BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wash, Wax, Detail, Cosmetic Maintenance & Repairs
EXXEL Distributions
      05-16-2022, 10:14 PM   #1
bobllama
Drives: 2011 E93 M3
2011 BMW M3  [0.00]
Advice on a couple of interior nicks/scratches
My 2011 e93 has a couple of signs of it's age now, with a nick in the interior driver door handle and some small scratches in the matte finish of the center console. Pictures attached of each. Any advice on how to fix or at least diminish the obviousness of either one? Thanks for any help!
      05-17-2022, 10:57 AM   #2
Hivand_M
Hivand_M's Avatar
Drives: E92 M3
Regarding your first picture, that part is pretty cheap to replace, and if you buy it from FCP, if you accidentally scratch it again, you can get a free replacement.
https://www.fcpeuro.com/products/bmw-cover-51459120979
The second picture, I believe that is all one piece and pricey. Not sure what you can do repair wise.
      05-19-2022, 08:28 PM   #3
bobllama
Drives: 2011 E93 M3
2011 BMW M3  [0.00]
Thanks, didn't realize it was so cheap. I tried to find a YouTube of how to remove it, but couldn't find one. What is that part called? "Center trim" seems to show the piece between the seats.
      05-19-2022, 10:34 PM   #4
Hivand_M
Hivand_M's Avatar
Drives: E92 M3
Skip to 2:46 for the removal. Tbh I'm not sure if you need to remove all previous items but just be careful if you decide not to.
I just searched for e92 headunit cover and it came up. That link didn't work?
      05-20-2022, 01:00 PM   #5
VtecforV8
17
Drives: 2010 E92 M3 6MT
Here's the part for pre-LCI--doesn't have the cut-outs for the auto stop/start and other buttons, but hopefully puts you on the right track.
https://www.getbmwparts.com/oem-part...el-51459118703
Try typing in your year and then going to "instrument panel components"
      05-09-2023, 08:46 AM   #6
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Drives: Green Bastard
get this
Purchase this rubberized coating spray. Near perfect match for interior parts.
Colorbond - 258 BMW Black LVP Refinisher Spray
      05-16-2023, 01:59 PM   #7
BGBF18
BGBF18's Avatar
Drives: '11 E90 M3 6MT
I just replaced the part in your first picture. As stated, cheap and relatively easy. Buy a dedicated trim tool.
The door pull is a PIA. I've done the full armrest replacement on my 2008 and it turned out well.
Now I have a 2011 with the same issue, but this time I plan on replacing just the door pull vice the whole armrest. The door pull was on Amazon and looks really nice.
In either situation, you'll have to remove the entire armrest from the door panel, which entails destroying the plastic "rivets" and mounting the new door pull.
Just FYI: New armrest 51418035887 is about $550. Door pull was about $30 on Amazon.
You'll still need to wreck the existing rivets and re-mount using 51419142455 (self-tapping nut) and 51419142456 (spring nut).
The new mounting system is just as robust a connection as the original plastic rivets, which was impressive.
I'll let you know how the door pull replacement goes.
FYI, RealOEM.com is a fantastic source for OEM diagrams and part numbers.
-BG
      05-16-2023, 05:37 PM   #8
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
This video shows how to drill out the rivets and pull out the door pulls.
Since this will be replaced with the aftermarket part, you can skip the restoration steps the video goes into. Just use the video for the removal and installation steps.
Auto Detailing Enthusiast!
      10-05-2023, 01:47 PM   #9
KenBNaples
Drives: 2011 m3
Curious. I assume you would have to sand all the soft touch off to have an even coat?
m3post
