Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Help to get use of ISTA
      05-12-2023, 06:45 AM   #1
Gezz
Drives: BMW 335i
Hi guys old member used to be As GerryH needed to re-register long story.I have dreaded abs lights. Fixed pump motor brushes. But still had issue with valve body. Changed it for a used one. However I still have Codes 5DD2 and 5DD0 which indicate that the module (still the original) needs to be calibrated.
2007 335i Any help /suggestions would be greatly appreciated
Cheers
Gerry
      05-12-2023, 05:18 PM   #2
TSilver335i
Australia
39
Drives: E92 335i
Cheers
Gerry
Check mega link in in the below pdf. Should get you out of trouble.
File Type: pdf E9x References, 220216 Revision-2-1-2.pdf (240.0 KB, 64 views)
      05-14-2023, 02:18 AM   #3
Gezz
Drives: BMW 335i
problem still
Thanks, T silver downloaded it but it wont launch no matter what I try. any suggestions would be appreciated
      05-14-2023, 06:29 AM   #4
TSilver335i
Australia
39
Drives: E92 335i
Could be in the download files already but did install vc_redist.x86.exe and vc_redist.x64.exe from mircoshaft?
Link is here anyway https://learn.microsoft.com/en-us/cp...?view=msvc-170
Tried to run istagui.exe as admin?
      05-20-2023, 09:39 PM   #5
TSilver335i
Australia
39
Drives: E92 335i
1. Make sure you have a functioning Standard Tools install.
2. Install all items in the "Pre-Install" Folder
3. Move "Rheingold" folder to c:\program files (x86)
4. Create shortcut for IstaGUI. It is located in C:\Program Files (x86)\Rheingold\TesterGUI\bin\Release
5. Move that shortcut to the "Bmw Tools" folder from your Standard Tools" install from step 1 and rename IstaGUI to "Ista"
6. Launch Ista and complete setup. When prompted for license, copy and paste the entire contents of the IstaLicense.txt file from this download.
***If you have issues launching ista and recieve a "failed to start" error, launch as administrator.
      06-07-2023, 12:22 AM   #6
Gezz
Drives: BMW 335i
Thanks
Hi TSilver thanks for all your help managed to get it solved Still coulnt get Ista but went to a local BMW guy who ran it for me
Cheers
Gerry
