11-13-2017, 11:19 PM | #1 |
60
Rep 129
Let's compare oils
Figured I'd make a thread for this since the list ended up being a good size. I have tried to compile a list of oils in the weights commonly mentioned on this forum. These oils cover everything from long life economy oils to race oils. If there is a blank, it means the spec sheets I found did not have that peice of information. I also tried to include if it was BMW or Audi approved (Sorry MB! I noticed that often the VW approved oils were also MB approved), be sure to double check!
NOTE: These oils are in no way my recommendation, just posting this information for others to use. Ordered by Viscosity @ 100C
Current : 2009 BMW E92 M3 SSII - Stage 2 - IPE F1 Exhaust
Previous : 2013 Audi A4 Moonlight Blue - Stage 3 (K04) E85 Last edited by Townending; 12-31-2017 at 12:13 PM.. |
11-13-2017, 11:20 PM | #2 |
60
Rep 129
Ordered By Weight
10W-60 15W-50 5W-50 10W-40 5W-40 0W-40
Previous : 2013 Audi A4 Moonlight Blue - Stage 3 (K04) E85 Last edited by Townending; 12-31-2017 at 12:14 PM.. |
11-13-2017, 11:21 PM | #3 |
60
Rep 129
Ordered by Brand:
AMSOIL Castrol Liqui Moly Mobil 1 Motul Ravenol Redline Royal Purple Shell Total Excel Downloads: Oil Specifications by Viscosity Oil Specifications by Weight Oil Specifications by Brand
11-17-2017, 07:02 PM | #5 | |
60
Rep 129
1. Shell Helix Racing 10W-60 (The New OEM IIRC) 2. Castrol Edge Pro TWS 10W-60 (The Old OEM IIRC) Both seem to fall at about ~23 @ 100C and ~160 @ 40C. As far as BMW is concerned, I would guess the above numbers are "optimal".
Previous : 2013 Audi A4 Moonlight Blue - Stage 3 (K04) E85 |
dreamspeed262.00 |
11-17-2017, 09:31 PM | #9 |
Stop the hate, get a V8
3853
Rep 8,625
You might want to put this on OneDrive or Google Drive and then share it out so people can grab a copy/manipulate it themselves.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
11-17-2017, 10:11 PM | #10 |
60
Rep 129
Many of the oils listed above are great oils. One could be better for a specific climate or vis versa. A few of the oils are track oils meant to have very short OCIs. I posted this list so that someone looking to move away from the OEM oil can compare all the manufacturers posted specs and chose an oil they would like to research from there. My thoughts: After reading through many of the rod bearing threads, and doing research on other threads, I personally felt 10W-60 was too thick for my daily driving style. My oil temp needle would normally stay around ~195F with the OEM fluid. I read about how many were switching to Mobil 1 0W-40. I didn't really like the idea of jumping all the way to 0W-40, so I chose the 5W-50 group to focus on. I boiled it down to Amsoil Signature Series and Redline Full Synthetic. AMSOIL ended up being cheaper and easier for me to obtain, so that's the one I went with. I've been running Amsoil Signature Series for the past ~25k miles with an OCI of 5-7k miles.
11-17-2017, 10:13 PM | #11 | |
60
Rep 129
EDIT: Added the downloads at the bottom of Post #3
Previous : 2013 Audi A4 Moonlight Blue - Stage 3 (K04) E85 Last edited by Townending; 11-17-2017 at 10:23 PM.. |
11-29-2017, 11:51 PM | #14 |
60
Rep 129
I'll get the pics up top updated later, for right now though check below
Brand: Ravenol Line: RSS SAE Grade: 10W-60 Viscosity @100C: 23.6 Viscosity @40C:154.4 Viscosity Index: 184 Flash Point: 236C Pour Point: -51C HTHS: 5.8 Total Base Number: 11.1 Evap. Loss: BMW Approvals: N/A Audi Approvals: N/A
11-29-2017, 11:56 PM | #15 |
60
Rep 129
The rest of the stats look amazing as well. That would be my oil of choice if it was easier/slightly cheaper for me to obtain.
11-30-2017, 07:36 AM | #16 |
114
Rep 130
I've done a bunch of reading on various oils and properties but would you mind sharing a little bit about how the differing characteristics affected your choice and feel free to pretend im a dummy
11-30-2017, 11:00 AM | #17 |
Rep 10,678
Porsche 991 GT3 uses 0W40 Mobil 1 -- seems to work fine as the year round and track day oil in that 4.0L 9000 rpm motor.
JPSurratt200593.00 |
11-30-2017, 02:28 PM | #18 | |
60
Rep 129
Using OEM Castrol and Shell fluid, I was never able to get the oil temp marker to stay at 210F, it would raise to 210F while I was on it, but drop down to ~195F when I would take it easy. In my eyes, this tells me I'm not getting the oil up to ideal operating temp. I then read about the users (one being a very close friend) who switched to Mobil 1 0W-40 and saw acceptable wear on their bearings. (Can't say for sure if they were lucky to have minimal wear, or if the oil actually did help.) Now, with the above information, I started comparing oil viscoisties. After seeing the numbers, I decided that Mobil 1 0W-40 was too thin for my liking. I was worried that if I did choose to really push the car, that the 0W-40 would not be thick enough once the temps started climbing. I then focused on AMSOIL 5W-50 Signature Series, Redline 5W-50, and Motul 5W-50. Motul was a PITA to get, so that was dropped from my choices. Back when I made this decision, AMSOIL had not introduced their new formula. At the time the stats on paper for AMSOIL were much closer to Redline, they were almost the same. Since I was looking at two great oils with very similar specs (based on tested specs), I simply went with the one that made more sense financially. I buy AMSOIL in a 12QT case for $102* shipped (1-Day Shipping), bringing it to $8.50 a quart. Where as ordering Redline would have cost me $13 a liter, and I would of had to pay a ton for 1 day shipping through ECS (My store of choice for Redline). After my first oil change with AMSOIL, I noticed the engine had a much smoother rev pulling out of my driveway after a cold start. Not only that, but oil temps stay at 210F for light daily driving / spirited driving. And there you go, my thought process. Again, I have no concrete evidence saying 10W-60 is not ideal for DD. But after my research, I felt most comfortable with AMSOIL or Redline 5W-50
BimmerRules!110.00 |
11-30-2017, 02:36 PM | #20 |
60
Rep 129
Seems like an Apples to Oranges comparison. I'm not familiar with the GT3 4.0, does it have the same bearing clearances? Would you think the difference in engine balance could play a factor (Flat-6 vs V8)?
11-30-2017, 02:56 PM | #22 |
Rep 1,122
