05-28-2022, 02:52 PM | #1 |
4512
Rep 1,862
Drives: powered by bootmod3
bootmod3: N55-PWG CustomROM release - MapSwitch, FlexFuel, AntiLag
Hey gang,
We've just released our CustomROM features for the N55-PWG vehicles. Map Switching via steering wheel, Flex Fuel integration, Anti Lag, In-Dash Ethanol Content checking, Live Adjust without re-flashing for burble, ethanol content override, and much more via custom tuning in the integrated BM3 Map Editor. We have also made 3 new OTS MultiMaps available including Stage 1, 2 as well as a 2H each with 4 slots preset and flex fuel functionality built in. Enjoy!
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
05-28-2022, 03:48 PM | #2 |
Rep 3,680
Wooo finally! Couple initial questions:
Is there a way to adjust which map is in which slot? For example if I want slot 2 to be a stage one map as opposed to stage 2 91. Can the antilag be activated when stationary, if so how? What is max boost limiter? Do I need to activate that to prevent overboosting? I should think not but just checking as I haven't seen it before.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
05-28-2022, 04:00 PM | #3 | |
1302
Rep 3,550
Yes, same as rolling It's It's max boost limiter. You can limit max boost.. has nothing to do with overboost. If the map says it's gonna run 14psi you can limit to whatever you want. 8psi, sure.. 9psi, yup.. etc
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
05-28-2022, 04:01 PM | #4 | |
1302
Rep 3,550
05-28-2022, 06:06 PM | #5 | ||
Rep 3,680
Also, in a 6MT car, how would the anti lag be used when stationary to launch. Clutch in, first gear, activate anti lag, and then time the release of the clutch with the release of the button?
05-28-2022, 07:44 PM | #6 |
Rep 664
Drives: 2013 BMW 335i
Just flashed it, havent gone for a drive yet. I left the running and went to live adjust to set burbles but i only see options overide and aggressive. Is there no way to adjust it like before where it showed duration, aggressiveness, min/max rpm as well as different settings for sport mode?
05-29-2022, 12:14 AM | #7 | |
1302
Rep 3,550
05-29-2022, 09:29 AM | #9 |
24442
Rep 191,344
05-29-2022, 03:32 PM | #10 | ||
Rep 664
n55david1301.50 |
05-29-2022, 03:41 PM | #11 |
1302
Rep 3,550
No problem!
05-30-2022, 09:25 AM | #12 |
Rep 664
Since it now supports flex fuel, so I need to swap anything else out in the car besides high pressure fuel pump if I want run full e85? My friend said I don't need to change injectors or anything and just need hpfp for full e85 on my n55 pwg
05-30-2022, 12:15 PM | #13 | |
1302
Rep 3,550
Also.. you will need a custom flex fuel tune to do it properly since there sre no full e85 maps available from bootmod3 ots.
UhhItsANT79.50 |
05-30-2022, 02:17 PM | #14 | |
Rep 7,624
05-30-2022, 02:19 PM | #15 |
1302
Rep 3,550
The multimap doesn't include an e30 map right now.. just pump gas...
05-30-2022, 02:32 PM | #16 |
Rep 7,624
Gotcha. Can't confirm since i dont use BM3 but isnt the intent of FF to be able to blend any amount of E% even if the "starting map" is a pump gas map? I thought John and others had tested by adding E and starting with the OTS 93 map and the tune would adjust. Would need to go read that thread again. In this way, it didnt matter if you were on the 93 map or the E30 map (latter doesnt exist in this case), if you were running say E60, the actual tune adjusted for flex fuel would be the same.
UhhItsANT79.50 |
05-30-2022, 02:49 PM | #17 | |
1302
Rep 3,550
UhhItsANT79.50 |
05-30-2022, 05:02 PM | #19 |
1302
Rep 3,550
No problem. There is so much bad info out there on this.
05-30-2022, 05:04 PM | #20 |
Rep 932
It doesn’t need to include an E30 map now because you got flex fuel right inside these OTS. So whatever you fill up with it just goes up and down from there based on flex fuel sensor whatever its reporting.
05-30-2022, 05:05 PM | #21 |
Rep 664
yeah im new all this ethanol stuff and was avoiding running e30 until they came out with flex fuel. wanted to try full e85 due to cali gas prices even though i know i'll visit the pump more often lol. 91 here is about 6.50 on average lol.
05-30-2022, 05:11 PM | #22 |
1302
Rep 3,550
Okay, even still. Max benefit is e30 since.there is no e85 map.
antilag, bm3, bootmod3, customrom, flex fuel |
