spacers
08-14-2014, 02:30 AM | #1 |
185
Rep 2,320
spacers
Are they safe to use? Anybody using them on stock Bmw wheels? For example anybody with Bmw performance wheels?
I was wondering can Bmw SA install spacers? Thanks
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
08-14-2014, 09:05 AM | #2 |
Rep 3,200
Drives: E92 325i MSport Coupe
Use hub-centric spacers from a reputable manufacturer like H&R or Eibach and you'll be fine. Don't forget you'll need new wheel bolts (longer by the thickness of the spacer you use).
08-19-2014, 01:37 PM | #4 |
Rep 980
Drives: '08 BSM 335i e92
If you need a BMW SA to install spacers, you shouldn't be driving a car. That's about the simplest DIY there is. Quality spacers will come with extended bolts. Here's the DIY:
Place vehicle on level ground Set e-brake Break the 5 lugs free (17mm socket) (don't remove them) Jack up the car Support with jack stands Finish removing the 5 lug nuts with 17mm socket Remove the wheel Install the hubcentric spacer on the hub of the vehicle. Ensure it's properly seated Reinstall the wheel on the spacer (tricky part is to ensure all bolt holes line up) Start threading the new extended lug bolts into the holes, get them hand tight Lower the vehicle back onto the ground off the jackstands Tighten all 5 lugs to 88ft.lbs torque spec Drive ~25 miles Retighten all 5 lugs to 88ft.lbs torque specs. Smile because you just completed the simplest DIY out there, and didn't fork over any money to your BMW SA. (In laymans terms) Remove wheel Install spacer Install wheel
'08 BSM E92 335i 6MT/MHD stg 2+/VRSF 7" FMIC/VRSF CP/HKS BOV/VRSF catless DPs/BMS DCI/muffler delete/BC Extreme lows/OEM style 167s/BMS high side OCC/Mishimoto low side OCC/etc
08-19-2014, 01:46 PM | #5 |
Rep 1,166
Can't tell if serious...
2008 e92 M3: Gintani Sport w/ Topspeed Catless X-Pipe, KW-V3
