2010 2011 BMW 5 Series Forum F10 Sports displays in iDrive |
03-18-2016, 06:46 AM | #4 |
44
Rep 327
I rarely use them. Interesting sometimes to know what power is being thrown out in various throttle, gear and load positions though.
Hand on heart, bit of a gimmick I think!
2015 F11 535D M Sport Touring, Space Grey, VDC, HUD, Comfort Seats, Sport Auto, Pro Media. GONE
2013 Z4 35is + tons of options. CURRENT |
03-28-2016, 04:46 PM | #5 |
173
Rep 278
Is this an optional extra ? I dont seem to have it on my car. Its a 2013 F10 535d M Sport and it has all the modes Sport, Sport +, Comfort, Comfort +, Eco Pro. It also has adaptive drive if this has an affect ?
03-29-2016, 09:06 AM | #6 | |
General
1571
Rep 29,202
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
03-29-2016, 09:29 AM | #7 |
Rep 54
04-02-2016, 10:52 AM | #9 | |
Rep 1,161
can be done via USB now.
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
04-02-2016, 05:37 PM | #10 |
173
Rep 278
Cool, I like the sports display ! I might get that. My car is remapped, would it show the measurement up to the power or will it go off with scale ?
04-04-2016, 11:02 AM | #11 |
Rep 5,050
it would be more useful if the sport display showed some relevant engine info such as oil and water temperature or even gave us some additional simulated gauges, instead we've got a useless gimmick.
04-05-2016, 02:03 AM | #12 |
Rep 1,040
With you on this one, mind you I always liked BMW for having the oil temp dial rather than the water temp one in Audis and others, and glad to have the oil back with the f10 back after going missing with e60.
04-05-2016, 04:27 AM | #13 |
Rep 15,858
Agree, it would so useful to have a menu option to see the key data without having to go through the hidden menu. Data is all there, just a simple gauge like display would be good. Oil, water, voltage, etc.
04-05-2016, 05:45 AM | #14 |
Rep 5,132
I always feel that products get "dumbed" down and information hidden away as it may be felt that most people simply are not interested (probably true)
I supposed the software is designed so if there are readings outside of normal parameters, it will warn you, otherwise there is no need for you to know. |
04-05-2016, 02:46 PM | #16 |
Rep 5,132
I'm pretty sure it was introduced with the LCI models
Your only option is to go the coding route. I'm sure I read that it was a bit hit and miss and only worked with some engines. A quick google shows the values for CIC or NBT are:- 3000 EFF_DYN_SPORT_CID set to: aktiv 3000 EFF_DYN_SPORT_UNIT set to: aktiv to change to Ibft and HP in KOMBI 3008 DREHMOMENT set to: lb_ft (displays ft lb) 3008 LEISTUNG set to: ps (displays hp) |
04-05-2016, 03:41 PM | #17 |
Rep 5,050
04-05-2016, 05:02 PM | #19 | |
56
Rep 225
http://www.bmw.com/com/en/owners/bmw_apps_2013/apps/bmw_m_laptimer/ .. Just sayin'... |
04-05-2016, 05:26 PM | #20 |
Rep 1,040
For a 2013 you should be able to code this, I did check this with an independent BMW specialist that installs BMW original Sat Nav some time ago and it was down to cars produced from 2012 onward not sure the exact month, my one a 2011 so not an option.
05-02-2016, 02:05 AM | #21 |
Rep 897
Yes it would!
2017 M3 Comp Pack 450PS
2017 C63S T 510PS |
05-02-2016, 04:20 PM | #22 |
Rep 3
I bought an app and Bluetooth dongle to check come codes on mine a few months ago.
Although gimmicky there are lots of customisable, real time screens you can add to the phone/tablet, I only used it a couple of times for my 0-60 for as laugh. |
