BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      09-21-2013, 09:07 PM   #1
ccondo
ccondo's Avatar
161
Drives: 2017 BMW M4 - Ferrari Red
Question Need my 4th set of rotors in 1.5 yrs!
I just did 1 day of a 2 day track event and skipped the last run group. 1/2 way through I started to get shake in my steering wheel when I brake hard.
I am on my 3rd set of rotors already and this set it only about 4 months old.
I spoke with people at the track and I was told things like maybe a rotor is getting stuck as well as I was told that if I use the breaks after the cool-off lap and hold them that might be causing the issue as well.
So any feedback or ideas on how this is happening would be appreciated.
Also since I very well might be purchasing a new set of front rotors I was hoping for some advice on what to purchase. I was thinking of OEM rotors with Pagid Dark Blue pads, Stop Tech brake lines, and Motul brake fluid.
I was planning on keeping the rear stock. ANy feedback is appreciated.
      09-21-2013, 11:02 PM   #2
paddy335
Drives: M140i;X5 40d
If you are tracking a lot, as Lute said. If you are I assume you aren't applying your handbrake in between sessions? If you are, don't.
If you aren't tracking much then you have a problem and should go see your dealer.
      09-21-2013, 11:11 PM   #3
FVM3
FVM3's Avatar
273
Drives: e92 m3, f30 328i
get BBK
      09-21-2013, 11:14 PM   #4
smmmurf
309
Drives: E92 M3 DCT 353k+ miles
Originally Posted by Lute View Post
Upgrade to a big brake kit
x1000000000000000
      09-21-2013, 11:49 PM   #5
Longboarder
Longboarder's Avatar
3431
Drives: 2016 BMW i8
After every track session I needed to get the stock rotors done as they would vibrate. Just got sick of that and got a BBK (StopTech 380/365 cross drilled rotors). I run street pads on the ST BBK and it's more than enough for the track. Have never had any vibration even after a 100 degree track day at Big Willow (fastest track out West) beating the snot out of the brakes.
So yeah, another vote for a BBK.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      09-22-2013, 12:59 AM   #6
AxisMagi
AxisMagi's Avatar
Drives: 2011 E90 Lemans Blue
I had the same issue even after upgrading lines, pads, and fluid.
The stock brakes get extremely hot when pushed to the limit.
One day my front wheel actually caught on fire! After replacing the
rotors once and then the same thing happening again I said F it and
went for the BBK. So much more stopping power and they never
even break a sweat. If your tracking hard BBK really is worth it...
~Axis
_____________________________
2001 E46 Race Car - S54 Swap - Moton Suspension - CAE Shifter
2011 E90 M3 - ESS VT2-625 Supercharger - Stoptech Trophy BBK - Ohlins Road & Track - MP Exhaust
      09-22-2013, 07:48 AM   #7
meyergru
No military grade
meyergru's Avatar
Germany
58
Drives: E92 M3 DCT
Did you bed the brakes as described here? If not, your rotors may wear very fast, especially, when you use them on track. This would apply as well, if you get new rotors...
It sounds as if you are using the stock brakes on track events. If you take that seriously, you should at least use the M3 race pads from BMW, which have less wear (and squeal like a pig in day-to-day driving).
      09-22-2013, 08:17 AM   #8
Chill72
Chill72's Avatar
Drives: 10 E92 M3 (RIP)
Driver fail.
      09-22-2013, 12:19 PM   #9
BMW Fanatic
135
Drives: slow
BBK
Do not put handbrake up (our cars go into park once turned off, not like SMG M5)
Bed your brakes in, worst thing you can do is put a new set on and go straight to the track.
      09-22-2013, 12:24 PM   #10
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
Originally Posted by BMW Fanatic
BBK
If manual, just put it in gear when parked
      09-22-2013, 12:40 PM   #11
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Originally Posted by Chill72 View Post
Driver fail.
+1, what are you saying, that you ran your rotors to minimum in 2 track days, warped them? the shake you feel is pad deposits. your rotors are fine. i didnt pass a tech inspection mine were so bad and just ran track pads on them and shake went away and used them all the way to minimum thickness. as others have said dont use your handbrake in the pits, you must do a cool down lap, and i add extra time driving around the pits if needed to cool further.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      09-22-2013, 12:50 PM   #12
Longboarder
3431
Drives: 2016 BMW i8
Originally Posted by 1MOREMOD View Post
+1, what are you saying, that you ran your rotors to minimum in 2 track days, warped them? the shake you feel is pad deposits. your rotors are fine. i didnt pass a tech inspection mine were so bad and just ran track pads on them and shake went away and used them all the way to minimum thickness. as others have said to use your handbrake in the pits, you must do a cool down lap, and i add extra time driving around the pits if needed to cool further.
Hopefully for op it is pad deposit...but quite often it's not. I was hoping my vibrations from tracking on stock brakes were due to pad deposits but they ended up being from warped rotors each time. Only time they didn't warp from a track day was when I was at a slower/tight track on a cool day. They're nice brakes for the street, but just can't handle sustained track usage IMHO.
a couple others
      09-22-2013, 12:55 PM   #13
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
i am of the opinion that there is no such thing as a warped rotor at least not on these very capable units on the m3. i was told by bmw and an independant shop that they were warped when in fact it was just really bad pad deposits. i proceeded to run a set of track pads for a short time and they were fine. if the people working on our cars cant tell the difference it no wonder owners cant. i had extreme shudder under braking, made it feel like the car was going to fall apart. they said it was the worst warped rotors they had seen. still were wrong.
      09-22-2013, 01:11 PM   #14
brado
22
Drives: 2009 e92 M3
If you can not afford a BBK I highly suggest cryo-treating whatever rotors you choose. This will improve the life of your rotors exponentionally
      09-22-2013, 01:26 PM   #15
LightWerkz
Drives: E90 M3
Stock rotors are just fine for DE's. What you need are some real track pads.
Listen to this man. I had the same experience, a few times, and track pads for a week weeks and things cleared right up.
Use the right track pads, with plenty of meat on them and your system will hold up great.
No need for BBK. But if you makes you feel better, go for it. If you were using stock brake pads, thats your problem.
      09-22-2013, 02:11 PM   #16
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Thank you. I ran stock the entire time I had the e90. Now on my e46 I went with bbk. Stock with proper pads and fluid work nearly as well. Have to be a little more careful to manage temps is all. Now I just put more heat into the brakes because I use them harder and boiled my fluid, were stock I didn't.
      09-22-2013, 03:07 PM   #17
dex37
dex37's Avatar
Drives: E92 M3
Performance Friction Direct Drive rotors are supposed to be a little better, but unfortunately there is no hard data on that. Due to their construction, they are supposed to be less prone to warping, but who knows. The stock rotors are quite good, but in my lame opinion the aluminum hat covers too much from the cooling vanes of the rotor. If you look on the back side of your rotor, you will see what I mean.
      09-22-2013, 03:08 PM   #18
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Sure hope OP didn't pay for 4 sets of rotors as well. My e46 needed rotors so that's why I got the bbk. No sense paying for parts I don't want anyways.
      09-22-2013, 03:32 PM   #19
Longboarder
3431
Drives: 2016 BMW i8
Interesting. The guy that does my brakes tracks his e92 M3. He knows the difference thankfully. He even said, "lets see if it's pad deposits or whether its warped" (each time). I'm an outlier because I need more brake pressure to slow down as I attain higher speeds but need to slow down more than most due to the S/C with stock suspension.
a couple others
      09-22-2013, 03:38 PM   #20
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
most people even your guy probably are smart enough to not track the e9x with stock pads. thus they have never experienced the level of pad deposits that they are capable of generating. i however was an idiot and ran my stock pads past the point they should have been used and created a mess. when you measure them they will appear warped, only way to truely tell is to run the crap out of them with a track pad to clean them up.
      09-22-2013, 03:45 PM   #21
Longboarder
3431
Drives: 2016 BMW i8
No need for a BBK huh?
Go toss an S/C on your car, reach 155mph on the back straights of your track and brake hard (really hard) on a hot day. Then couple that with a downhill braking at 100+ and a couple other hard braking zones mixed in for fun. Then do that 15 times around the track.
When your stock brakes (even with upgraded pads) start vibrating and then your brake pedal hits the floor at ~ 120mph and you need to downshift hard and pull the ebrake to avoid going off the track into a pile of boulders you will find out real quickly the need for a BBK.
a couple others
      09-22-2013, 03:48 PM   #22
ccondo
ccondo's Avatar
161
Images of my front drivers rotor
I am starting to wonder if it is deposits as well.
I am trying to determine if I should get some Pagid Sport pads for track/street use and I am thinking if it is deposits those pads would get rid of the deposits.
Here are some pictures of what my rotors look like:
http://www.flickr.com/photos/caseyme...7635774625134/
This is after washing the car and I took a pressure washer (with a 40 degree head) to the rotors.
brakes, rotors
m3post
