04-03-2024, 08:45 PM | #1 |
Rep 3
Drives: 2020 M4 Comp LeMans Blue
Tire Size Advice
Looking for some advice on tire size
Wheels will be the following: 19 x 9.5 ET22 19 x 10.5 ET25 Tire sizes I'm considering: 275/30 295/30 OR 265/35 285/35 I'm lowered on EMD springs and would like to know which tire size would fill the wheel gap more. I'm looking for a perfectly flush look in terms of ride height, but also don't want to compromise traction with this setup. |
04-03-2024, 08:57 PM | #2 |
Rep 5,554
10.5et25 with a 285 or 295 is extremely aggressive and, even with significant camber, the tire will poke out of the fender. 10.5et35-46 with 285/295 is where you want to be (10.5et46 M2 CSR 513M forged wheel is a great option).
04-03-2024, 09:18 PM | #3 |
Rep 3
What about changing the rear to 19x10 et25? A little less aggressive but only 15mm more than stock. Do you think this will still poke out?
04-03-2024, 09:30 PM | #4 |
Rep 5,554
It’s still an aggressive setup but is used by forum members. However, it’s too aggressive for me. It should work with a 275, maybe a 285, definitely not a 295. 295 is too wide for a 10” rim. May require a little extra rear negative camber to get a 285 to clear the rear fender depending on the actual tire width.
