10-21-2017, 06:10 PM | #67 | |
Rep 37
It says that production was on 2016-04-07, so its just plug and play Sorry still learning... |
10-22-2017, 03:46 AM | #68 | |
13
Rep 65
It is not plug and play. My F20LCI is from march 2016 and it comes with NBT head unit. So i would take a lookat flebay to one of the following part numbers: 65509292248 <--Pre LCI ( black is with a bleu-ish tint) 65509387453 <-- LCI (More "black is black") display For mine F32 I bought the LCI. It looks awesome and is worth every penny. After replacing the screen you need to code the following values: HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display This job doesnt take more than half hour work. The coding you can do with a laptop and with the Esys software. Or you can buy the bimmercodeapp. http://www.bimmercodeapp.com/ That is how i coded my display. easy peasy |
10-22-2017, 09:04 AM | #69 | |
Rep 37
10-22-2017, 01:07 PM | #70 | |
13
Rep 65
The bimmercodeapp is 30 bucks and the Vgate iCar 2 Wi-Fi OBD adapter is somewhere around 15 bucks. (depends where you live) |
10-23-2017, 04:23 PM | #71 |
Rep 565
As a side note - you don't have to code the resolution, just the DISPLAY_VARIANTE. I've had a 6.5" screen that came with a default resolution set to 10" in eSys. I've swapped it for an 8.8" and left the resolution as-is and everything works okay.
10-24-2017, 05:44 AM | #72 |
13
Rep 65
Yeah, sometimes you need to code only the DISPLAY_VARIANTE. But this is not always the case. Thats why you have to check both.
10-27-2017, 08:36 PM | #74 |
Rep 37
11-02-2017, 07:53 AM | #75 |
Rep 565
Hi guys, I'm having my car's software (the whole car, not just the head unit) updated next week. Is it okay if I leave the 8.8" screen attached during the update? I know I'll have to code the screen again afterwards, but will the software update go through okay or may the larger screen somehow screw it up? Thanks for any info!
11-02-2017, 07:58 AM | #76 |
Rep 29
I would like to install 8.8" in my car, but my dealer told me not to do anything because BMW might void my warranty if i have any problem with electronics. So does anyone know if i can swap it back before service and re code it to 6.5" screen? Can they see something was coded before in some history, logs or something like that? I have my car for 9 months now so dont really want to lose my warranty...
11-02-2017, 08:17 AM | #77 | |
Rep 565
PS: It all depends on the dealer - you're using an original BMW screen in your car, even the car & head unit both support it, but BMW doesn't sell that specific config (no nav with large screen). Some dealers don't have a problem with that, others do. I heard that in the US, you should still have warranty coverage on all other parts that you haven't fiddled with. |
11-02-2017, 08:26 AM | #78 | ||
Rep 29
11-06-2017, 07:56 AM | #79 |
Rep 832
Drives: 2019 G01 X3
Is it possible to code USB video after upgrading to the 8.8” screen? 2015 F32 EntryNav HK
11-06-2017, 12:51 PM | #80 |
Rep 565
11-12-2017, 01:34 PM | #81 |
29
Rep 152
Hi,
I have a 2016 320i F30 with the 6.5" entry nav screen. From reading the posts do I just need to purchase an 8.8" screen and do the coding? Or is more needed? Thanks. I attached a picture of my iDrive screen because I have no idea if it's compatible or not. |
11-26-2017, 10:34 PM | #83 |
Rep 29
Ok i found screen part number: 65509387453
This should work for my f30 lci production date 09/2016. No nav basic 6.5". Im just confused it says its NBT Evo and it says it can not be used for NBT. What does this Evo means? |
11-27-2017, 08:58 AM | #84 |
Rep 565
NBT Evo is a newer head unit which comes with iDrive 5 (or 6). Since your car does not have navigation, you should have the older head unit (HU_ENTRYNAV). Your iDrive should look like steve498's (see 2 posts above). If that's the case, you can install the screen you mentioned.
12-09-2017, 07:22 PM | #85 | |
Rep 23
My car was produced 12/2015, can i install the f15 screen? What version of ESYS do i have to use, Lite or Full version ? Thanks |
12-09-2017, 07:40 PM | #86 |
Rep 565
12-09-2017, 08:06 PM | #87 | |
Rep 23
At this moment i doesn´t know The screen part number bacause i doesn´t no in the future if i change my NBT to Evo is it posible to install ID6 with a 10.2 f15 screen. With a 8.8 screen and a NBT Evo i Know it´s posible to install id6 but with 10.2 i doesn´t know the answer. With my NBT with business gps is it posible the see vídeos in motion after coding? Many thanks |
