BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
GetBMWParts
      04-24-2024, 11:47 AM   #13091
usta83
Drives: BMW 116 (F20)
Originally Posted by fe7565 View Post
This has reduced the latency of the music a lot!
      04-26-2024, 06:16 PM   #13092
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
Good information. Glad it helped!
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
      04-26-2024, 08:00 PM   #13093
Coderedpl
Coderedpl's Avatar
Drives: F80 M3
Recently got mine and installed in my F80. I purchased the MMI box from Andream for the sole purpose of Android Auto, my 2018 VW had it and my wife's 2018 Q7 has it but my 2018 BMW doesn't 🤦‍♂️
Pretty easy to install, a bunch of fiddling with the wires to get it all back together. The screen right angle connector gave me a bit of trouble to find that perfect spot to put the screen back on.
Everything appears to work properly, thankfully we can use full Bluetooth from the car which is awesome, plays music and takes calls without an issue. I tested it a few times.
Some things I noticed:
* No factory touchscreen capabilities, not a big deal as i rarely use the factory one anyway
* Can't change to next song using wheel controls like you normally would (while on the MMI/Android Auto screen)
* When you're on a call with someone, you'll see it on Android Auto, but if you go back to the BMW menu mid call, you'll still see the call there too.
* Same goes for the music. I have Spotify playing on Android Auto, I see it there but if I go back to main screen, I also see it on the car side
* Get in car, start car and it connects via wireless pretty quick for Android Auto.
* Wired android auto works aswell with the USB connection but there is a delay. You'll connect it, go to wired auto. It'll say to connect device, and then a few seconds later on that screen it'll start.
* Minor annoyance is the delay of shut off, I'm assuming it has to do with the 10-15 minutes before car goes to sleep. I rarely lock my car in my garage and sometimes I'll come home and start doing things inside said garage, and I'll turn on my Bluetooth speaker. During that 10-15 minute window, my phone just keeps trying to connect and reconnect to both the WiFi and Bluetooth of the MMI box, causing interruptions of playback but also notifications on the phone saying, oh android auto is available blah blah. This also seems to happen if I wake my car up for whatever reason like when I went to vacuum the interior, and it kept causing my music to stop because it would try to connect to the MMI box.
* If you want to use the "YouTube" app, you'll have to turn off use Car Bluetooth option. Makes sense to me.
* Rear camera works without issue
* Microphone works without issue
I haven't messed around with it much more yet but it does seem to work for what ifs supposed to do, granted it will have some limitations but what I'm most happy about is that there isn't a loss in Audio Quality thanks to using car BT.
fe7565552.50
      04-26-2024, 09:29 PM   #13094
fe7565
fe7565's Avatar
Originally Posted by Coderedpl View Post
Recently got mine and installed in my F80. I purchased the MMI box from Andream for the sole purpose of Android Auto, my 2018 VW had it and my wife's 2018 Q7 has it but my 2018 BMW doesn't ��‍♂️
Nice write up!
I use CarPlay, but some of these may apply universally or to AA...
For steering wheel control scroll, try to code (Bimmercode expert or other).
These are CIC and NBT, so if you have NBT EVO use the equivalent codes:
BASIS_KOMBI_MMI_LIST = aktiv
or...
HU_NBT > KOMBI_CIC > kombi_low
and MMI_List > aktiv
Phone call issues:
Make sure that in the phone Bluetooth settings the device is set to "car speaker" and that you have given the myriad of permissions that Android requires for BLE and wifi connections.
If no go: try to delete all BLE connections from car and MMI and phone and re-pair all of them again ( I know it's a pain)
If no go: then may want to try to use only BLE between the phone and the MMI only...or the phone and the car only (do not see much benefit).
The MMI seems to boot up at times a fraction later than the HU. This causes an internal CID bus error that you cannot see unless you use ISTA+, but you can ignore it. But this is also happening when powering off the HU and the MMI. That's when you see the "No Signal" in the CID. This is something that short of a hardware solution the Chinese manufacturer should be fixing via coding.
I tried using YouTube but could not set it up. Gave up after a couple of tries since it's not a priority. How did you get yours working?
Yes, as long as you are in BLE range of the car with your phone, it will want to stay connected or may reconnect.
At times, if you go out of BLE range, and then return about 10-20 mins later (assuming that the HU did not yet go to sleep) the MMI will not reconnect to my phone via BLE. May be 1 out of 10 times. I have to press BACK button for 3+ secs to reboot MMI and then it reconnects 19 out of 20 times. If that does not work, I may have to delete the phone to MMI BLE link and re-pair again.
      04-27-2024, 02:05 AM   #13095
Nath4n
34
Drives: X7_M50d(2020), X5_30d(2015)
Originally Posted by Migz71 View Post
This is not version 1.7x update its just a mcu update. Is there a 1.7x update out for the Andream mmi's yet? Cheers
What about re-reading my post again? Try it a bit slower...
I never said it's FW update.
      04-27-2024, 04:22 AM   #13096
davidalme
Drives: BMW F20 LCI 120i
Nice write up!
or...
Phone call issues:
Hi,
I have the same problem regarding the connection between the phone and the car only when I unlock it. Spotify starts playing music and a message pops up on my phone that Android Auto or Waze is running. This annoys me so much because when I vacuum my car without switching on the ignition, there is a connection between the RoadTop box and my phone. Do you see a solution to this?
What exactly do you mean by what you wrote: "This is something that short of a hardware solution the Chinese manufacturer should be fixing via coding." It is something that can be solved via a local USB update?
Full text from you for a bit more context:
Best,
David
      04-27-2024, 10:21 AM   #13097
fe7565
fe7565's Avatar
Originally Posted by davidalme View Post
Hi,
Best,
David
The MMI powers on when it gets power from the car. The power on time depends on the internal hardware of the MMI and the software boot time. The engineers would have to make either hardware or firmware changes to make the MMI boot up faster than the HU and CID as to avoid errors on the car’s bus not seeing the CID. The MMI sits between the CID and the HU.
The auto music play at start up is written in the firmware. It starts if you have the HU menu set to Multimedia => Phone. You maybe able to set your phone not to allow auto play. Some others suggested to set an automation routine in the iPhone that stops the music playing when Carplay starts/connected.
I rather have the MMI connect to the car automatically when the phone is in range, even if annoying, than not.
Do not expect Apple or Samsung level sophistication and user integration from a $220 Chinese hack.
      04-29-2024, 07:36 AM   #13098
perfegram
Drives: BMW E63 650i
Originally Posted by perfegram View Post
Hi there! I installed Andream (CIC version) on my E63. CAN bus is connected in-line between the iDrive controller and the car.
Generally it works, but after getting in the car the MMI unit does not work for a while, like 30-60 seconds until CarPlay appears on the screen. Till then I can't control CIC, but I see the OEM picture. Is there a fix for it?
The problem has been solved by the updating MCU to the version 23.8.1.116 (August 2023 I guess) from here:
https://f30.bimmerpost.com/forums/sh...ostcount=12373
And ISPBOOOT.BIN (1.6.16_n the latest one for CIC) from the sharepoint link post:
https://f30.bimmerpost.com/forums/sh...ostcount=11917
There's also an update for MCU at the sharepoint, but the file modification date is Feb 2023, so I guess it's not the one I have and not the latest.
fe7565552.50
      04-29-2024, 10:48 AM   #13099
usta83
But I have switched back. The sound quality is way lower.
      04-29-2024, 10:52 AM   #13100
Gee Cee
Drives: 335D Touring
Hi All,
New to the forum. Decided to move away from leasing and picked up a 335D Touring at the weekend.
The car was highly spec'd, inc. Pro Nav, but being a 2015 model and NBT does not have the Apple Carplay functionality I'd like.
I've been reading through this thread at the various MMI options and like the sound of the Mr12Volt one, but that would use the existing 8.8 screen which is a noticeable step backwards in terms of screen resolution, clarity & colour etc, from the screen in the 2021 3 series touring I had as my last lease.
I've seen (from reading on here) that integrated automotive offer an OEM upgrade to the newer ID6 screen that already has carplay and is touchscreen. Their case study video on their website talks about the other benefits of the upgrade, namely nav, full-width screen, GPS, reversing camera, etc, but my car has all of those already. And at £1.2k it's not a cheap upgrade, so I'm wondering if there's an alternative I've not seen yet to upgrade the screen as well as adding carplay?
TIA
      04-29-2024, 04:39 PM   #13101
fe7565
fe7565's Avatar
Originally Posted by Gee Cee View Post
Hi All,
TIA
There is another thread here (look for Android HU 11 / 12 /13) for Android Head Units that is built into an after-market Chinese screen. I installed one a few years ago for $450 and uninstalled it after two weeks. It was too reflective. Check with that thread and ask them if this glare issue was resolved and also what the current screen resolution is.
The other option is to go OEM screen, but that brings with it more hardware upgrades and coding issues for a 2015 car, which are time consuming and takes time to learn unless you are willing to spend over $1K for someone else to do it.
      05-01-2024, 03:17 PM   #13102
justenx
Drives: F56 Mini Cooper
Does someone know how to get rid of the audio delay and make steering wheel buttons control tracks?
I tried BASIS_KOMBI_MMI_LIST = aktiv, and tick use car phone bt, there is still delay (noticeable when watching a video and not only music, and buttons still doesn’t work)
Thanks
      05-02-2024, 03:14 AM   #13103
justenx
My mistake...the front camera has a time-on option not the rear cam. The front cam comes on for your selected time period (0-15s) after the rear cam if you put the car in drive again after reverse. You can still cancel out of the rear cam anytime with the Menu button, if that was selected.
Not familiar with the OEM 360 cam and how it's implemented in the MMI. I am sure it reads the CANBUS messages and the MMI takes action based on those. Search the forums, or hopefully someone else can address this.
As far as the Pixel. It's painful, but I would start from scratch and remove the Pixel from the car's Bluetooth and also from the MMI's. Then add back in the MMI again first and then to the car. Make sure in the car under Options you select data, audio under the paired phone. Also make sure to give full access in the Pixel settings to the BLE and wifi connections with the car and MMI. When I used Android in the past (use CarPLay now), deep access permissions were not automatic.
Some people toggle between the car and MMI for having full bluetooth control, but primarily affects the audio priority and quality.
The problem with these MMIs is that the firmware is closed and worked on by a few so-called engineers in China. So no way they are able/willing to address issues that their customers (like us) struggle with. I wish the couple of Andream distributor people lurking here, as much as they are trying to be helpful, would pass on to their MMI engineer contacts these common recurring issues.
If the MMI would be an open-source firmware, the public working together would have already fixed the myriad of problems. Just like Firefly1337 and his team did early on when they hacked into and modified/vastly improved on the MMI firmware files.
Many people had good results with changing their MCU files to MCU 21.9.13.122 (note the risks)
MCU firmware updates are a much lower risk than the MMI program firmware updates which seem to be specific to the distributor.
Does it really switch automatically to front camera when you put the car on drive?
For me it’s only after I am driving like 5 meters or get to 5kmh (coded this way and can’t be coded to 0)
      05-02-2024, 03:23 AM   #13104
fe7565
fe7565's Avatar
Without posting details about your MMI, hard to answer anything.
      05-02-2024, 11:48 AM   #13105
menem
Drives: BMW F22 17'
Issue with Andream MMI
Hello,
I have purchased Andream MMI, the NBT version, since I have a HU_ENTRYNAV (NBT system but without NAV). I connected everything as instructed on the forum, however when I switch to AA screen, nothing is shown (black screen). When I switch to BMW menu, it works fine, so I believe I have connected everything correctly. I'm doubting there might be an issue because I have upgraded the basic 6.6 screen to 8.8 one some time ago. However, I have put the dip switch position as for 8.8 screen - 123 to ON. Do you guys have any clue why it does not work?
Thanks
      05-02-2024, 12:10 PM   #13106
BMWChap
Drives: F32
The code should be 5025, but on the first page there is a list of other codes. Read the guide carefully.
The bluetooth gives better audio vs, the AUX-IN analog input, and also groups the various audio inputs into one channel. While with the AUX-IN the MMI often missed phone call audio, navigation instructions, etc.
Setting up the bluetooth audio in the menu is a bit tricky. Should delete all pairings from the MMI first. The two BT channel settings in the menu are a bit tricky to setup as the MMI reboots in a couple of seconds after selecting it and does not give you time to enable the second one. And then that menu selection disappears. So you have to be quick to select both before the MMI reboots.
Some Logic 7 EQ settings, but they may have been using the AUX-IN at that time:
https://f30.bimmerpost.com/forums/sh...ostcount=10823
I have the German ModsUK version
I can confirm the audio sounds terrible via AUX so i'll be switching it back to Bluetooth, interestingly on my BMW E92 2010 CIC I have what appears to be a later CUST version ??
SDK Version: 25.0.0.7.0.0.2.0
CUST Version: EW_CHL_1.6.16R2_n
MCU Version: 21.7.21.117
HW Version: B_CHL_G
Also.. are you able to play Youtube Videos ?, I can log in to my Youtube Account, see all my videos but when I select Play it Loads but never plays, then returns back to the Youtube home page...
I have an Iphone 14 Pro Max with the latest updates..I wonder if this could be the issue as the MCU Version is 2021.
      05-02-2024, 06:51 PM   #13107
fe7565
fe7565's Avatar
Originally Posted by menem View Post
Hello,
Thanks
I would reach out to Andream support first.
Do you have anything showing when NOT in the OEM menu? Or just black screen? Is there "No signal" displayed? Can you hear audio when in MMI screen mode but black?
1. check that all connections and LVDS are firm and seated. Re-seat the quadlock connectors.
2. Make sure DIP switch settings is ON and not OFF (labeling is funky)
3. try different DIP switch settings (search this thread and read first page)
4. LVDS cable(s) maybe backwards (unlikely)
      05-02-2024, 07:16 PM   #13108
fe7565
fe7565's Avatar
HW Version: B_CHL_G
My guess is that it's an Andream type firmware based on the format, but do not know ModsUK...maybe someone else does. Some sellers add protection in their firmware (even if it looks like Andream or Road Top) that may brick the MMI if you do not install their files.
I did not get my YouTube on my Road Top NBT working, because after two tries it failed, and I did not have the patience to figure it out since I only use YouTube at home. Someone else may be able to help you there.
Not sure which iPhone had problems with the MMI....14 or 15? But it was not a YouTube issue, if I remember correctly.
      05-02-2024, 07:26 PM   #13109
fe7565
fe7565's Avatar
Some notes for anyone who may later run into the same issues:
I had an NBT emulator. Depending if you installed the emulator before the MMI, or between the MMI and the HU....it could block CAN messages. My MMI was not able to detect the reverse cam CAN message when installed it on the KCAN2 car bus between the MMI and NBT HU. MMI => Emulator => NBT HU. I had to use the manual sensing wire connected to the backup light. So should connect like this: Emulator => MMI => NBT HU (tap emulator into MMI harness) When I removed the NBT emulator (not needing it) after using full set of after-market FSC codes....the MMI was able to receive that CAN message.
Another issue. If your CID in MMI-mode goes intermittently black (not the "No Signal", just a blank CID) while driving, one of your LVDS cables may have a break in it. It connects and disconnects seemingly randomly, but mostly when the car is in motion as the wire inside is cracked.
      05-03-2024, 01:37 AM   #13110
menem
Drives: BMW F22 17'
Thank you for your reply, I have contacted the Andream support and I am waiting for the response, here is some more information.
When I switch to MMI screen/mode, nothing is shown, just black screen.
I did not try to connect to AA yet, because I do not see even the basic MMI menu, so when I switch to MMI screen I can hear audio source that is currently selected in OEM headunit (BMW bluetooth, radio).
1. I re checked LVDS connection, that was my first guess, even tried switching LVDS cables in following way:
HU -> original LVDS -> MMI -> new LVDS cable -> screen
vs
HU -> new LVDS cable -> MMI -> original LVDS -> screen
this did not help
As for the quadlocks, I could try re-seating them, but if this was an issue wouldn't there also be problem with OEM menu and functionality?
2. I have double checked it, arrow is pointing down for ON, so I've put 123 down, could it be reverse ?
3. I've read first 10ish pages, seems that 123 should be the only correct combination? What else did you had in mind?
4. What do you mean by backwards (see my answer in 1.) I this even possible ?
      05-03-2024, 01:53 AM   #13111
fe7565
fe7565's Avatar
vs
this did not help
You have done everything I would have done.
My guess is either DIP switch setting....
or.....LVDS cable pin orientation is off by 90 degrees or 180 degrees. First check if you have power going to your 4+2 (6 pin) connector's red wire and check the black/brown? if you have ground. Do for both LVDS cables. Possible that your positive and negative are switched. If you get power to your CID, you should get an orange "No Signal" displayed. So looks like your CID is not getting power. Either missing power from the HU to the MMI or missing from the MMI to the CID...or both.
If the 2 power wires were switched around, your 4 data pins maybe also switched.
If that's the case...you can ask the seller to send you the correct cable. Or carefully pull out the two pins (pos and neg) and swap them. Or cut the the pos/neg power cables and swap them. Do not cut any of the 4 data (video signal) cables as they are RF protected.
You have APIX1 CID?
      05-03-2024, 02:22 AM   #13112
menem
Drives: BMW F22 17'
You have APIX1 CID?
I would also assume the dip switch combination is the problem, because you can not connect LVDS either 90 or 180 degrees off, the connector itself is keyed, also the +2 pins can only go one way.
What is the other possible DIP combination I should try?
Also, as mentioned earlier, the OEM menu is shown correctly, wouldn't this also be affected if LVDS cables were wrongly connected?
What is APIX1 CID ? I have upgraded to Alpine AL3011 8.8 CID - 9387453024 OEM number
andream, android, android auto, apple, carplay, mmi, retrofit
