01-11-2024, 01:56 PM | #1 |
Rep 15
Tension strut bushings replacement
Hi Everybody,
I have a 435i xdrive with 81K miles. Just did an oil change at the BMW dealership and they noticed a leaking front control arm (aka tension strut) bushing and recommended replacing both bushings. The interesting thing is that their quote was only $154 for both sides, labor, parts and tax included! I mean, they are replacing the bushings only, not the entire control arms. Given that these parts (Lemforder) with preinstalled bushings are around $85 + tax at FCPEuro, I am wondering, is this a good idea to change just the bushings, instead of buying the whole control arm and sweating changing it myself? Any thoughts/recommendations would be greatly appreciated. Thanks, Dobrin |
01-11-2024, 06:07 PM | #2 |
155
Rep 131
Drives: 2018 BMW 330iX Sedan
01-11-2024, 09:09 PM | #3 |
Rep 3,954
Just replace the entire control arm with Lemforder parts.
You'll get a new ball joint as well. |
alohasurftoad3124.00 Dobrin1.50 |
01-12-2024, 03:34 PM | #4 | |
Rep 15
The other idea about upgrading the suspension is very tempting. I have a 335i xDrive and a 435i xDrive, and I honestly think their suspensions are horrible (at least a bit of relief is that the 435 has the adaptive one). To me BMW not offering the sports version suspension on these cars is a deliberate act of evil to make people buy the M series. However, these aftermarket control arms are quite expensive and moreover they are difficult to find (for example, the VAC monoball control arms are out of stock). Anyway, thanks both of your replies for your input and valuable suggestions! |
01-15-2024, 08:30 PM | #5 |
37
Rep 90
My OEM hydrobushings started to leak at around 90k miles.
For the hell of it, I had my dealer quote me to replace those bushings: $950 I ended up buying Myle HD arms and replacing them in my driveway. I don't need monoball components, so the HD pieces appealed to me since they're just rubber bushings -- not hydrobushings like OEM. It wasn't hard at all and if you can do your own oil change, you can absolutely do these. https://www.fcpeuro.com/products/bmw...hd-31126854723 https://www.fcpeuro.com/products/bmw...hd-31126854724 If you're x-drive, the front axle has to come out of the hub for clearance. The axle bolts are one-time use, so replace them as well. https://www.fcpeuro.com/products/bmw...-31206795249kt FCP has a video that covers it pretty well: https://blog.fcpeuro.com/how-to-repl...t-control-arms
Bootmod3 | BMS intake | Dinan springs and swaybars
01-16-2024, 08:32 AM | #6 |
Rep 522
Millway and Turner are other monoball options like VAC.
They make a huge difference in steering input. I love them and wish they came stock
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
01-18-2024, 01:47 PM | #7 | |
Rep 15
About the aftermarket monoballs: I would have chosen them if it wasn't for their price. I am sure it will improve handling, but I can live with the soft suspension since this is actually my commuter car. Thank you all for your input! |
01-19-2024, 01:59 PM | #8 |
37
Rep 90
Hopefully you won't have issues with axles seized up in your hubs. I'm not quite NE, but my car's been in VA/MD its whole life and, thankfully, mine came right out.
The Myle HDs have been good to me for a year now. Just a slight increase in road noise, but nothing that has been noticeable to passengers. Steering feels a bit more responsive.
01-25-2024, 08:06 AM | #9 |
Rep 494
Just FYI I believe TRW is the OE. Not that Lemforder isn’t a reputable brand.
But also, if $154 is their price for everything I don’t see why you wouldn’t just let them do it. You save a small amount of money and your time. You would miss out on a new ball joint but afaik that part of the control arm doesn’t typically wear out on the same interval as the bushing. They didn’t recommend an alignment after replacing the control arm bushing?
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
01-25-2024, 03:43 PM | #10 |
37
Rep 90
You don't need an alignment for just a tension strut replacement.
01-26-2024, 05:15 PM | #11 | ||
Rep 787
And yes, they also say that an alignment is required after the tension strut is removed. Somewhere on here is a bmw document that lists which jobs require wheel alignment afterwards and tension strut is on that list
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
bushing, control arm, tension strut |
