BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > M140i - Weird issue - PLEASE HELP!
      04-23-2024, 01:21 PM   #1
AndyM340i
Drives: G20 M340i,F20 M140i, E31 840ci
Hi Guys,
I have a 2018 M140i running a BM3 Stage 2 OTS map with the correct supporting mods - MST induction, downpipes and uprated HPFP (TU). The car has been running this spec for 6-months and has done a ring trip - no issues. A week or so ago the car developed a fault where it would not start. Fault traced to faulty fuse box (in boot). Fusebox replaced and car starts fine.
Now I have a weird issue...
At high RPM (normally 4th/5th gear, about 5k RPM) the fuel rail pressure crashes and I lose power. After the loss of pressure (measured using a live graph on my Autel) the car runs okay and then I lose all power (usually after 1-2miles after pressure crash) - accelerator does nothing. I pull over and idle is perfect, but the car will not do more than 5mph and its very jerky as if it cannot get enough fuel. I cycle the ignition and then its fine...until I try and use full power again.
When the rail crashes the EML light does not come on. I scanned immediately following the issue and the codes are:
213901 - Power management: reduction or shutdown of individual electrical consumer.
8040B9 - De-activation of terminal 30B: Top startability reached.
8040BD - Reset of deactivation of terminal 30F.
I only saw these codes today as I have not had my diagnostics with me on previous occasions. I have chaged: EPKM, LPFP, Fusebox (due to previous starting issue). HPFP is purely mechanical, driven by the camshaft, so I do not believe that is at fault.
I'm stuck - any ideas?
