Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Which Flywheel for FBO car DMF or SMF?
      09-27-2013, 06:38 AM   #1
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Question Which Flywheel for FBO car DMF or SMF?
Hey there
My clutch is going to the end, mostly I drive in the city I decided to go with SPEC stage2+ clutch kit as it is good for FBO power levels and still comfy on the street/traffic.
Now my question which FLYWHEEL single mass oem or dual mass stainless steel?
Please advice me which version to choose will oem flywheel is ok for 350-400whp or it will fail again?
Anybody did single mass share your experience. how noisy it is?
Thanks
      09-27-2013, 09:14 AM   #2
cwarren
cwarren's Avatar
82
Drives: 08 e92
go with oem dmfw if your going to keep torque limit under say 450-475 ish
anything higher and you might want to consider a steel smfw from spec.
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
      09-27-2013, 04:56 PM   #3
rolando316
Drives: 2007 BMW 335i E92
Also curious to hearing this as I'm in the same situation. That 450-475 torque seems to be right at the border between what a FBO + e85 (which is my setup) would be at, and what an upgraded turbo setup could produce.
2007 335i E92 Space Gray 6MT | COBB PTF e50 | BMS DCI | VRSF 5" Intercooler | VRSF Downpipes | Walbro Inline 255 | Spec Stg 2+ | SM Steel Flywheel | ST V1 Coilovers | M3 Front Contol Bits | Linea Corse LM 19" | 245/275 Michelin PSS | M3 Front | M3 Side Skirts | MTech Rear | LCI Tails-Euro | JL 12w3v3
      09-27-2013, 08:30 PM   #4
PGZ11
Drives: 335XI
reused my stock flywheel with this clutch. seems good for FBO e30-40%. have not gone any higher than that yet ..
      09-27-2013, 09:14 PM   #5
rdeterman
rdeterman's Avatar
Drives: 2008 335i Coupe 6mt
SMFW if you planning on making any more power... which im sure if your planning on spending 2k on clutch/flywheel and install you are
JB4 G5 ISO W/BMS FLASH, FBO, Walbro LPFP, Spec S2+ SMFW
      09-27-2013, 09:38 PM   #6
Presidio335xi
Drives: 335xi coupe
Originally Posted by RimasRS
Hey there
Thanks
Remember the misfires caused at high rpms for Rb and singles with DMFW.
Lighten SM flywheel is a lot lighter and feels great. Just be prepared for ChATTEr
2017 F82
      09-29-2013, 02:39 AM   #7
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Thanks guys really appreciate
For now I am thinking to leave stock turbos because still I want to do meth and exhaust but after that I dont know will I stop... In the beginning I thought I will do just tune + fmic but you only finish moding when you sell the car
Anyway I think I will stay with DMF even though mine is dead and I need a new one. I would hate to drive slowly in the city and people would look at you thinking WTF is wrong with your car...
      09-29-2013, 03:50 AM   #8
bmwm3redblack
bmwm3redblack's Avatar
59
Drives: BMW ///M3 E46, BMW E92 335Xi
Fotr how much is sm lighter than DM???
Is it really crucialy beneficical???
Bmw 335xi/FBO/ black on black/ 6sp manual/Cobb AP/BMS DCI/AA BOV KIT/VRSF DP'S/VRSF 7'FMIC /FULLY CATLESS/H&R sport springs/ 19' ac schnitzer wheels.
      09-29-2013, 08:48 AM   #9
3000GT MR
3000GT MR's Avatar
Drives: 09 335i/3000gt vr4
I'd go with a SM steel. I have that with a stg 3+ no issues. Doesn't really chatter that much.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust
335i 2009 e90 665RWHP VFF900 ST RIP .
      09-29-2013, 09:42 AM   #10
joec500
Drives: it has 4 wheels
I re-used my DMFW with my Horepower Freaks Stage 1 clutch without any issues and I am doing 460+ WHP and 533 WTQ. I just resurfaced it. I wanted to maintain stock driveablity as possible. No issues with here.
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
      09-29-2013, 10:13 AM   #11
cwarren
cwarren's Avatar
82
Drives: 08 e92
how long have you been running this set up ? I have the dmfw (new) and the stage 2+on its way .running 440/505 and was thinking im pushing it ! but im in the same boat as others chatter is not an option .
either way obviously is not changing my mind but would love to hear how its held up for you.
      09-29-2013, 11:41 AM   #12
G.I.Joe
G.I.Joe's Avatar
Denmark
30
Drives: E92 335i 2008
That's what I did (with a HPF Stage 2 clutch) for about 15k miles. Thought I had no issues. And I'm running RB turbos on a E50 mix with 500+ WHP.
However 2 months ago the stock DMFW completely disintegrated while doing a full throttle 6th gear acceleration @ 120+ mph, and it almost destroyed my transmission and my crank shaft at the same time as well. Had to have repairs made to the gear box. The HPF Stage 2 clutch however survived. My original DMFW had about 85k miles on it when it happened.
I now run a SPEC stage 3+ clutch and a SPEC steel SMFW, and after breaking it in I can certainly say that this is what I should have done in the first place. So much easier to launch the car properly every time, and chatter isn't really anything to worry about IMO. Everyday driveability isn't really an issue either, not for me at least.
In retrospect I had way too many concerns about going for a SMFW solution in the first place, the SPEC combo really works great. Of course I have only used it for 2k miles yet, but many others have used it for a long time without issues.
E92 335i 2008 Space Grey 6MT | Pure Stage 2 turbos | Motiv PI | Trueform Tech Intake | Quaife LSD | M3 Suspension kit | Öhlins Road & Track Coilover | DEFIVfab N54 diff lockdown kit | COBB PTF E85 Map | Fuel-It Stage 3 LPFP | NGK 5992 plugs | Wagner FMIC | Wagner 3" DP | Milltek exhaust | Tial BOV | SPEC Stage 3+ clutch | SPEC Steel SM Flywheel |
      09-29-2013, 12:10 PM   #13
Dmacc
200
Drives: 2011 BMW 1M
+1 for spec steel smfw
thanks to MGallop
      09-29-2013, 12:57 PM   #14
Ovitrix335
Ovitrix335's Avatar
Drives: Bmw 335i
I have 13k miles on my spec stg3+ with spec steel flywheel and i can say the clutch takes all the abuse i throw at it. The steel flywheel is chattery especially with the ac on, and it's very grabby. If you don't mind the chatter you'll love the spec combo....
      09-30-2013, 04:30 AM   #15
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Well some people report really loud chatter. Really again it confuses me..
How long you have this setup?
Damn that should be scary. So it broke in two parts? How did you repaired your box where did you get new parts for it?
I know that going 500whp+ would really be better to go SMF but for me not really sure.
Would like to hear in person how loud is the chatter. And what about real feeling in the car is it like a truck almost I mean how would you rate from 1-10 points comparing with stock setup
Noise 1-10
Vibrations 1-10
Pedal smoothness 1-10
      09-30-2013, 01:39 PM   #16
G.I.Joe
G.I.Joe's Avatar
Denmark
30
It was quite scary, I was pulling on a M6 Grand Coupe at the time (for the 4th time) going through Germany. The flywheel broke in about 20 parts, so when I say disintegrated, it really was like that....
I had my local shop do all the repairs, they had to dismantle another gear box to get the parts.
Noise 1-10
Vibrations 1-10
Chatter is only present when you have the MT in neutral and the clutch is released. Press down the clutch and there is nothing. Idle is super smooth, only a little more vibration during acceleration (almost like when adding E85 and the engine runs a little more roughly), it revs faster (it really can be noticed), and the pedal feel is smooth, you need a little more throttle than with the DMFW, but pedal pressure is less than with my HPF Stage 2 clutch and the stock DMFW.
If anyone near you runs a SPEC Stage 3+ (or 2+) with a steel SMFW you should ask for a ride/drive.
      09-30-2013, 01:47 PM   #17
09BMW335i
09BMW335i's Avatar
29
Drives: 2009 335i
Agree
i have a Spec 3+ clutch and a SMFW and Love it
09 335i Sport --MHD (Tune by Wedge )--Inlet System by Trueform Technologies --Tial BOV--Macht Schnell Catless Downpipes--AMS FMIC--Walbro 455 LPFP--HPF Gen2 Exhaust--SPEC Stage 3+ clutch / billet steel flywheel--
      09-30-2013, 08:49 PM   #18
Presidio335xi
Drives: 335xi coupe
Noise 1-10
Vibrations 1-10
1 being stock
Noise - 7-8 with AC on / 4-5 AC off (but understand it is only when in neutral at a light or stop sign. My wife and mom both thought something was wrong with my car when they first heard it FWIW. Consider a 10 the worse waste gate rattle you have ever heard.
Vibrations 3-4 (reverse and 1st gear in the morning, not once warmed up then 1-2) Needs more throttle to engage but you will learn to like it better, especially when being aggressive/launching
Pedal Smoothness - 2 shorter engagement point near the top the peddle. It is quite firmer than stock but nothing major and again you will get use to it.
I will also add you will notice the steel SMFW will rev quicker and drop quicker in between shifts, thus allowing quicker shifts.
2017 F82
      10-01-2013, 08:42 AM   #19
bmwm3redblack
59
Originally Posted by 09BMW335i View Post
Agree
Is it a great difference in noise and comfort,cnmpare stage2 to stage3+???
Or all spec products are noisy??
      10-01-2013, 10:08 AM   #20
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
500+ WHP SMFW
Anything less should be able to get away with the DMFW.
We recommend a new OEM DMFW as historically we've seen many horror stories of the DMFW not being resurfaced correctly.
As mentioned above the SMFW will have some chatter. If you opt for a DMFW and make in excess of 500WHP+ there is potential for your vehicle to throw misfires codes.
Well sell many spec clutches a week. If you have any questions I'd be happy to answer them.
You should choose a clutch based on your torque. Not what others are running.
      10-01-2013, 10:39 AM   #21
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Originally Posted by Jeff@TopGearSolutions View Post
500+ WHP SMFW
Thanks Jeff helpful as always... So in easy words everything before RB or Vargas I mean turbo upgrades should hold with DMF. How about FBO protune + meth?
What else should I know do when replacing clutch and flywheel?
Any tips?
      10-01-2013, 11:30 AM   #22
bmwm3redblack
59
500+ WHP SMFW
So jeff i'm in the same boat,cause my flywheel ticking after 2-3 launches,so i think that it needs replacement soon.
I'm 335xi FBO +e85, what route to go?
clutch, dmf, flywheel, spec
