02-03-2013, 02:23 AM | #1 |
13
Rep 226
Turbo kick @ 2500 RPM
Hi Guys,
Please forgive the noob questions. I am new to these turbo BMs. I test drove my first 135i today and noticed the car was not as smooth as I expected when accelerating. The car is a 2008 model with @ 50,000 kms. It seemed to me that around 2500 the turbos kick in noticeably. The car did not seem to be down on power or anything but it was not a smooth build up of power as the revs rose. Is this normal? Or does it need tuning? Please forgive my ignorance but I've not driven a lot of 6 cylinder turbos. I was expecting a power deliver similar to a normally aspirated engine? Thanks in advance. |
02-03-2013, 02:30 AM | #2 | |
Rep 2,934
02-03-2013, 03:02 AM | #3 |
Rep 3,093
LOL at pavo.....meth
I bet the seller has a piggy back tune already on the car so it could be running around 13-14psi compared to the stock 8psi. These cars have a lot of torque especially when running a little more boost. Power does come on quite strong when the turbos spool up. |
02-03-2013, 03:03 AM | #4 |
piggy in the mirror
47
Rep 595
I have driven three of these cars and all three felt different, I'll be driving a forth next month with PPK so I'm guessing it will feel different again.
135i Coupe N55 PPK+JB4
X3 30d LCI |
02-03-2013, 03:12 AM | #5 | |
Rep 4,848
I had a ESS tune which gives a much more linear delivery of power. I suspect the example you were driving has a tune and not tuned very well.
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
02-03-2013, 03:30 AM | #7 |
13
Rep 226
02-03-2013, 04:23 AM | #8 | |
13
Rep 226
I read somewhere that BMW USA was flashing the N54 ECUs with some weird tune which introduced more lag to add to the longevity of the HPFP, could this be the case here? Last edited by racer_x; 02-03-2013 at 04:55 AM.. |
02-03-2013, 05:22 AM | #9 | |
European Editor
10622
Rep 22,992
Dack
02-03-2013, 06:48 AM | #11 |
234
Rep 2,643
My N55 has very smooth torque delivery. Torque feels like it gradually builds to 2000RPM and pretty constant for most of the rev range. It certainly isn't missing any bottom end torque. To me the top-end feels a bit of a disappointment by comparison.
02-03-2013, 08:29 AM | #12 |
Rep 1,293
If the car is not tuned, I think Dack is spot on. BMW's updated software flash introduced some serious lag below 2200-2500 rpm. In order to get the same response as before, you would need to double your throttle inputs. The PPK corrects this issue and gives you a very linear torque curve and immediate throttle response. The PPK is not the most powerful tune but power delivery is very predictable.
02-03-2013, 08:07 PM | #13 | |
Rep 1,364
02-03-2013, 08:18 PM | #14 |
Rep 1,293
I'm not sure. Every car seems to respond a little different. A number of people have mentioned that both the Cobb and JB4 tend to surge a bit when the boost dials up. Some people claim that they don't experience any surge. That being said, the stage 2 Dinan and GIAC tunes seem to get the best reviews when it comes to smooth power delivery but they are not cheap and require a dealer to flash the ECU.
02-03-2013, 08:37 PM | #15 |
Lord Captain Commander
110
Rep 3,093
Any sort of tune that increases your power substantially should result in more 'surge' as you describe. This is simply because the turbos will take a bit longer to reach the higher boost level.
E82 135i M-sport: SGM/6MT/Black |
02-06-2013, 04:13 AM | #16 |
13
Rep 226
I drove an 09 model (stock, no mods) tonight and it was noticeably smoother. The seller tells me that the HPFP and the injectors were replaced as a precaution under warranty. He was not sure if they upgraded the ECU firmware or not.
