BMW X3 Forum
BMW X3 Forum
      12-08-2021, 03:56 PM   #1
usedtobecool
Drives: Mazda 3
CIC software (Multimedia/telephone) update
Hi, I just picked up a 2012 Xdrive28i from a neighbor and am trying to get as many things as I can up to date on it (software-wise, car seems mechanically great).
I have a CIC with Navigation system professional with these current software revisions:
Multimedia: MX-003.004.031
Telephone: TX-003.004.031
I couldn't find updates to them anywhere. BMW's own site just says "An error has occurred. Please try again later." when I type in my VIN. If anyone has updated files they can share, please let me know!
Also, navigation updates or any others I can perform myself, please share! Thanks in advance!
      12-08-2021, 05:52 PM   #2
pungo
pungo's Avatar
Drives: Z4MC-X3-35i-525i, Corrado G60
I have a 2011 and upgraded mine with UPD01008.bin downloaded from BMW a while ago. I get the same error as you when I check for updates now.
Attached pdf has the version info.
Readme_UPD01008_ENG.pdf
Here's the binary, remove .pdf from the filename.
UPD01008.bin.pdf
Besides a newer map, you can do some coding to change some of the characteristics of the vehicle.
Appreciate 3
      12-09-2021, 11:59 AM   #3
usedtobecool
Drives: Mazda 3
Attachment 2761157
Attachment 2761160
Awesome! Thank you so much for posting this! I wonder if this was the end of the line for updates. I haven't seen anything mentioned about any newer revision. Hopefully this will improve the bluetooth connection a bit. Thanks again!
      12-09-2021, 04:50 PM   #4
pungo
pungo's Avatar
No problem...I'm guessing the last firmware update for CIC was in 2014 since the pdf has a timestamp of 2014 as well as the last phone listed is a iphone 5 & galaxy 4. I pulled the file from BMW in early 2019.
      12-24-2021, 11:49 PM   #5
brianhinton77
90
Drives: 2011 X3 28i, 2016 X5 M-Sport
Attachment 2761157
Attachment 2761160
How did you update the .bin? Just put it on a usb stick and put it in the glovebox usb connection? Thanks!
      12-31-2021, 01:19 PM   #6
GORDON.M3
GORDON.M3's Avatar
1423
Drives: E92 M3 • F25 X3 M-Sport
drag the bin file to an empty USB drive, plug it in and wait till the car settles after starting up about 2-3 mins.
Then go into settings and click on software update, the USB should be plugged into the car prior to starting the car. It will detect the update and it should load the new software to the car. Takes about 2-3 mins max.
This is not a head-unit update but a combox update to support newer phones and fix some bluetooth glitches.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI
      01-01-2022, 06:42 PM   #7
brianhinton77
90
Attachment 2761157
Attachment 2761160
Can you please let me know your steps? I have tried this and can't get it to work. Here's what I have done:
Formatted USB to FAT32
Drag the file you posted from downloads to the USB drive.
Changed the .bin.pdf to just .bin
put the USB in the glovebox, waited until Software update screen asked to update via Teleservice or USB
Chose USB
Idrive stated the was no software on the usb
After this, I thought about when I updated my maps....the file you posted is compressed when I downloaded it....so now, I take the USB back inside and extract the files to the root of the USB. Took it back out to the X3 and exactly the same thing as before....no update
EDIT: I downloaded again ….didn’t do anything too the file except take off .pdf……update can only be done via the armrest USB…that’s where i was messing up…I was inserting into glovebox
      01-01-2022, 09:23 PM   #8
GORDON.M3
GORDON.M3's Avatar
1423
Chose USB
Glovebox USB is for the Map/Navigation Updates.
Armrest USB is for the BMW Software Update. It says on the update page to use the armrest audio USB for update.
      06-02-2022, 11:26 AM   #9
Schnell19
Drives: BMW X3 F25 2012 20xdrive
Thanks heaps for the update mate! I have a 2012 X3 and have been looking for a while how to get the software update as the official BMW site doesn't work anymore.
My main issue was my bluetooth songs just showing as unknown and since the update that is no longer the case so thanks heaps for that!
      06-09-2022, 03:37 AM   #10
MPDev
Drives: BMW X3 (F25)
X3 f25 2011 - navigation maps update
Morning All,
Can any of you advise if it's possible to update my maps for the above vehicle please? Thanks
      07-19-2022, 09:37 PM   #11
alekseyk
Drives: BMW x3 F25
Is there any way to modify this *.bin uodate file, to make custom changes, like disable Auto Start/stop and etc.?
      07-19-2022, 11:29 PM   #12
pungo
pungo's Avatar
Even if you could modify the .bin file (which you can't without the source code and proper compiler) it has nothing to do with the auto start/stop Use e-sys to disable it.
      07-20-2022, 12:43 AM   #13
ardie7
Drives: 320D E90 & X3 F25
Alternatively, besides pungo's suggestion, you could also code this function on/off using Bimmercode if you're not quite comfortable enough to run E-sys (I'm still new to the BMW coding ecosystem myself and decided to stick to Bimmercode until I learn a bit more about E-sys)
      03-10-2023, 09:28 AM   #14
steaman
steaman's Avatar
Drives: i3S - 2019 X3 3.0d F25 - 2011
Hi, I bought a X3 F25 2011 in december with the original maps.
I have tried to upgraded the CIC with UPD01008.bin method described above without sucess. I used a FAT32/32GB USB in the armrest but nothing happens. I have also tried with a number of other USBs with the same result.
I know that BMW is USB sensitive and wonder if it is any specific brand that is known to work?
      03-10-2023, 09:21 PM   #15
GORDON.M3
GORDON.M3's Avatar
1423
First it's not the armrest, its the glovebox USB port.
Second, you must go into the car settings menu and click on Software Update.
      03-11-2023, 07:26 AM   #16
steaman
steaman's Avatar
My first task is to update the Combox. The secont will be the Maps.
In your Post #8 you state:
I have tried both USB connectors without success. I forgot to mention that i also used the SW update menu.
I think I've tried all the variations:
  • Start the Navigator first and then insert the USB
  • Plug in the USB and then Start the Navigator
  • I have done this in both the armrest and the glove compartment.
  • But nothing works.
Any more options? Could it be something wrong with the combox? Is it possible to retrofit a later Combox version?
      03-12-2023, 01:25 PM   #17
brianhinton77
90
We’re you sure to delete the .bin off of the file?
      03-12-2023, 02:03 PM   #18
steaman
steaman's Avatar
I have done as described above: Change the .bin.pdf to just .bin
      03-25-2023, 04:31 PM   #19
Sandorr82
Drives: BMW 530
Hello all also have issue with update,thats my first post here
I have problem with change name this file.
When I download this file is show name with nopdf on it but still my car not see that
      03-30-2023, 02:25 PM   #20
steaman
steaman's Avatar
Same situation here. I have tried a number of USB sticks according to recommendations without success.
It is the Combox that is supposed to detect the UPD01008.bin file on the USB stick.
I bought a used Combox on Ebay that is produced 2 years latar than my existing one and hopefully it will solve the upgrade.
      03-30-2023, 03:36 PM   #21
pungo
pungo's Avatar
You probably have "show filename extensions" turned off
      04-01-2023, 02:36 AM   #22
steaman
steaman's Avatar
This is from the owners manual belonging to my X3 F25 2011:
Update software via USB.
Updating may only be done when the car is stationary.
  1. Save the file with the updated software in the main folder of a USB stick.
  2. Connect the USB stick to the USB audio interface in the center armrest. It is not possible to update the software via the USB interface in glove compartment.
xbimmers
