ARMA SPEED
      03-21-2024, 09:05 AM   #1
xBenCookx
xBenCookx's Avatar
Drives: 2015 BMW M4
CCBs question
Good morning all,
I’m sure this has been asked a million times, but I’m new to this thread and still slightly new to BMW (always been in LS cars). I recently got a 2015 M4 that came with CCBs, and I have seen on this forum and other places that I don’t really have to worry about changing them for a long time (car has 50k miles) unless I track or crack them, but Ive had shops tell me I need to replace them in the next year or so. Is there anyway for me to know when they need to be replaced? I seriously doubt if they normally last 150k plus miles that I already need to replace them. Thanks!
      03-21-2024, 09:34 AM   #2
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
hello
There are three circles, or wear indicators, on each rotor to help determine when the rotors are fried.
Unless you or the prior owners tracked the car, the rotors will last insanely long. I would look for different shops, these seem to just want to charge you tons of money for nothing.
      03-21-2024, 09:42 AM   #3
xBenCookx
xBenCookx's Avatar
Drives: 2015 BMW M4
Originally Posted by SYT_Shadow View Post
hello
Thanks for the info!
      03-21-2024, 09:53 AM   #4
Taylorsherk
183
Drives: 2017 M3 ZCP
i thought each rotor has a min weight printed on it and you can weight them to determine how much life is left as well.
      03-21-2024, 10:15 AM   #5
Yuille36
Yuille36's Avatar
Drives: BMW X5M, BMW M3, MB E63 AMG
2015 BMW X5M  [0.00]
Either method will work.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
      03-21-2024, 11:59 AM   #6
andrewmr
449
Drives: 2020 M4
The first thing I would do is ask the shop how they determined that the rotors need to be replaced. From their answer you can determine if you need to find a different place to have your car serviced.
Appreciate 3
SYT_Shadow11490.00
RickFLM410981.00
      03-21-2024, 01:09 PM   #7
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
To replace Carbon Ceramic Brakes will put a major and I mean major dent in your wallet. I called my local BMW Dealership and ask them what is the price for new rotors and pads, and they quoted me $17,500 This is when I was looking at and considering buying a M3 that had these brakes on it.
Although, I ended up going with steel rotors, as I'm not tracking my car. I did discover in my search that Turner Motorsports, does offer steel replacement rotors and pads, if you decide to convert from CCB's to steels. After looking at that price tag, I understand why some owner would go this route. These rotors are the same exact size as the CCB's, so for just a set of steel rotors will set you back about $1700 not counting pads.
I think that this is a great option, unless you want to take out a mortgage to pay for a new set of Carbon Ceramic Rotors. I've contemplated going with the 6 piston front calipers and the 4 piston rears, but after driving my M3 for the last few months, I determined that this car has enough braking power for the speeds that I drive. Maybe if I were to track it, I might feel differently about it. But you can always go with a dedicated track pad.
      03-21-2024, 02:12 PM   #8
WhiteFox
WhiteFox's Avatar
108
Drives: BMW M4 F83
There will be a circular wear indicator on the discs if these are chipped then the discs will need to be replaced soon if the carbon material is fully gone then they are finished usually.
If used on everyday driving 100k on them will not be an issue. They usually breakdown fairly quickly if tracking the car a fair bit.
      03-21-2024, 06:19 PM   #9
Monkey Throttle
263
Drives: F80 comp 6MT, 993 C2S
I once had a tire shop tell they couldn't patch a tire and I had the wrong tires on my car and they should all be changed.
I said, "Not every Porsche owner is a dumb fuck... Get my car off your lift immediately."
Limped to my regular tire shop. They patched my tire immediately and sent me on my way.
Appreciate 3
      03-21-2024, 06:29 PM   #10
RickFLM4
RickFLM4's Avatar
Drives: M4
Are you the second owner and know the first owner never tracked the car? One reason an owner might want to get rid of a car with CCBs is because they know it will need them replaced. I agree with most of the sentiments in this thread about a shop not knowing what they are talking about or trying to rip you off, but I’d follow through on checking them out as I think you intend to do, especially if you’ve had multiple shops tell you.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      03-21-2024, 06:31 PM   #11
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
One of the pitfalls of CCB's is that the surface of the brake rotors, are so delicate if you let your wheel hit the rotor when changing tires or you go off road during a Track Day and gravel or even small rocks hit and chip the rotor it must be replaced at great expense. That was a key decision maker for me, when I bought my M3.
      03-21-2024, 08:39 PM   #12
Blocke
317
Drives: 2015 AY M3
To properly determine if they need to be replaced, you have to weigh them. Proper weight requires cleaning them, there’s a whole procedure to it. Unless the shop used a Carboteq to diagnose them, they are going off visual inspection which doesn’t tell the whole story. I’d find a new shop.
      03-22-2024, 12:20 PM   #13
Samo6556
131
Drives: 09 BMW M3
CCB can be refursbished as well from some 3rd party vendors
      03-22-2024, 01:15 PM   #14
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
I just did some research and it does appear like a viable option. You will still end up paying about $6,000 US. This is about the price of one front rotor.
There is a company called "Rebrake Ceramic Brake Remanufacturing" in Munich Germany, has perfected a process by which your carbon ceramic rotors are placed in a crucible and heated to 1,100 degrees Celsius, then add carbon fibers, carbon and ceramic polymers are concentrated on the top layer of the ceramic brake disc.
Even if this layer is just a millimeter thick, it’s still very resistant to heat and abrasion. The ceramic brake discs with larger diameters are understandably more expensive to restore than smaller discs.
It is somewhat cheaper to resurface CCM discs from Aston Martins, Corvettes, Ferraris, Maserati's, McLarens and Nissans than the CCB brake discs used by Audi, Bentley, BMW, Lamborghini and Porsche. Depending on diameter, prices range from 1,050 EUR to 1,350 EUR plus VAT. Rebrake provides a 12-month guarantee for all resurfaced ceramic brake discs.
      03-22-2024, 01:19 PM   #15
xBenCookx
xBenCookx's Avatar
Drives: 2015 BMW M4
Originally Posted by Yuille36 View Post
I just did some research and it does appear viable. It appears to be a cheaper solution, then just replacing the entire rotor. But it isn't cheap.
I wonder if anyone in this forum has done this. It seems way smarter than getting new brakes if I’m understanding correctly.
      03-22-2024, 01:22 PM   #16
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
The cost of refurbishing four rotors equal about $6,000 and that is the cost of replacing front rotors from BMW.
      03-22-2024, 01:22 PM   #17
xBenCookx
xBenCookx's Avatar
Drives: 2015 BMW M4
Wanting to save up for a crankhub upgrade but 3-4K ain’t it rn lol
      03-22-2024, 01:23 PM   #18
xBenCookx
xBenCookx's Avatar
Drives: 2015 BMW M4
Hmmm okay well that’s nice to know. Definitely going to look into that IF I ever have to replace them but I seriously doubt it since I just passed 50k miles and never track it
      03-22-2024, 01:27 PM   #19
SYT_Shadow
SYT_Shadow's Avatar
11490
for sure Rebrake is an option, but the likelihood that OP needs this is pretty much zero
      03-22-2024, 01:36 PM   #20
Yuille36
Yuille36's Avatar
2015 BMW X5M  [0.00]
This was a major decision point for me, and that is why I choose steel rotors over CCB's. This will probably be your most expensive consumable for your vehicle. But Turner Motorsports sales a steel rotors to replace your CCB's. Same overall diameter and thickness, I believe 400 x 30 mm for about $1600 excluding pads.
      04-14-2024, 02:33 AM   #21
Cowsgomoo1284
Cowsgomoo1284's Avatar
27
Drives: 2016 M3 6mt
2016 F80 M3  [0.00]
Local bmw shop told me I needed new pads and rotors (non ccb). Declined and said I’d do it myself but I took their word for it and ordered everything.
Started replacing them and they had probably 75% left on the pads and no lip whatsoever on the rotors. Looks like they’re pulling the same thing on you
      04-16-2024, 03:54 PM   #22
f80fan
15
Drives: F80
BMW M Carbon Ceramic Brakes (CCB) - service PDF...
https://f80.bimmerpost.com/forums/sh....php?t=1115439
f80post
