Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Turner motor sports short shift kit
      03-18-2024, 06:35 PM   #1
domain007
21
Drives: 2010 335i X-drive
I have a question for y'all. Has anyone installed the Turner motor sports short shift kit alongside the bushing refresh kit in your 335xi? If so, which shift joint did you get with your kit? My kit came with the straight joint. There's a bit of conflicting info if the straight shift joint will hit the transfer case vs the offset shift joint.
Edit: car is a 2010 E92 335xi n54
      03-19-2024, 11:15 PM   #2
apexxx6789
Drives: 335XI
Which kit did u get? Got a link?
Check out https://www.e90post.com/forums/showthread.php?t=1685171 and the posts referenced.
      03-20-2024, 02:55 AM   #3
domain007
21
This is the kit : https://www.turnermotorsport.com/p-567777-turner-adjustable-short-shift-kit/?pdk=AQcI
This is the refresh kit I'm talking about:
https://www.turnermotorsport.com/p-555693-turner-motorsport-shifter-rebuild-upgrade-kit-e9x-325xi-328xi-330xi-335xi/
The part in question is the rod joint that attaches directly to the transmission
      03-20-2024, 03:01 PM   #4
335i54n
Drives: e90 335i, e39 m5
its a waste for the kit since u have the ssk. you just need the 2 oval bushing (stock or poly) and the rear bushing, the clips, rod bushing (realoem vin verify if u want toi replace)can be resused. imo i would upgrade oval bushes and use a new rear bushing. fyi the shifter is not bent like oe so sit a little crooked, you get used to it but hindsight it more annoying than i thought
