BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Cylinder 4 misfires! Can't find the problem
Studio RSR
      11-12-2023, 06:28 PM   #23
joselaholla
Drives: bmw X1
Do you resolve this issue?
Hello, Did you resolve this issue? I'm having the same issue with my X1.
      03-24-2024, 01:15 PM   #24
Costello
Costello's Avatar
Germany
Drives: 335i E92 LCI
Originally Posted by AlpineweissF10 View Post
I did a static compression test by disconnecting the fuel pump and removing spark plugs and connecting compression tester and cranking for about 10 times for each cylinder. They all came in around ~210 (+/- 2).
I then did a leak down test and it showed less than 4% leakage for each cylinder.
Sounds like you did a running compression and that was the issue. I'll look into that next. Hope that's not the case.
Originally Posted by Felixrobb View Post
Nope, Still not resolved...
And you solved this?
      03-26-2024, 08:42 PM   #25
AlpineweissF10
10
Drives: 2012 535i Xdrive
Not sure what happened but mine was the HPFP. Sounds weird but replaced it and it's been running great.
