      03-30-2011, 06:41 PM   #23
eleven11
eleven11's Avatar
Drives: -F85 X5M-
I have this same setup - I think it sounds awesome. I have absolutely no idea how some people describe the system as "anemic" or underwhelming. If you feel this way, I honestly feel you should get it checked out (or your hearing). Not trying to be offensive - I really am perplexed.
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      03-30-2011, 08:24 PM   #24
FDM68
FDM68's Avatar
Wake Island
33
Drives: 11' 135i
Originally Posted by 11N55 View Post
Thanks! Bass -1, Treble +1. As far as the frequency settings go I have it set up like a bell curve with the lowest and highest frequency at normal and the mid frequencies +3. Ill post the exact settings when I get a chance.
Just went out a gave this setting a try. I like it allot, Thanks.
      04-09-2011, 04:52 PM   #25
brauheist2007
brauheist2007's Avatar
Drives: 2011 135i
I did my best to mimic the "Electronic" setting on the iTunes equalizer for the car's equalizer. Then I bumped the bass up a little over the half way mark. Sounds pretty good to me. I do wish it had a wee bit more mid-bass power....but it is very clear.
Also, if you have an iPod hooked up try setting the equalizer on your iPod to your favorite EQ ('electronic' in my case) before you plug it in and then run it....that sounds pretty awesome to!
I have the HK system w/ iDrive.
      05-09-2011, 08:45 PM   #26
11N55
11N55's Avatar
32
Drives: AW 2011 135i 6MT
2011 BMW 135i  [0.00]
Sorry for taking forever to post this, for anyone that wants the settings here they are:
Bass +1
Treble +1
Bal 0
Fader 0
Logic 7 Settings:
80Hz +1
200Hz +3
500Hz +3
1kHz +2
2kHz +2
5kHz +1
10kHz +3
Order Placed: October 25 | Production Complete: November 4 |En Route: November 16 | At Prep Center: December 2 | At Dealer: December 6
      08-11-2012, 02:31 AM   #27
.b0link
14
Drives: 2012 LMB 135i
BACK FROM THE DEAD!
I used these settings on my 2012. However in the EQ there was no 80hz setting but 100hz instead so I just adjusted the 100hz to the +1 of that it was said for the 80.
My question is, im guessing they have changed around the settings and terms...and mine has nothing about Logic 7 listed, but has an option marked surround sound.
Im no audiophile and my ear obviously isn't as good as others, but I was unable to notice a difference between Surround on and off. What exact effect does this setting have and what are most people running?
As for the EQ settings though, def made a noticeable difference and sounds much better than everything did being zeroed out. Glad I found this thread cause I have no idea how to "tune" an EQ.
      08-11-2012, 02:36 AM   #28
.b0link
14
Also, any audiophiles out there care to share their settings?
      08-19-2012, 02:42 AM   #29
Bmwbreed
Drives: 2013 BMW 135i
11n55. Sounds great to me. Glad I chose this option when ordering and can't wait to try it out once my car arrives. Btw love the song playing. What's the name of it? Kinda sounds like progressive trans which I love. Is it on iTunes?
      08-19-2012, 01:51 PM   #30
Derek8819
Derek8819's Avatar
35
Drives: 2015 F80 M3
I am sure the HK sounds awesome, but with the basic system in my 1M there are so many interior rattles when the system is loud that it makes it completely unenjoyable. I don't know how you guys do not have the same issue.
      08-20-2012, 11:16 PM   #31
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
Bass +1
Treble +1
Bal 0
Fader 0
Logic 7 Settings:
80Hz +1
200Hz +3
500Hz +3
1kHz +2
2kHz +2
5kHz +1
10kHz +3
Has this gained anything other than making it louder? Boosting everything, in different amounts, seems... wrong, by everything I ever learned. Normally you start flat, take away what's too strong and add what's missing. Boosting everything across the board seems kind of silly.
I don't guess the OP ever claimed to be an expert but...
      11-25-2012, 08:59 AM   #32
thehalcyon
52
Drives: '12 135i MT LeMans
I'm shopping around for a 135i at the moment and I'm wondering how the stock "hi-fi" system and the HK system compare to the stock hi-fi unit in the f30 3 series.
I've test driven the 135 but forgot to bring and cds with me during the last visit.
I did listen to the radio but it wasn't really very good quality on the 135. I was quite impressed with the sound system on the new 3 series.
None of the dealers in my area have the HK system in a 1 series for me to listen to, so I would be making a blind decision on this.
Thanks
      11-26-2012, 12:29 AM   #33
kleach18
Essayons
kleach18's Avatar
Drives: 2013 135i
I added the HK system to my order without ever hearing it. Its worth every penny, although it sounds like a $$ from the outside of the car. Not sure if it's the way the subs are facing under the seats or just the general design. I had a loaner that just had the basic hifi system in it and it did the same thing. It just seams that the HK has more power and more adjustability so it's a little worse.
Inside the car it's worth every penny.
/ 135i - M-Sport / 6-Speed / BMW Performance Exhaust / BMS Intake / JB4 Stage 2 ISO + Flex Fuel Wires / BMS 3.5in Down Pipe / CP-E Charge Pipe / Walbro 255 in-line fuel pump / BMS H8 AE / BMS SSK / APEX EC-7's with Nitto NT05's / COBB Tuning Sport Springs / Koni Yellows / Wagner Evo 1 / Blacklines / iCarbon Rear Diffuser / BMW Performance shift knob/boot / BMW Performance Steering Wheel /
      05-28-2013, 09:15 AM   #34
cat-like
cat-like's Avatar
Australia
10
Drives: 2013 AW 135i
Reviving a thread from last year here based on my experience of the HK system in my 2013 135.
People's opinions are only relevant to what they are comparing it to and what their expectations are. I guess I would describe myself as somewhat of an amateur audiophile. My home system is probably very elaborate by most people's standards
As an upgrade over the basic system the HK is actually a decent option, I got it in the hope that I could tweak it to satisfy my needs, but unfortunately it doesn't measure up. After 3 weeks of playing with the settings, including countless hours of google time, I am now resigned to the fact that I will be looking at aftermarket options.
The mid bass is just not tight enough and the sound is just too bright and fatiguing. I had top of the range Focal splits installed in my previous car, with a small rear Hertz sub, Alpine amps and Dynamat. The system was tuned by a local guy with a great reputation in car audio. The Focal tweeters can be described by some as a little bright but these HKs are considerably brighter. My previous system was the envy of all who heard it for smoothness and clarity and those who have been in my new beemer have all commented on the "disappointing" sound in comparison.
Did I expect the HK to be on a par with my previous system? No of course not, I'm not delusional. But I was hoping for something I could live with.
So I will soon be looking at upgrade options and obviously spending a bit of money. You get what you pay for.......
      06-01-2016, 05:17 PM   #35
shibbay
Drives: 2011 135i DCT
Originally Posted by tyorll View Post
music playing?
Originally Posted by Aries932 View Post
what is the name of your song that you are playing?
It's Zaa ft Molly Bancroft - Surrender:
harmon, kardon, review, system
