M3 ABS/DSC unit
05-07-2019, 10:29 AM | #1 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
M3 ABS/DSC unit
Excellent condition M3 ABS/DSC unit. Part numbers are in the pics. All M3 ABS/DSC units are interchangeable and work with any model yr E9x M3. They all use the same DSC software version.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
06-16-2019, 04:13 PM | #2 |
Sua Sponte
1299
Rep 2,850
TTT
06-17-2019, 03:29 PM | #5 |
Sua Sponte
1299
Rep 2,850
The benefit is in the DSC module. If you know how to do it, a M3 ABS/DSC unit can be coded into a non M car and be rid of almost all of the electronic nannies that the non M car has.
06-19-2019, 08:42 AM | #6 | |
Rep 87
06-20-2019, 03:24 PM | #7 | ||
Sua Sponte
1299
Rep 2,850
Coding wise the only additional step you need to take before you would do all the normal stuff ( write vin/update module with winkfp, default code with NCS expert, DSC calibration and brake bleed with ISTA ) is alter the model identifier code in one of the stored VO'S to a M3 model. I leave my CAS VO as 335is for most everything and have the VO stored in the NFRM as a M3 model. When I go to code the DSC from then on out I choose the NFRM module in ncs expert in my initial read so the module is read and codeable as a M3 module otherwise you'll get a error because of the 335i VO and the M module mismatch.
07-28-2019, 06:33 PM | #8 |
Sua Sponte
1299
Rep 2,850
ttt
02-23-2024, 01:36 PM | #11 |
Sua Sponte
1299
Rep 2,850
My bad, I do not. I'll mark this as sold.
