03-07-2021, 09:43 AM | #45 |
Rep 1,148
Can we replace the servo motor before it fails, to not risk the eccentric shaft? I'm sitting at 72k and the car runs flawlessly, I've gone through most of the car, I'll replace the servo motor early if it means preventing more work later.
06-22-2021, 10:33 AM | #46 | |
Rep 5
Do you think it's because of the voltage? What do you think if I boost it with a another car follow the relearn process? Or does it need to be a voltage stabilizer? Any advice will be helpful. Thanks |
08-02-2021, 10:52 PM | #47 | |
766
Rep 2,361
08-03-2021, 03:06 PM | #48 | |
Rep 3,947
08-04-2021, 05:31 AM | #49 |
Rep 2
Hi, can you explain me what is 0b2 and jb4 ? I have the simillar problem ! Error 133E10 Check indication + no power in motor, hardly to start engine motor, changing of missfire errors, cilinder 1,2,3,4,5 and 6 !
08-04-2021, 10:53 AM | #50 |
Rep 7,607
OBD2 is the plug under the dash on the driver side that allows you to connect to the vehicle. It's what you would have used to scan for codes.
JB4 is a piggyback tuning device. Suggest you google them. |
08-16-2021, 10:00 PM | #51 |
A Govea
Rep 3
BMW Valvetronic Code
This is for the F25 chassis Engine N20. Mine is a BMW X3 28iX drive, 2013, it has 80,000 km.
One day during a normal drive in the morning I got the annoying message in the dashboard “DriveTrain Malfunction…” Limp mode activated, I stopped and turned the engine Off, waited five minutes, turned engine On and the error disappeared, the car was running fine the rest of the day and next days until I got the time to run a diagnosis using ISTA. ISTA is the software used by BMW dealers or specialised workshops to diagnose any malfunction, so far I have used ISTA in my F30 and F25. Memory fault was read and I got this two codes: 133B04 - Valvetronic system ; no adjustment possible 133E10 - Valvetronic system: deactivated , adjustment fault too frequent The first one appeared as not present but the second one was still present. Decided to follow the procedure to try to repair the problem. It took me about two hours running all the test using ISTA, you will need a battery charger to keep the battery voltage above 13v during all the procedure. The problem was fixed, the Valvetronic system was recalibrated by the software, no tools, no spares, no work under the hood, SIMPLY scanning and diagnosis the car using BMW software. Start saving time and big money, get yourself a laptop, ISTA and the USB or ENET cable to connect your car. |
F32Fleet3587.00 |
09-24-2021, 05:35 PM | #52 | |
Rep 18
Thanks |
01-22-2023, 07:00 AM | #53 |
Rep 3
Hey all, I appriciate your help.
I recently replaced the valvetronic motor on my f30 335i 2012. My issue now is with ISTA (on my laptop with windows 11). As you know, 2 service funtions should be carried out after the replacement. First Function: "Valvetronic running-in phase" Basically when I start this funtion (consisting of 450 cycles) the procedure starts but the count is very quick. This can not be normal right?. It was like less than 1 second for each cycle. Second function: "Learn valvetronic limits positions" The problem is that ISTA is not able to start this function and throws this text: The starting coditions for teaching-in limit positions are not met. Either the engine speed is not exactly 0 or the valve tronic relay has not applied. No matter how many times I tried this error still appeared eventhough my motor is off, and only ignition is on. I read that there are latency settings on ISTA than can cause a miscomunication between the car and ISTA. But didnt find futher explanation. Does anyone know what going on wrong? I have ISTA version 3.47.10. |
01-30-2023, 02:29 PM | #54 | |
10
Rep 32
https://www.car-auto-repair.com/how-...h-kdcan-cable/ |
F32Fleet3587.00 |
03-25-2024, 02:35 PM | #55 |
Mr OEM
658
Rep 80
Drives: 2012 BMW 335i
Sorry to bump this post*
Anyone have a good fix to this issue, my 2012 335i makes an audible click when unlocking or opening a door, does this mean that the valvetronic system motor is bad or anything along those lines? |
03-28-2024, 02:12 PM | #56 | |
scotthilly
75
Rep 104
I have a 2011 335i (e90) but with the same PWG N55. I had this issue and the shop near me replaced the valvetronic motor and valve cover gasket for $1,300. |
03-28-2024, 02:19 PM | #57 | |
Mr OEM
658
Rep 80
As my 335i has only a single click that I can hear, and I see that other people's cars are making a continuous clicking sound for a few seconds, and they said it was their valvetronic motor. |
04-01-2024, 06:29 PM | #58 |
scotthilly
75
Rep 104
I had one single audible click upon ignition on.
04-02-2024, 01:24 AM | #59 |
Mr OEM
658
Rep 80
