03-08-2023, 01:40 AM | #1 |
Rep 29
BMW 435i Engine Replacement
I recently spun my rod bearings on my 435i RWD. It was around 109k miles, FBO Stage 2 BM3. I just sourced a new motor, 70k miles for 3 grand. I’m planning on replacing a few components on this new motor and had a couple questions.
1) I plan to replace the valve cover gasket, oil pan gasket, oil pressure control valve, plugs/coils, and injectors. I was wondering what other components I should replace while the motor is out. 2) I’m currently running Bootmod3 Stage 2(Agg) OTS tune. I’m obviously going to keep it on stock tune for a while but I was wondering how long I should keep it stock for. I still plan on flashing back to Stage 2 sometime but when would be a good time to do that? 3) I’m also adding the MMR oil sump baffle. I know the S55 oil setup is way better but I can’t afford it. Anyone who has the MMR setup please let me know your experience. I’m 99% sure the shitty oil pan design on the N55’s caused the spun rod bearings. I’ve never tracked the car and don’t plan to. I do drive decently hard and take it out on the occasional canyon sends. Open to any advice thanks! |
03-08-2023, 09:49 AM | #2 |
84
Rep 93
Was any work done on oil system before it let go, like oil filter housing gasket? From my research, MMR should help especially under hard braking. But a lot cars let go because oil system wasn’t primed after ofhg or low on oil.
03-08-2023, 02:05 PM | #3 |
Head Fry Cook at McBurgertown
507
Rep 1,005
Replace the rod bearings on the new (used) engine. If you're doing the baffle, you'll be right there at them anyway.
Also, do the oil filter housing gasket. Make sure to prime the new engine before firing it up. |
03-08-2023, 06:10 PM | #4 |
Rep 29
No work was recently done on the oil system before it let go. I did have the “low engine oil light” but quickly added a quart of oil.
03-08-2023, 06:12 PM | #5 |
Rep 29
Got it! I’ll definitely replace the OFHG. My mechanic is doing the motor replacement so I’m sure he knows the procedures such as priming.
03-08-2023, 08:59 PM | #6 |
Rep 7,607
03-09-2023, 04:39 AM | #7 |
Rep 29
Just the add oil warning. To be honest it was completely my fault, should’ve taken better care of the car. It’s my first Bimmer so I didn’t fully understand the amount of maintenance these cars need. Expensive lesson but I will definitely take a lot better care of the new motor.
03-10-2023, 05:46 PM | #8 |
Rep 29
My mechanic also told me to replace the Oil Pressure Control Valve while the motor is out. What does this do and is it necessary to change? He told me this could’be been a cause for my spun rod bearings.
03-25-2023, 07:05 AM | #9 | |
1006
Rep 2,243
Drives: 2007 328i / 2014 M235i
If the car said engine low, that only means it was down 1L, I wouldn’t worry that you caused it but being stage 2 doesn’t help. Put new bearings for sure and the baffle |
04-07-2023, 08:43 PM | #10 | |
19
Rep 106
04-13-2023, 10:51 PM | #11 |
84
Rep 93
If it was low on oil, it’s either burning it or leaking. N55s don’t like to run low on oil. Did you drive it aggressively on low oil? That would definitely kill rod the bearings.
03-29-2024, 02:44 AM | #12 |
Rep 29
2k for labor and around 4K for the motor (used). Since the engine was already out I had my mechanic change all the gaskets and solenoid. It’s been a year and I haven’t have any problems with the replacement engine.
SpoolinAddict19.00 |
03-31-2024, 07:25 PM | #13 | |
Rep 3,947
I tried 2 of them before just opting for a new N55 from BMW. |
04-03-2024, 09:45 AM | #14 |
scotthilly
73
Rep 104
04-03-2024, 02:33 PM | #15 | ||
Rep 13
Contrary to what many people say, the N55 is a reliable engine if it’s maintained well. Make sure you aren’t in need of any gaskets as this might contaminate your oil with unwanted debris, but over all, based on your great maintenance history, your engine should last for a long time. One thing that is specifically mentioned in this thread and I cannot stress this enough. Any time you do any maintenance that disrupts the oil channel, ex your oil filter housing gasket, please prime the engine. There are many different ways to do it and it realistically takes 15 min at most. Doing so will ensure that there is no oil starvation to your rod bearings and should keep your engine running healthy for many miles to come. At some point as well, I’d suggest replacing your belt along with the tensioner and other components regarding that area of the engine. The N55 is known to suck up the belts into the crank seal, which shears the belt which then gets into your oil. Watch for that as well |
04-03-2024, 02:43 PM | #16 | |
Rep 3,947
About $13,500 (includes the core charge) since BMW won't take an engine back with a few holes through the engine block. |
scotthilly73.00 |
04-05-2024, 04:56 PM | #17 | |
Rep 10,356
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
