07-19-2011, 10:50 PM | #111 |
1099
Rep 2,286
BTW - would a rear-drive car with either a: 1) manual transmission; 2) automated manual, i.e., MDCT; or 3) modern 8-sp auto (such as on Lexus ISF) normally have about a 20% drivetrain loss? If not, what would be the standard "approximate" drivetrain loss percentage for these transmissions assuming RWD?
07-21-2011, 02:30 AM | #112 | |
Rep 10,407
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
03-09-2012, 08:20 AM | #115 | |
Rep 693
01-01-2017, 09:35 PM | #116 | |
14
Rep 62
Here it is now 2017 and we've had stock @ 560HP, CP @ 575HP, Jarhe 30 @ 600 HP and now rumours of the F90/G30 or what ever it's called will be 600HP+ all with assuringly the same basic configuration. I'd predict this engine @ 650HP+ before the production ends. My 2 bits |
01-07-2017, 10:44 AM | #117 |
MGySgt
642
Rep 1,260
Drives: See Garage List! ;-)
Garage List 2010 M5 [10.00]
2016 BMW 340xi M Sport [9.00] 2019 X5 50i M Sport [5.50] 2010 535xi [0.00] 2013 M5 [0.00] 2012 X5 M [0.00] |
....Yeah! There is no way going from 1.2 bar to 1.5 bar only makes for a 5Hp diff. If one did the math on the difference,...then that same diff you should reflect there about the additional increase in power. My math is showing a 20% increase in boost!
So, if BMW wants us to believe that a 20% increase in boost yields only 5 more Hp,...then that's what we will believe. Someone pls check my math!
JMD
01-16-2017, 08:14 PM | #118 | |
14
Rep 62
Atmospheric pressure has no bearing on the turbo specification. Bar is a unit of pressure measurement. The M5 turbos create 1.5 bar (~22psi) above atmospheric pressure. It doesn't matter if you are sea level or 5000'. Cylinder pressure will be the same at maximum turbo output. The engine won't respond as well during spooling of the turbos at higher altitude due to air density and oxygen levels but it should theoretically make rated HP once they are fully spooled. My 2bits |
01-16-2017, 08:39 PM | #119 | |
14
Rep 62
01-16-2017, 10:33 PM | #120 |
Rep 6,072
I do agree the this platform might be able to generate 650 HP but then we need to see if DCT is getting redesigned or they want to use the Auto transmission. Something like the one installed on X5M/X6M
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT Gone : 2016 F82 Austin Yellow M4 - 6MT Gone : 2013 F13 Sakhir Orange M6 -7DCT Gone: 2013 F13 Alpine White 650i -ZF8 |
12-03-2017, 08:22 PM | #121 |
Rep 34
this article says the opposite , bmw increased the compression and lower the boost by .1 bar = 1.1 bar
who is right ? http://www.bmwblog.com/2011/09/22/bm...-of-the-beast/ |
03-30-2018, 03:52 PM | #122 | |
Rep 1
VE efficiency
10-18-2023, 08:34 PM | #123 | |
125
Rep 376
Drives: '23 AMG GLE53, '10 X6M
Might make sense as the m5 being a racing sedan and the X5/x6 being a big arse SUV. Wouldn't the SUV need more torque for itself vs a lighter sedan? |
