02-13-2024, 07:08 PM | #1 |
47
Rep 57
Drives: F82 m4 comp
2011 BMW E90 M3 Competition Mileage: 145,000 6 speed manual Exterior: Alpine White Interior: Palladium Vin: WBSPM9C50BE203838 Location: Columbus , OH Rod bearings done, throttle actuators replaced, valve cover gaskets done, upgraded valve covers Modifications & Upgrades Öhlins Road & Track Vorschlag adjustable camber plates Mporium aluminum undertray Mporium textured valve covers Some Key Service History Service documentation shows the following recent maintenance has been performed: *more service history is available, binder full of receipts* - November 2023 (142,328 miles): OEM BMW sway bar end links (both sides replaced), Oil filter housing gasket replaced, oil change - August 2023 (139,800 miles) : OEM engine oil level sensor, seal, and motul oil change * October 2022 (134,309 miles): Clutch, flywheel, transmission mount, transmission shifter bushing, driveshaft support bearing, flex joint, oil changed, and secondary air control valves replaced * March 2022 (130,223 miles): Engine oil and filter changed, valve cover gaskets and engine mounts replaced, alignment performed, suspension corner balanced * September 2021 (122,305 miles): Engine oil and filter changed, engine air filter, engine ground strap, and idle air control valve replaced * February 2021 (114,460): Engine oil and filter changed, spark plugs replaced * October 2020 (106,558 miles): Engine oil and filter changed, alternator replaced * February 2020 (96,783 miles): Engine oil and filter changed, headlight adaptive motor replaced * August 2019: Throttle actuators and coolant temperature sensor replaced * February 2019 (86,321 miles): Brake fluid, front and rear brake pads, rotors, and sensors replaced * February 2018 (76,773 miles): Engine rod bearings replaced, airbag recall service performed Since purchase, I’ve had the front bumper professionally resprayed (rock chips filled, and license plate screws filled). I also had the OEM 359m competition wheels redone in OEM BMW silver (new center caps and new M gel stickers). Paint correction and gyeon wax preformed. Lastly, I’ve had the windshield and top trim seal replaced with an oem windshield, seal, and new wiper arms. * 2 keys * Service records * Wrenches and manual for ohlins suspension This car has been an absolute blast to own and is very solid. The car has been in Texas majority of its life. The underside is clean. The car drives very nice, with the upgraded suspension and having most of the rubber components underneath replaced, the car drives better than most lower miles examples I’ve driven. The exterior of the vehicle presents itself well, with the only downside being the occasional rock chips, but there’s no major scratches, dents, or dings. Miles will slightly go up as I daily drive it. |
02-14-2024, 01:33 PM | #2 |
Rep 798
Looks great for its age and mileage. GLWS!
vortexdetail46.50 |
02-14-2024, 06:32 PM | #3 |
47
Rep 57
Drives: F82 m4 comp
02-15-2024, 08:04 AM | #4 |
105
Rep 112
Drives: 2013 E92 M3
Palladium on white, such a clean look!
Best luck for your sale from a state neighbor
To me, S65 V8 = automotive bliss
vortexdetail46.50 |
02-22-2024, 10:18 PM | #5 |
Rep 14
looks GREAT bump
vortexdetail46.50 |
03-01-2024, 12:06 AM | #6 |
Rep 1,974
This is listed as ZCP but it doesn't seem to have EDC. Are you sure it's an actual competition?
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily 2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten |
03-01-2024, 06:27 AM | #8 |
47
Rep 57
Drives: F82 m4 comp
The car is a competition package model. The EDC was deleted when the ohlins road & track coilovers were installed.
03-14-2024, 06:54 AM | #10 |
47
Rep 57
Drives: F82 m4 comp
04-15-2024, 05:41 PM | #12 |
47
Rep 57
Drives: F82 m4 comp
Bump - price is negotiable if anyone is interested
04-15-2024, 11:33 PM | #13 |
57
Rep 149
Drives: BMW M3 E92
Interested in e90 m3 for sale
Hi! I'm helping a friend find an M3 and he's interested in the car you have posted. He's not a forum member so I'm pming in his place. He's located in VA so if you're okay with shipping and the deal goes through with him then likely in a few days you'd have it shipped out. If not we could trip up there sometime in a week or so. His name is Nick, you can message him at (804) 297-8632. I hope it goes through! But, if it does or doesn't glws!
