BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Chassis reinforcement plate (from CPM Japan)
GetBMWParts
      10-25-2015, 06:08 PM   #23
knightsabers
knightsabers's Avatar
Australia
454
Drives: Audi R8 v10 Spyder
I'll let you know when it arrives in the next couple of days
      10-25-2015, 09:38 PM   #24
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
I am excited to hear your impressions.
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      10-29-2015, 09:22 PM   #25
knightsabers
Australia
454
Installing it tomorrow hopefully. It's solidly built with a bit of weight to it. I'll measure the dimensions & weight later.
Here's a copy of the instruction.Created a translated version beneath.
      10-30-2015, 11:47 AM   #26
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
would it fit with a big 3inch exhaust because the stock plate was causing rattle with my exhaust where they were too close.
Docrace 6266
      10-30-2015, 11:57 AM   #27
tboooe
tboooe's Avatar
925
I doubt it because its position is the same as the stock one so if your exhaust was hitting that it would also hit this one too.
My build thread
      10-31-2015, 12:34 AM   #28
knightsabers
Australia
454
Got it installed first thing this morning. First impression is less body roll entering a corner at speed, surprisingly it took away the rumble from the start stop.
I have a 3" full exhaust and the clearance is fine for mine.
Might try it for a week before giving my thoughts on it.
OEM Piece
      10-31-2015, 09:52 AM   #29
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
I installed the F80 brace on my F30, but have since went further and purchased the brace from the F32. The coupe's brace ties in two additional contact points and is pretty inexpensive.
      10-31-2015, 10:42 AM   #30
tboooe
tboooe's Avatar
925
Did you experience any improvement in handling with the F32 brace? If so, I wonder if adding the CPM brace would further improve things.
My build thread
      11-04-2015, 04:21 AM   #31
NISFAN
NISFAN's Avatar
3489
Drives: BMW M2
Are those two extra rods to reduce the yaw movement of the subframe during cornering? Are they solidly mounted? Have you noticed any difference?
      11-04-2015, 11:55 AM   #32
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
That's a photo of the underside of my F31 340i I took while it was on the lift at a friend's garage and those are stock bracing parts. My March 2015 F31 330D also had the same bracing.
      11-04-2015, 01:09 PM   #33
2014 335i  [9.74]
Yea, I used your image since I didn't have one in my phone at the time. Since F30s don't have the same type of brace as the F31/F32, I ordered the parts and plan on putting them in a week or two.
      11-04-2015, 01:10 PM   #34
2014 335i  [9.74]
Some more images of the F31/F32 chassis brace...
      11-04-2015, 02:11 PM   #35
tboooe
tboooe's Avatar
925
glennQNYC did you notice any improvement after you installed the new brace?
My build thread
      11-04-2015, 05:57 PM   #36
2014 335i  [9.74]
Not on yet... My shop of choice (Lux Motorwerks) has been backed up with SEMA projects. I'll have it on in a week or two.
      11-05-2015, 04:33 AM   #37
Daftasabrush
Fool
England
1857
Drives: F31 340i
Looks like the F31 and F32 have different part nos for this:
33316861811 is shared with F31, F34 GT and F36: http://www.realoem.com/bmw/enUS/partxref?q=33316861811
33316797444 is shared with F32, F33 and F36: http://www.realoem.com/bmw/enUS/partxref?q=33316797444
Interestingly, the F31 part appears to weigh a bit more than the F32 part but I doubt there's much difference though if both parts fit the F36
      11-05-2015, 11:03 AM   #38
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
I have installed the F80 plate and similar cross brace for F2x series.
I have quaife LSD and JB4 with ~ 400bhp/460lbft and the rear brace positively locates rear subframe to the underbody.
More power and QLSD putting more reactions into the rear subframe bushes meant occasionally worming under hard acceleration. With underbody chassis bracing the rear is now much more stable and any and all of the aforementioned wobbles have gone and the car is now even more composed especially over bumpy roads, typical of what we have here in the UK.
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      11-05-2015, 04:54 PM   #39
Daftasabrush
Fool
England
1857
Drives: F31 340i
Interesting the F80 plate can be installed with the cross brace. Did you have to use longer bolts?
      11-05-2015, 09:08 PM   #40
dotjonnL
20
Drives: 335iX M-Performance
+1 did you have to use longer bolts?
      11-06-2015, 03:06 AM   #41
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Yes - installed longer F8x bolts.
The stock F2x bolts are 3/4" long and the stock F8x bolts are 1" long
      11-08-2015, 03:44 PM   #42
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Can this be done to X-Drive cars as well? Or is this a strictly RWD upgrade?
Edit: Never mind my question, I just checked a picture of my X-Drive's under-body and the panels look the same.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      11-08-2015, 03:54 PM   #43
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Stock 435i X-Drive brace:
      11-10-2015, 07:06 AM   #44
Seraphblade@sg
42
Drives: F30 328i
Hi Glenn, would you be able to post the part numbers for the 2 additional braces?
