BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > A Look at F8x Springs for F3x Vehicles
GetBMWParts
      03-08-2020, 11:18 PM   #23
FaRKle!
Originally Posted by Jerich0 View Post
How much harsher did your ride get with F80 springs?
Harshness is more of a function of the dampers and not springs. In fact, when my rear dampers were optimized for a 620lbs/in spring, putting a 900lbs/in spring in there was actually softer/smoother than the 620lbs/in spring because the damping ratio went way down.
When people get more harsh rides after fitting stiffer lowering springs, it's usually because they're engaging the bump stops too much.
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      03-19-2020, 01:41 PM   #24
Littlebear
Drives: ...the Mods crazy.
Originally Posted by FaRKle! View Post
4cyl RWD F30/32/36
.... Rear F80/82 springs might be fine and slightly lower.
2) I'm not your personal spring consultant, unless you're buying one of the sets I have for sale , haha. [/i]
Hi Mr. FaRKle & other BMW Experts!
I have a '17 330i rwd, no sunroof. Stock (not M) springs, M-sport bars, & Bilstein shocks.
I think my rear springs are too soft, but I can't take any drop. Going by the info in your first post, I'm not sure if there is hope for me. I think I would need the rear F80 springs to give me ~ 3/4" more height than they do in an F80 (1/4" + ~ 1/2" for M-sport?), which would have to come from my lighter weight. Can you offer an opinion, pls?
TIA! Murf
      03-19-2020, 04:08 PM   #25
FaRKle!
TIA! Murf
There should be stiffer springs from other F2x/F3x models that will let you maintain your current ride height (or close to it). Base suspension springs are pretty soft. If you have B6/8, then your dampers can definitely handle them (because with those shocks and your OE springs you're WAY overdamped).
      03-19-2020, 04:45 PM   #26
Littlebear
Thanks FaRKle,
What is the weight dist. of the F80? I imagine not 50/50 like the 330i, but not too far off, so it seems the F30 ends would do a similar thing, ie: both go up almost the same amount (or down), instead of going in different directions (fnt up, bck down)?
Murf
      03-20-2020, 12:50 AM   #27
FaRKle!
Thanks FaRKle,
Murf
6cyl front cars tend to be around 55% front.
      03-20-2020, 05:58 AM   #28
Littlebear
My search finds the F80 at only ~ 110lb (two dogs) more than my 330i, with a weight dist. of ~ 52% front for the F80 (50% for the 330i?). So the rear of the F80 < or = to my 330i (by my calcs, depending on curb figures).
I think the F80 springs would drop my rear, and maybe the front.
Any opinions or better calculations, pls?
Murf
      04-11-2020, 06:27 PM   #29
therealm3
Drives: F30 340 MSport
Adding in my experience. I have a 2016 340 M sport, 6MT, with track handling package (EDC). I bought a set of used M3 springs from a car with MT and put them on my car this weekend. I also bought a new set of 4 M3 bump stops (after reading through Farkle's thread on those as well). The install went smoothly. If you are doing this for the first time or looking for a refresher like I was, I recommend finding Farkle's DIY on you tube. He goes through it from start to finish and includes good tips, tool advice, and all the torque specs you need. It is a great video.
Anyhow, the car dropped about 1/4" front and rear with the M3 springs vs. the MSport springs. I was hoping for a little more, but all in all its a nice subtle drop. Probably better to have a bit more height in the long run as a daily driver and mountain bike hauler via a rear hitch mount. Driving the car I can feel that it is stiffer but the handling isn't drastically different than it was stock. In completely unscientific terms, it feels slightly flatter and a bit crisper. One thing that was very apparent is that in comfort it settles better. My neighborhood has a fair amount of speed bumps and with the MSport springs it would have a double bounce when in comfort mode and now it has a single rebound. Which is how Sport was before, but with the stock springs and sport mode, the single rebound was much more harsh then comfort is now. I like it.
All in all it was less than $200 for parts and I think it was well worth it. I figure this will suit me till warranty is up in a year and then I'll look to something a bit more custom with ride height adjustments. Or if I decide I just want to go lower for looks, I can always get a set of eibach springs. They should match well given the spring rates are very close to M3 rates.
FaRKle!4017.00
Littlebear3509.50
      04-18-2020, 06:12 PM   #30
Randy Johnson
M340i
Randy Johnson's Avatar
Drives: BMW M340i
2021 BMW M340i  [10.00]
Looking for mild drop on an F36 with adaptive suspension. Can anyone tell me what springs to use?
      04-20-2020, 11:29 PM   #31
weehe126
Drives: 2017 340i
I see some ZHP springs, code MP for sale. I have an auto 340i, so am assuming a ~0.5" drop at most since it is softer for the manual? I have non-adaptive M-sport suspension currently.
      07-02-2020, 10:21 AM   #32
JJR4884
JJR4884's Avatar
26
Drives: E46 330Ci | F32 435i
Great post - going to do a bit more research for sure. I have a 2016 435xi MT with M Adaptive - I'm happy with the rear ride height but I would like to try and source F80/F82 fronts to drop it just a tiny bit. The wheel gap and front lip are so far way from the ground but even a 0.5 in difference would make it that much better.
      07-04-2020, 11:36 AM   #33
cu260r6
25
Drives: 428i
I put standard F82 springs on my F32 about two years ago. I paired them with Koni special active shocks and have loved every mile in the car ever since. The ride is firmer but not harsh, and I've never had a passenger complain. Occasionally, I entertain the idea of swapping for the yellow Koni sport shocks, but it doesn't seem to be worth the money as the special actives are perfect for 95% of the time. Great upgrade, highly recommend.
      07-11-2020, 01:24 PM   #34
weehe126
Drives: 2017 340i
What shocks/struts are people pairing with these springs? Currently have non-adaptive M Sport suspension on a auto 340i. Bought zhp springs from a F80 with dct and no sun roof, so high spring rate with expected minimal drop.
      08-06-2020, 12:12 PM   #35
blumagic
blumagic's Avatar
309
Drives: 2014 328i xdrive , 2013 SHO
Decided on Emmanuel design f80 springs. Should be pretty low and maintain a wife friendly ride.
I’ve seen the lift people get with b8’s in addition to farkles observations I think the f30 springs have a lot of preload with b8s. I remember having to compress them (h&r sports) quite a bit Just on the stock struts. With the shorter b8s it would be even more. With these EMD springs i can start threading without compression. When the new bearings come in it should be about as much preload as I’ve experienced in my coilover setups
      08-06-2020, 10:36 PM   #36
EricD735i
Drives: ‘16 328d & ‘16 X3 28d
Curious, did you get the special actives for the M sport suspension? Or standard suspension?
      08-11-2020, 10:54 AM   #37
CarolinaBavaro
CarolinaBavaro's Avatar
Drives: 2013 Bmw 335i M sport
As I have seen on here. Most people are using Bilstein shocks with anything. I just recently installed some Koni Yellows due to my EDC shocks 3 out 4 being toast. My car had Dinan Springs with Shockware. EDC is okay for those who want the convenience but compared to the Yellows that setup is straight Garbage. Especially for the cost of replacement. The only con regarding the yellows is the rear adjustment. They have to be removed but besides that they are awesome with Dinan Springs. I think the yellows are a better since you can adjust them to fit what ever spring you use.
      09-04-2020, 06:33 AM   #38
xpro
Drives: 335XD
My Setup 335d xdrive currently B12 with -06 Eibach springs ( this are slightly higher spring with 1095kg payload)
Would you guys recommend F80 dct springs instead of my setup?
I find B12 to be way too soft.
My car is using just about every inch of the shock travel to the point that the springs are fully compressed. You can actually see the marks on the coils where they touch each other.
The ride on the highway is ok, but on backroads, the suspension is just overworked and the car bottoms out every time.
I almost feel like this B12 was designed for 4cyl lighter cars and just cant hack the weight of a 6cyl car.
At this stage I don't even mind increasing the height of the car in order to raise the B8 travel or just upgrade to b14 with progressive springs that i can manually raise,
thanks
      09-04-2020, 10:53 PM   #39
FaRKle!
thanks
The 34N/mm Eibach front springs are pretty darn close to F80/82 ZCP front springs. You could try going with something stiffer like F33 or F83 springs. If you want to go stiffer but still stay low you could look for the F33 6-cyl M-Perf front springs. They're about 240lbs/in.
xpro171.00
      10-24-2020, 07:18 PM   #40
GeorgeDixon
Drives: X5M & M550i
Reviving this thread. I have my factory springs still from my old M4 (base, DCT, carbon roof). I’m thinking about installing them in my 2018 430i xdrive GC. Any thoughts to how much it will lower it?
      01-07-2021, 02:35 PM   #41
STDK
STDK's Avatar
Denmark
Drives: E36, E46 LCI, F31 LCI, G20
Can anyone tell me if my F31 320d ed which has FF front springs are standard or something else. When I look at F31s with B12 pro they don't seem lower than mine?
2020 G20 330e
2015 F31 LCI 320d ed
2004 E46 LCI 320d Touring
1996 E36 316i Bavaria Compact
      01-07-2021, 05:08 PM   #42
blumagic
blumagic's Avatar
309
Forgot to update
Here is what the F80 ED springs look like on a 328 xdrive
xpro171.00
      03-02-2021, 06:11 PM   #43
Foriegnmonkey1
Drives: BMW 340i RWD
340i adaptive m suspension springs
I have a 2016 340i RWD adaptive M suspension
I ordered the f80 springs along with the bump stops, and want to know if these parts I ordered are correct and will work with my car. I know nobody else that has the kind of knowledge and ive been doing extensive research. these are the parts I ordered:
31-33-7-847-700 Coil Spring $146.32 2 $292.64
33-53-7-847-710 Coil Spring $147.83 2 $295.66
31-33-6-857-729 Bumper $23.73 2 $47.46
31-33-7-847-662 Shock Protector $13.04
please help, and I dont want this to be too low so i dont know how this will react on my car.
      03-11-2021, 09:29 AM   #44
Tommi_Mav
Greece
66
Drives: F32 435dx
Forgot to update
Excellent result!!!
