KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
10-03-2023, 01:26 PM | #1 |
Rep 5
Best track wheel and tire set up?
Hello everyone, somewhat new to the community here and looking for the best track, wheel and tire set up that doesnt rub.
Im currently on the stock 359 wheel set up with the stock tire sizes but want to size up for the track. I also have Stoptech racing brakes front and rear. Is a square set up best, or is it best for handling dynamics to run staggered? What are the best size wheel and offset for both front and rear? Also as a bonus whats the best non slick R compound tire to run? Im sure there is a ton of opinions on tire preferences. I am assuming there is a thread for this but I couldn't find in my searching so thanks in advance for your responses and or direction. |
10-06-2023, 10:24 AM | #2 |
Dont listen to me
795
Rep 562
there are a million threads on this topic that could keep you busy reading for a year, but I think the link below to the Apex Wheels fitment guide is fantastic. It gives all sorts of options that lets you choose what you think is right.
https://apexwheels.com/fitment-guide...-fitment-guide Tire brand/compound is entirely based on your experience and skill level, so it's never easy (or good) to blindly recommend tires to someone without knowing their talent level first. In my personal situation, I run a square 18x10 +25 offset setup with 275/35/18 Bridgestone RE71R tires. There is zero understeer in my setup, the car is really easy to rotate, and the balance leans on moderate oversteer when pushed. I feel this setup is awesome but it also makes me feel a 275 is a little narrow for a heavy car and could benefit from a wider 295+ setup. If I were going to buy track wheels and tires from scratch, I'd go up to an 18x10.5 +20 or +22 square setup with a 295/30/18 tire. But you need at least roughly -3* camber to fit that setup in the front. A 275/35/18 tire would also work great on the 10.5" wheel (depending on exact tread width of the tire brand/model).
Instagram: @thatwhitem4
MilehighM3915.00 |
10-10-2023, 01:56 AM | #3 |
Rep 9,032
Can you fit the 10.5" square with 295 tires in the back seat?
The 18x10 et25 with 275 fit snug but totally doable in the back seat. Many will run a 5mm spacer up front to clear coilovers. I love the RE71RS tires but some say the Yoko AD051 are faster but don't last long. Others swear by the NT01 and they last forever. .
11-02-2023, 11:09 AM | #4 |
Rep 645
"The best tire" is extremely dependent on your goals. Does "best" mean fastest? Supercar 3R. Does "best" mean most consistent? NT01. Does "best" mean longest lasting? ExtremeContact Force. etc.
11-02-2023, 01:23 PM | #5 |
Rep 1,292
Tire wise it really depends on your driving level and type of driving.
Are you looking for the fastest 200tw tire to set lap time? Or consistency that'll last a full session? Durability that'll last you one track season (depends how many days you a year)? Also depends on your level, some tires do mask mistakes. You want something that you can learn from. My suggestion is just try out different tires and see what you're most comfortable with. |
11-04-2023, 12:57 AM | #6 |
Engineer
51
Rep 171
If cost is a concern, I run a 17x10 ET25 Apex ARC-8. Fits over stock brakes and ST40R with the 355mm Rotor. The tires are a considerable source of weight on the rotating assembly. The closer you bring them into the middle, the less rotational force they’ll have. It just clears the stock brakes. Some decent track tires are also available as well in 275/40R17. I do not track my car but I had both 275/40R17 Conti DW’s and now I have 265/40/R17 PS4S. A good street setup.
12-17-2023, 08:10 PM | #7 |
Rep 5,548
Apex makes multiple wheel designs (arc8, EC7 and SM10 in either flow formed or forged options) that fit the e92 m3 and allow you run 295 tires. 18x10.5et22 should be a direct bolt on but may require a front wheel spacer to clear strut/spring).
BW offers their TA16 forged and TA5R flow formed wheels in either 10.5et22 or 10.5et27. Small spacers may be needed front or rear. Tires are a much harder thing to recommend because it depends on skill level, cost/per, grip level vs. heat cycles, tire weight, 295 width vs a brand’s actual 295 width, street compounds vs r compounds vs race compounds, etc. If you relatively new to tracking and/or in beginner-intermediate run groups then you definitely want to start on 200TW tires. It’s also not a bad idea to run the lower grip versions of 200 TW tires so you can develop your driving skills and get used to driving at the limit on a more forgiving tire than one that provides to warning when grip is exceeded and/or requires running at higher slip levels. |
