TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Adaptive Cruise Control Retrofit?
      02-15-2016, 05:10 PM   #45
ssshake
16
Drives: 328i coupe 2009
Has anyone completed this retrofit? I'm seriously considering it but I think the hardest part would be sourcing the parts and knowing where to install the control module. The radar and the wheel stock are likely easy.
      04-07-2016, 06:34 AM   #46
fatjoez
student
fatjoez's Avatar
226
Drives: e90
Okay guys let's make this happen.
Parts required (excluding wiring)
Sensor + Longitudinal Module
http://www.realoem.com/bmw/enUS/show...diagId=66_0118
sensor 66316777883
longitudinal module 66316775949 (03/01/2006 —) / 66316774206(9/1/2005-2/23/2007 only)
Bumper Trim
m sport bumper sensor cover 51117907077
m sport bumper centre grille for sensor cars 51117907076
Steering wheel Stalk cruise control stalk specifically for adaptive
http://www.realoem.com/bmw/enUS/show...diagId=61_3088
61319123057/61319123057 multifunction, rain sensor
"Rep. kit visual components for SZL IMPORTANT! On vehicles produced up to 10/31/2008, before ordering the steering column switch module refer to PUMA measure 28753830 as well as the repair manual REP 61 31 009."
Can someone with access to maintenance/workshop manuals please post the workshop manuals for adaptive cruise control or the ones mentioned below?
"On vehicles with optional ACC also order
installation instructions 0129 0 036 224 and template 0129 0 431 720."
What is a "template"?
      04-07-2016, 06:47 PM   #47
fatjoez
student
fatjoez's Avatar
226
Drives: e90
FYI this is standard cruise control (not adaptive)
3' E90 335i Dynamic cruise control retrofit
http://www.realoem.com/bmw/enUS/show...diagId=03_2073
It is possible to retrofit option SA544 by replacing the instrument cluster, the entire switch module and the steering column trim.
Code retrofit with Software Service Station (SSS) via "Retrofit CIP" path.
      05-12-2016, 09:12 AM   #48
ndelevic
Drives: BMW 330XD
Hi guys, I have been searching for info about this mod for a long time.
Is there any progress...?
I am also willing to start working on this but my main concern is where to find stalk with acc option. Is there a chance just to install CC stalk from e60?
      09-02-2016, 07:26 PM   #49
DimitrisM3
e90 my big fat lady!
DimitrisM3's Avatar
Greece
49
Drives: e90
Originally Posted by Patrys@BimmerTech View Post
We can help you code this retrofit if you are still thinking of doing it.
Patryk
Can work on e9x m3 ???
      09-05-2016, 11:42 PM   #50
Jaghi
18
Drives: Wraith
From my understanding ACC wasn't offered for the M3, I'm sure you can retrofit it but you will need to make custom grills and what not.
      11-08-2017, 04:07 AM   #51
JGB2010
JGB2010
Australia
Drives: 2010 E91 323i
Hi,
A bit of a long story here, sorry its on a long running thread - I have a later e91 323i (2010) which being a 6cyl came standard with $544 Dynamic Cruise. I do a LOT of hwy k's so I would like the full $541 Active Cruise. (which I have on my older E66 and love).
Being slightly later my car did not have an LDM, the cruise was all built into the DSC etc.
So, I did some research, thought - I can do this, and sourced most of the parts.
First to note is my car seemed later than the wiring diagrams I have.
I first installed the ACC sensor, fed it the appropriate signals (GND,+12V, ACC Wake Up & PT-CAN). This worked, as the sensor heated in icy temperatures, and I can log into it using NCS & INPA.
I then installed the LDM (from the same donor car) giving it too the appropriate signals (GND,12V,PT-CAN Wake Up & PT-CAN), once again, all logs in OK
At that point, I changed my VO from $544 to $541. I also changed all the 'ACC' references in units such as the KOMBI & CIC to 'aktiv'.
All ready for the first run, I engaged CC and it all seemed to work as it always did (no ACC action), after a while i looked down to see my speed holding OK, but my cruise set marker darting around spontaneously. over a few days I played around a bit more and determined that the traffic in front had no affect on the markers behavior. I haven't changed my stalk yet, I figure if I can get the cruise to work, then I'll spend the last dollars to finish the job.
I noted that the wiring diagram also showed the PT-CAN connected to the NFRM (so the cruise knows when you are indicating to change lanes), but my car had no wiring on the assigned pins, so I wired that into the bus too. The ACC still did not work. (lots of errors though - mostly PT-CAN errors, can post if it would help)
My car was then due for a service, so in it goes to BMW. On my way back to collect it, I am told that my FRM module 'died' when they connected their factory tools. I was advised it can happen when owners change parameters in module [who would have done that ] - some robust product hey? BMW Australia replaced & coded the NFRM under good will.
When I finally picked my car up and drove home, engaging the CC - I got an error 'Active Cruise Faulty - Keep Your Distance'.
So now I have no cruise control.
I changed all my coding back to original, VO and all, but my simple cruise control still will not work. I still want ACC, but now would be happy to get back DCC. Any ideas where I should look next?
I have my pre/post TRC files, but I think the issue is bigger than just searching for 'ACC' and making it aktiv
This weekend I'll check the wiring to the FRM, see what carnage BMW may have caused!
      11-08-2017, 05:38 AM   #52
ptpending
ptpending's Avatar
456
Drives: e91
you need to disconnect LDM, ACC sensor and code all modules (kombi,nfrm,dsc) according new VO
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      11-27-2017, 04:18 AM   #53
JGB2010
JGB2010
Australia
So I finally got back to having the just 544 dynamic cruise - not really sure how in the end - wasn't quite as easy as changing the vo & unplugging the LDM, but resetting dsc seemed to get it going. So now back to the ACC. I have changed my VO to 541, and I have put VIN's into the LDM & ACC. I have coded the KOMBI as much as I can see. But I still have no ACC operation, just normal cruise with braking. There is no ACC indication in the instrument cluster when cruise is in operation. The CIC ocasionally shows a cruise control failure, and the set speed marker darts up and down, like its a comms bus issue. I have 2 faults showing, D02F LDM: nominal torque request, D026 LDM : wheel torque, brake (E1). I haven't coded anything into DSC yet as I don't see anything obvious. Ive attached my DSC,KOMBI,LDM,ACC .TRCs
Back to my instrument cluster, I can make the car/ACC indicator light via INPA etc, but I noticed that realoem has different P/N for 544 DCC & 541 ACC, does anyone know if that would be stopping me from progressing?
      05-12-2018, 09:34 AM   #54
vilord
Drives: E91, Tundra, TT, SV650
Hi JGB, did you have any luck since your last post? I have recently started to get back into coding and updates on my car and this caught my interest again
      12-17-2018, 09:23 AM   #55
Elixis
37
Drives: BMW E90 335d/E39 540i/G30 540d
2003 E39 540i  [0.00]
2011 E90 335d  [0.00]
2018 G30 540d  [0.00]
Bump
      12-17-2018, 10:01 AM   #56
gamesfrager
198
Drives: 2011 328i
https://www.e90post.com/forums/showthread.php?t=1530925
      12-17-2018, 10:12 AM   #57
Elixis
37
Thanks!
      08-09-2021, 07:41 AM   #58
Onemanshow
17
Drives: BMW 330d- E39 M5 -E90 318D
Hi guys
do you know if it is possible to swap only the cruise control stick , from the regular one to the Active cruise one? , or the complete stalk MUST be replaced ?
      08-09-2021, 11:04 AM   #59
vilord
the part you have circled in the second picture is one piece that goes into the switch block circled in the first picture. you can't disconnect it without breaking it.
Jesse
      10-07-2021, 10:41 PM   #60
skmas04
Drives: bmw e90 325i
you still have it?
canada, cuise, dynamic, modification, retrofit
