BMW M3 Forum (E90 E92)
  TireRack
      04-14-2021, 05:48 PM   #727
MisterClutch888
MisterClutch888's Avatar
552
Drives: 2011 E90 M3 6MT ZCP
Originally Posted by slow4dr View Post
18x9.5/10.5 +22 5mm spacer all around 265/35 275/35
nice. i really want a set of CE28 as well. Currently have two sets as well, one set on Audi and one set on Integra Type-R. One of my all-time favourites.
Current - 2011 E90 M3, Jet Black, 6MT ZCP. Recaro/Bilstein/BBS/StopTech/Haimus/Turner/Pinnacle/BE/Auto Solutions/Macht Schnell/GC/Whiteline/Slon/Alpine
Sold - 2008 E92 M3, AW x FR, 6MT. CF roof is oh-so-Sexy!
IG @misterclutch888
Slow Build
      06-09-2021, 11:00 AM   #728
nishfish87
38
Drives: E92 M3, F85 X5M
No rubbing or trimming.
Titan5 T-S5
18x10 +25
275/35/18 Sumitomo HTR Z III
12MM Spacers
2.5 degree camber
zero toe
18x10.5 +25
Michelin PSS 295/35/18
No Spacers
2 degree camber
0.20 degree toe
Lowered on BC Racing BR coilovers with it being pretty much flush.
I do plan on replacing the Sumitomo's with PSS soon and possibly removing the spacers for fitment.
      04-04-2022, 01:29 PM   #729
Joshbot007
55
Drives: 2013 Frozen Blue M3
I have stock suspension with PS4S tires on Titan T-S5 rims
19x9.5 +22 275/30s front rubs the inner edge of the painted bumper at the 10 o'clock position.
19x10.5 +25 305/30s rear rubs the painted metal bumper at the 10 and 2 o'clock positions as well as fender liner.
I am thinking about going to a 265/30-19 front and a 295/30-19 rear to solve the rubbing but im not sure if downsizing by 10mm in the front and rear would be enough. Im wondering if I will have to go down to a 255/35-19 front and a 285/30-19 rear.
Id be fine with the rear rubbing the liner tabs a little but I cant have it rub away the painted surface of the fender.
Thoughts on if 295/30-19 will clear the actual fender in the rear?
      04-04-2022, 03:37 PM   #730
rhyary
rhyary's Avatar
Drives: 2013 M3
295/30/19 clears the rear with 22 offset
The front 255/35/19 is better than 265/30/19.
Both the 275/30 and 265/30 have too short sidewall, unless you only care about how it looks.
      07-08-2022, 07:34 PM   #731
ZachE90M3
ZachE90M3's Avatar
145
Drives: BMW M3
Anyone lowered on H&R springs with 18x9.5+15/10.5+20? Wondering what it'll take for these to work right?
      07-08-2022, 11:37 PM   #732
Ervin87
Ervin87's Avatar
Drives: E92 M3 | B5 S4 | E30
Front you can solve with some negative camber (-2.0).
Rear will be very close, if you go 295 and PS4S. I had rubbing with 10.5ET22 with this size and tire and had to go down to 285. You have 3mm more clearance, but hard to guarantee you won't rub.
      07-10-2022, 10:52 PM   #733
ZachE90M3
ZachE90M3's Avatar
145
Drives: BMW M3
Anyone?
      07-19-2022, 05:54 PM   #734
importraceram
75
Drives: 2008 E90 M3
Anyone?
Not sure about the et15 up front. What size tires? I think the 18x10.5 et20 should be ok in the rear. The reason why I say that is because I have 18x10.5 et25 in the rear with a 285/35/18 lowered on H&R springs and I am definitely going to add a 5-10mm spacer. My front is 18x9.5 et22 with 265/35/18 and it is a pretty good fit maaaaaaybe I could do a tiny little 5mm spacer but that would still put me at et17, really not sure about et15 but I suppose it depends on tire, how much camber, etc.
ZachE90M3144.50
      07-19-2022, 06:00 PM   #735
ZachE90M3
ZachE90M3's Avatar
145
Drives: BMW M3
Anyone?
Well I went with 265/35 on the front and I'm hoping it fits good. If I have to run a little more camber then oh well lol
      07-19-2022, 06:04 PM   #736
importraceram
75
Drives: 2008 E90 M3
I recently purchased some Titan 7 TS5's. Overall I like the wheels however I think the rears need just a bit of love. I read a thread from years ago, extensively, talking about these wheels with 285/35/18 tires saying that it's a perfect fitment for this platform. I honestly don't think it's terrible however I think et20 (possibly even a bit lower) would be just right. I am considering adding a spacer to the rear. Based on what you all know, and the attached pictures, should I stick at a 5mm spacer or is there room to go just a bit more? It looks like Turner Motorsports has a couple 7.5mm options. What size would you all recommend in this situation? While I want it to be aggressive, I definitely don't want it to rub. I have been there and done that (with a previous car back in the day) and my fenders did not appreciate that...
DrFerry6728.50
      09-10-2022, 01:20 AM   #737
ZachE90M3
ZachE90M3's Avatar
145
Drives: BMW M3
Don't know if this setup is on here yet but here it goes haha.
Car: 08 E90
Wheels w/ Offsets: Rays TE37SL- (F) 18x9.5 +15, (R) 18x10.5 +20
Spacers: None
Tires / Miles: Continental DWS06+ - (F) 265/35/18, (R) 285/35/18; New Tires
Suspension: H&R lowering springs (no camber plates)
EDC Setting: Normal/Sport
Alignment: haven't officially done an alignment yet (will update when I do)
Fender Modifications: (F) None (R) None
Rubbing? Installed them earlier today and haven't rubbed on anything… yet (will update if I notice any)
DrFerry6728.50
      11-24-2023, 08:28 PM   #738
JBird..
Drives: 2009 E92 M3
Just fitted square 18x10 ET25 with a 5mm spacer in the front. I also fitted Bridgestone RE71RS for my upcoming track day and do rub in the front on full lock on the front and back side of the fenders Is that expected? Do other guys run 275/30 with the RE71RSs?
      11-28-2023, 11:26 AM   #739
tsk94
tsk94's Avatar
1522
Drives: E92 M3, E82 128i, F82 M4, E36
No one runs a 275/30R18, I don't think that size even exists.
Rubbing on the fender liner at full lock with a 275/35 is common. Mine rubbed completely through to the metal on the back side. Then I did some light massaging of the metal to provide some additional clearance
m3post
