BMW M3 Forum (E90 E92)
  TireRack
      02-26-2012, 11:40 AM   #67
TysonRa
TysonRa's Avatar
Germany
32
Drives: E92 M3 Competition Package
Car: 2011 E92 Competition package (ZCP)
Wheels: 359M - (F) 19x9, (R) 19x10
Spacers: (F) 10mm (R) 12mm Macht Schnell spacers
Tires: Michelin Pilot Sport PS2
Front: 255/35/ZR19
Rear: 285/30/ZR19
Suspension: H&R springs
Rubbing: a bit rubbing at the front while full wheel turn, at the rear no rubbing at all settings, didn´t go over any speed bumps or something like that yet....
      04-28-2012, 11:30 PM   #68
ALpine11M3
Drives: '11 AW M3 Coupe
Car: 2011 e92
Wheels w/ Offsets: Niche Mach V (F) 19x9.5 +26; (R) 19x11 +33
Spacers: None
Tires / Miles: Nitto Invo (F) 275/30-19; (R) 305/30-19; New Tires
Suspension: Eibach Springs
EDC Setting: Any
Alignment: Stock
Fender Modifications: None
Rubbing: None
      05-01-2012, 01:43 AM   #69
Bob MG
Moderating
Bob MG's Avatar
United Arab Emirates
418
Drives: like a muppet
My previous ESS E92 2009
HRE P40
20x9,5 ET 22
20 x 11 ET 25
PS2
255/30/20
305/25/20
No spacers
No fender mods
No rubbing on front
Very slight rubbing on rears on big bump but didn't make a mark anywhere that I could see.
KWV3
OEM wheel alignment specs
Current E90
ZCP
Pirelli P Zero Corsa
255/35/19
285/30/19
10 mm spacer front
5mm on rear
KwV3
Slight rubbing on rears on inside liner on bumps but no hassle
      05-14-2012, 05:31 PM   #70
thurston
Germany
215
Drives: 2016 M235i
2012 E92
  • 19x9 +22, 19x10.5 +25
  • 255/35/19, 295/30/19 - Michelin PSS
  • KW V3 w/ about a finger gap
  • Camber maxed out
Front - no rubbing at all
Rear - rubs on bigger bumps with just me or two of us in the car. Rubs extremely bad with 4 people in the car
Designer & Photographer
      05-21-2012, 10:57 PM   #71
m3peat
Drives: 2009 E90 M3
Stock E92 ZCP fitment confirmation
I'm looking to put 275/30 fronts and 295/30 rears on a stock ZCP E92 wheel/suspension. Tire of choice would be either Yoko AD08's or Mich PSS's. I can use spacers if need be and will max out stock camber up front (w/ pins pulled which isn't much I understand), slight camber in rear and some rear toe-in.
I don't believe I saw a post confirming this will fit w/o rubbing. I only searched this thread though since it seemed most related.
thanks for any help
      05-22-2012, 03:06 PM   #72
ALpine11M3
This should fit without rubbing. However, thats pretty wide for factory zcp wheels, especially the AD08s which run wider than normal.
      05-23-2012, 01:49 AM   #73
m3peat
Drives: 2009 E90 M3
Thanks.
I'm doing this for an autox setup and I've run 275's on 9 and 9.5's w/o issues on my E46, so I don't see the width as a problem for the tires, just whether they rub or not.
I would go with 265/285 but the 30 series sidewall will be too short and 35 too tall.
      05-24-2012, 09:29 AM   #74
datninja
Drives: 15 F80 M3
2008 e92
HRE P40SC
20x9.5 +22, 20x10.5 +22
H&R springs
255/30/20, 285/30/20 hankooks
No rubbing
MR E92/20"HRE P40SC/Meisterschaft GT/H&R/VF620
      06-13-2012, 10:55 PM   #75
SlamMan
SlamMan's Avatar
Drives: ED 5/19/2010, Interlagos E90
I've got Yokohama Advan AD08 tires on my E90 ZCP. 265/30 and 295/30. I have Ground Control camber plates up front running about 2.5 deg camber. Stock other than that. No rubbing in font. Occasional slight rubbing in back under full compression. Great tires.
I play real sports. Not tryin' to be the best at exercising. - Kenny Powers
      06-23-2012, 12:41 AM   #76
Drifty//
Drives: A4 quattro 3.2 MT6; E92 6MT
Originally Posted by dcstep View Post
Car: 2009 E92
Wheels: APEX ARC-8 (F) 18x10 +25, (R) 18x10 +25
Spacers: None
Tires / Miles: Dunlop Direzza Star Spec (F) 275/35-18, (R) 275/35-18
Suspension: Dinan Stage 1 plus Dinan Camber plates
EDC Settings: All
Alignment: (F) -2 degrees camber (R) -1.7 degrees
Fender Modifications: (F) None. (R) None
Rubbing?: (F) None. (R) none.
Car: 2008 E92
Suspension: Ground Control camber plates
Alignment: (F) -2.5 degrees camber (R) -1.5 degrees
Rubbing?: (F) YES! (R) none.
Everything else is the same. Front also rubbed before camber plates & alignment.
      06-23-2012, 07:02 PM   #77
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [8.40]
Originally Posted by Drifty// View Post
Car: 2008 E92
Wierd. What springs?
I've got the Dinan springs and Dinan plates.
Dave
      06-23-2012, 08:50 PM   #78
Drifty//
Stock springs.
The front tires rub against the rear wall of the wheel wells, starting a bit past half of the steering range. Plenty of room in front of the tires & no indication of rubbing against the top of the wheel wells.
      06-23-2012, 10:15 PM   #79
dcstep
2009 M3  [8.40]
Stock springs.
The front tires rub against the rear wall of the wheel wells, starting at about 1/3rd of the steering range. Plenty of room in front of the tires & no indication of rubbing against the top of the wheel wells.
I have no idea. I'm lowered and cambered (just under -2 degrees) and don't touch anywhere. I've got around 6,000 miles on this setup, including around around 60 autocross laps.
Dave
      06-24-2012, 02:02 AM   #80
BPMSport
BPMSport's Avatar
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
2008 E90
BBS LM
19x11 Rear, ET 25 275/35/19
19x10 Front, ET 25 255/35/19
Michelin PSS all around
No spacers, and no rubbing at all, even with 5 people in the car
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      06-26-2012, 11:57 PM   #81
m3peat
Drives: 2009 E90 M3
Did you consider the 275/30's up front?
      06-27-2012, 09:15 AM   #82
THE TECH
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Originally Posted by Mike Benvo View Post
2008 E90
BBS LM
      06-28-2012, 03:44 PM   #83
Archiebabes
Drives: F90 M5, Huracan EVO, R35 GTR
Anybody here running the same setup below without any rubbing issues?
Lowered on RD Sport Springs
Volk TE37 SL's
Front - 19x9.5 +21 - 265/35/19 tires Nitto Invo or Michelin PS2's
Rear - 19x10.5 +22 - 285/35/19 tires Nitto Invo or Michelin PS2's
Thanks
      06-28-2012, 03:45 PM   #84
THE TECH
THE TECH's Avatar
307
Volk TE37 SL's
Thanks
One of the questions that people will ask is what tire?
      06-28-2012, 04:02 PM   #85
Archiebabes
Nitto Invo's or Michelin PS2's
Thanks
      06-28-2012, 04:10 PM   #86
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
265/30 285/30 works ok. Main issue I see with the 265/35 is the increase in outside diameter which could rub the fender liner.
Invo comes in 265/30 285/30 but PS2 does not
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      06-28-2012, 08:30 PM   #87
THE TECH
THE TECH's Avatar
307
I'm hoping my 275/30 and 305/30 19 PSS don't rub when I get them on.
      07-10-2012, 08:23 PM   #88
BAMFM3
BAMFM3's Avatar
67
Drives: 2022 Audi SQ5
Car: 2009 E92 M3
Wheels: Breyton Race GTS (F) 20x8.5 +35 (R) 20x10 +35
Spacers: Yes, size unkown. Appears to be 5-10mm Front, 18-20mm rear.
Tires / Miles: Yokohana S.Drive (F) 255/30/20 (R) 275/30/20
Suspension: H&R Race Lowering Springs
EDC Settings: N/A
Alignment: (F) UNK (R) UNK
Rubbing?: (F) Very minimal inside the fender liner around where everyone gets it. 40k miles on car and again, rubbing looks very minor. (R) None
I plan on swapping the Breytons out, as they came on the car and I want to go 19"....probably the OEM ZCP 359 wheels. As long as I keep the diameter of the tires the same on the 19's, stance on the car should be unchanged, correct? And if I go 245/35/19 in the front, it should eliminate the rubbing I am currently getting? Will probably go with 275/35/19 in the rear with the ZCPs as I'm not having any issues at the current moment and seems others are okay with it.
22 Florett Silver SQ5
13 Silverstone II E92 M3 (Sold)
19 Shadow Black Shelby GT350 (Sold)
13 Mineral White E92 M3 (Sold)
11 Melbourne Red E92 M3 (Sold)
m3post
