BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW F30 3 Series Coding DIY - Code Auto Start Stop, DVD, Folding Mirrors, Etc.
Extreme Powerhouse
      10-11-2014, 04:44 PM   #7415
MdW86
83
Drives: Bmw f30 320i 2012
The heating of the rear window is temperature controlled i believe. Therefore if its 15 degrees Celsius outside, removing condensation goes really slow. Any idea how to code the temperature of the heating element?
      10-12-2014, 10:38 AM   #7416
AndyGB
Drives: F10
Hi Shawn,
Could I have the e-sys and pdszdata links please - 2014 F10
Many thanks
      10-12-2014, 10:40 AM   #7417
WeaselCMC
Drives: BMW F30 SE 2013
Dear, shawnsheridan.
Can I have coding software for f30 320i 2013 too?
      10-12-2014, 12:41 PM   #7418
shawnsheridan
General
shawnsheridan's Avatar
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      10-12-2014, 12:43 PM   #7419
Moovrr
Drives: BMW M140i F21
Launch Control
Originally Posted by shawnsheridan View Post
The car's EGS Control Unit need's >= 50.4 firmware for Launch Control. Just having >= 50.4 PSdZData doesn't mean you can code the feature if the car has < 50.4 firmware. You would first have to flash new firmware onto EGS, and then code it.
PM sent.
I think I need to flash my EGS firmware to enable the 'EGS, 3000 Applikation, Funktionen, LC=aktiv already set which doesn't seem to work with my current I-step version F020-13-03-502. I have read the process to flash here http://f30.bimmerpost.com/forums/sho...5&postcount=13 and I assume I just replace the last steps to check the right ECU's ID Base rows with the EGS row check boxes (first question)?
And could someone pm me the right I-step firmware version to flash the EGS module please (second question)?
I have E-sys 3.24.3.
Thanks
      10-12-2014, 02:39 PM   #7420
shawnsheridan
General
Thanks
Yes, just make the checkboxes in TAL for EGS.
Use the latest 53.5 firmware. PM sent.
      10-12-2014, 03:37 PM   #7421
doppler
Drives: 2018 i3s
Hi,
Can I get the e-sys and pdszdata download links please?
I've got a 2014 F22 M235i.
Thanks!
      10-12-2014, 03:39 PM   #7422
shawnsheridan
General
Originally Posted by doppler View Post
Hi,
Thanks!
PM sent.
      10-12-2014, 03:48 PM   #7423
__mkw
Poland
Drives: F30
I am trying to code BMW 328i from USA to ECE.
How important is parameter in FAList->FZAuftrag->Type->Typshlussel.
In my car this looks like this:
In google I found list of codes, separate for USA, Europe, UK, Japan etc.
http://www.bmwarchiv.de/e-code/f30.html
3A51 328i Limousine N20B20O0 180kW Heckantrieb links Europa
3A52 328i Limousine N20B20O0 180kW Heckantrieb rechts Europa
3A53 328i Limousine N20B20O0 180kW Heckantrieb links USA
3A54 328i Limousine N20B20O0 180kW Heckantrieb links China
3A55 328i Limousine N20B20O0 180kW Heckantrieb links Europa
3A56 328i Limousine N20B20O0 180kW Heckantrieb rechts Europa
3A57 328i Limousine N20B20O0 180kW Heckantrieb links USA
3A58 328i Limousine N20B20O0 180kW Heckantrieb rechts Malaysia
3A59 328i Limousine N20B20O0 180kW Heckantrieb links Russland
Is coding car form USA to ECE need Typshlussel change ?
      10-12-2014, 03:53 PM   #7424
Moovrr
Thank you Shawn, you're golden.
      10-12-2014, 03:59 PM   #7425
shawnsheridan
General
Originally Posted by __mkw View Post
...Is coding car form USA to ECE need Typshlussel change ?
It is critical to set Typshlussel = xxxx correctly.
What is your factory ECE Typshlussel?
      10-12-2014, 04:05 PM   #7426
__mkw
Poland
Drives: F30
Now it's 3A57 - USA Typshlussel
for ECE it's should be 3A55.
Is it safe to change 3A57 -> 3A55 and then code the whole car ?
      10-12-2014, 04:32 PM   #7427
shawnsheridan
General
I have done certain modules before, but not the entire car, and it is safe so long as you use correct equivalent Typshlussel.
I don't think your list is correct though as I am pretty sure:
3A55 = F30 325I ECE LL (3A55) [from=0309]
3A57 = F30 328I US LL (3A57) [from=0309]
I think you need to use:
3A71 = F30 328I ECE LL (3A71) [from=0309]
      10-12-2014, 05:02 PM   #7428
__mkw
Poland
Drives: F30
Are You sure about this ?
In Vin number is part of Typshlussel, my car vin is: WBA3A5G58.
I found a europe BMW 328i vin number: WBA3A51020FZ99737
in vin decoder:
Model description: 328i
Market: Europa
Type: 3A51
E-Code: F30
Chassis: Limousine
Steering: links
Engine: N20B20O0 - 2,00l (180kW)
Drive: Heckantrieb
Transmission: automatisch
Production date: 02.11.2011
      10-12-2014, 07:38 PM   #7429
shawnsheridan
General
You are correct. So, the BMW database I am using must have a mistake in it.
      10-13-2014, 04:04 AM   #7430
AndyGB
Drives: F10
Hi Shawn,
Many thanks
      10-13-2014, 06:27 AM   #7431
shawnsheridan
General
Originally Posted by AndyGB View Post
Hi Shawn,
Many thanks
PM sent.
      10-13-2014, 07:44 AM   #7432
JRGN
Drives: 320d M (f30)
Hi , I can Pass the link to coding one 320d f30 purchased in July 2014 .
Thank you .
      10-13-2014, 11:35 AM   #7433
shawnsheridan
General
Thank you .
PM sent.
      10-13-2014, 01:38 PM   #7434
MdW86
83
FEM_BODY-> 30D0 remotecontrol, 13 -> Funktionen-> RC_default_IDG_3rd_button_short
It looks like you can programme 2 opening bootlid, 3 panic alarm, or 4 follow me home.
Medium and long passing of 3rd button on the remote are programmed to open the bootlid.
Has anyone tried to program to follow me home with the remote?
Edit: or anyone tried RC_ENABLE_CONFIG_BUTTONS. This should activate 'configuration of the 3rd button via the idrive menu'
      10-14-2014, 09:54 AM   #7435
carzaddict
Drives: 2015 Cadillac Escalade ESV
has anyone been able to figure out coding for the "welcome lighting" ?
I hate that it turns into a warm blue once I open the door...I want to keep it cold blue
2015i Cadillac Escalade ESV
      10-15-2014, 09:01 AM   #7436
Rxpert
Rxpert's Avatar
187
Drives: 2018 F80 M3 ZCP 6 Speed Manual
Hi Shawn,
I just started coding for the first time and am using the 53.3 data which you sent me awhile back. Since then my car had the MPPK installed and the dealership reset/updated my system.
Can I continue to use 53.3 or should I upgrade to 53.5? (Running E-Sys 3.24.3)
If it's the latter can you PM me the updated version?
Thanks in advance!
3 series coding, 3 series f30, 3 series f30 coding, 3 series f30 forum, 3 series forum, 3-series forum, 5 series f10 coding, ass, ass disable, auto start stop, auto start stop disable, bmw 3 series coding, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw 5 series coding, bmw auto start stop disable, bmw auto start stop disabling, bmw coding, bmw coding directions, bmw coding diy, bmw coding instructions, bmw diy, bmw diy forum, bmw f10 coding, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 coding, bmw f30 forum, coding 3 series, coding f30, coding f30 3 series, disable ass, disable auto start stop, disable bmw auto start stop, disabling auto start stop, disabling bmw auto start stop, f10 5 series coding, f10 coding, f30 3 series, f30 3 series coding, f30 3 series forum, f30 3-series, f30 3-series forum, f30 coding, f30 forum, f30 forums
