05-02-2015, 07:45 AM | #8559 |
24
Rep 179
I deleted my previous post. Might have hold the connector the wrong way when measureing, haha.
But anyways, here's the one I bought. http://www.one-stop-electronics.com/...&product_id=21 |
05-02-2015, 07:50 AM | #8560 | |
General
10445
Rep 40,789
05-02-2015, 08:00 AM | #8561 |
24
Rep 179
While I'm waiting for e-sys to install on the other computer, I'll think I'll check the Diagnostic Port fuse.. If there is a fuse for that one? remember I had an fuse for that in my old E46.
05-02-2015, 08:03 AM | #8562 |
General
10445
Rep 40,789
Yes, it should be fused.
05-02-2015, 08:13 AM | #8563 |
24
Rep 179
OBD had fuses 18, 28 and 42 (Fuse Box in engine bay. In case someone was wondering). All good.
EDIT: I have now tryed with another computer with a fresh install of E-sys. And the problem still remains. Nothing happens on computer when plugged to car, and no link light in the RJ45 port on the computer.. Do I need to set{configure a new wired connection? Any good guides to troubleshoot the OBD port in the car? Fuses was good. Find it hard to belive that the OBD port is bad... Last edited by Sleepwalker; 05-02-2015 at 09:27 AM.. |
05-03-2015, 02:14 AM | #8564 |
24
Rep 179
Could It be power issues? I have my car running while trying to make a connection, It reads 14,3 at the battery posts. So it should be enough.
Is battery charger a better way to go? Don't have one, so haven't been able to try. There is only one obd port in our cars, right? (drivers side foot well) |
05-03-2015, 03:10 AM | #8565 | |
General
10445
Rep 40,789
And yes, only the one OBD Port.
05-03-2015, 03:23 AM | #8566 |
24
Rep 179
05-03-2015, 03:35 AM | #8567 | |
General
10445
Rep 40,789
Is your LAN Adapter taking a 169.254.xxx.xxx IP Address when connected?
05-03-2015, 05:33 AM | #8568 | |
Rep 22
Is it the wireless connection set to off? Try to use (from command prompt) ipconfig, and check what ip address is setup from the lan adapter, as showed by shawn it has to begin with a local area network ip range family. |
05-03-2015, 01:24 PM | #8569 |
16
Rep 16
Hi Shawn,
Could you please send me a PM with all the info I need to start coding F11 2011? I have the cable, but prettymuch everything else I will need.. Thanks a lot for all the great work you've done on this! Tor |
05-03-2015, 01:27 PM | #8570 |
General
10445
Rep 40,789
PM sent.
05-03-2015, 01:50 PM | #8571 | |
24
Rep 179
Yes, firewall is disabled, and the computer doesn't have any anti-virus. |
05-03-2015, 02:29 PM | #8572 | |
Rep 1,892
Basically, are you sure the Ethernet port (RJ45) on the laptop is working? |
05-03-2015, 03:50 PM | #8573 |
24
Rep 179
05-03-2015, 07:03 PM | #8574 |
General
10445
Rep 40,789
I do not ask abut the Light. I want to know if you actually checked the LAN Adapter Status to see if it has an IPv4 Address assigned.
05-04-2015, 02:15 AM | #8575 |
24
Rep 179
05-04-2015, 04:50 AM | #8576 |
General
10445
Rep 40,789
I don't know. You need to start swapping out Laptop and Cable to narrow down where the issue is. No other way at this point.
05-04-2015, 09:30 AM | #8577 |
24
Rep 179
Did some measuring of the cable again. All is good (ohmed pins on OBD connector and RJ45) except pin 4 and 5 that should be bridged according to the ENET Cable DIY. I get nothing when I ohm pin 4 and 5 on the OBD connector.
05-04-2015, 09:49 AM | #8578 | |
General
10445
Rep 40,789
I think there is an issue with that laptop and it's Network Settings.
05-04-2015, 10:02 AM | #8579 |
24
Rep 179
But my problem is the same with my other laptop too (Have tryed two different laptops) One is running windows 7 and the other one is running windows 8. IPv4 is set to dynamic on both of them. And both have no issues connecting to a normal wired network.
05-04-2015, 10:34 AM | #8580 | |
General
10445
Rep 40,789
But, if it is not the Laptop, and not cable, only thing left is FEM_GW in the car. So, what you really need is another F-Series car to connect to, and see at least if problem is on car side, or cable / laptop side.
