BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > M3 Photos/Video/Media Gallery
Mporium BMW
      04-25-2011, 11:40 PM   #1
datbimmerdoe
datbimmerdoe's Avatar
Drives: like I'M BOUT THAT LIFE
[ fire orange | e92 | arkym | hre p43s | brembo ]
UPDATED: more pix + article, scroll down.
@ hre wheels booth - mfest v vegas
-fire orange e92 m3 dct
-hre p43s (f:19x9.5 255/35 - r:19x10.5 295/30)
-kw clubsport
-brembo bbk
-arkym front bumper
-arkym trunk
-arkym rear diff
-cf splitter
-ipe innotech f1 exhaust
-ess vt2-650 supercharger
PIX C/O: 1013MM & anthony@eas
whose e92 is this?
associated directly with Arkym
update 1/11/2012
Article & Photos by Zachary Mayne - link: www.bimmer-mag.com
AGENT ORANGE
Fire Orange paint and bold HRE wheels make this M3 a bravura showcase for Arkym's sexy bodywork.
A 604-hp supercharger from ESS makes it an ultra-intense driving experience, as well.
With its ground-scraping stance, black HRE alloy wheels and retina-searing Fire Orange paint, this project M3 would be expected to
have an audible bark to match its visual bite. Push the Start button, however, and the BMW’s engine comes to life with a distinctively
stock-sounding exhaust note.
Huh? Where’s the boisterous noise we’ve come to expect from heavily modified M3s like this one?
Oh, it’s there. All you have to do is press this little button on the remote and blam! Hidden valves open in all four exhaust pipes,
allowing the uncorked roar of the S65 V8 to be heard in all its glory.
It’s a brilliant idea when you think about it. Loud exhausts are fun and exhilarating…to a point. The point at which they become
decidedly un-fun may be when you drive past a police officer who eyes you suspiciously, or when you want to park
in front of a restaurant without shattering the windows along the sidewalk.
With this M3’s iPE Innotech Valvetronic F1 exhaust system, a simple press of a button reduces the engine note to a polite burble,
one that’s quiet enough to convince the local constables that your taste for bright orange cars doesn’t necessarily mean you’re a speed-addicted lunatic.
But let’s be realistic: If you’re driving an M3, you probably are a speed-addicted lunatic, something that’s most definitely true
if you’re driving this particular M3. Masterminded by Arkym, a relatively new company that specializes in aerodynamic body parts for BMWs,
the car has been built to showcase those parts as well as the tuning philosophy behind them.
Fire Orange firebreather
Painted in Fire Orange, the same color used by BMW on the Euro-only M3 GTS, the car’s stock front bumper has been replaced with
Arkym’s AeroRace carbon fiber bumper, which features an integrated carbon splitter as well as aggressive side intakes
that arc upwards from the outside before diving back towards the center opening. At the rear, its stock trunk lid was binned in favor of
an AeroRace carbon fiber equivalent and its stock rear bumper complemented by Arkym’s carbon fiber diffuser.
HRE supplied a set of P43S alloy wheels, which measure 10.5x19 inches at all four corners and are wrapped with Toyo Proxes 1 tires
that measure 255/35ZR-19 at the front and 295/30ZR-19 at the rear. A Brembo big brake kit uses 380mm rotors at all four corners in conjunction with
six-piston calipers, while a set of KW Clubsport coilovers allow ride height and damping rates to be dialed in precisely for a variety of conditions.
While those mods might be enough for some companies, Arkym wanted to make sure its M3 was as fast as it looked,
so the bodywork manufacturer turned to ESS Tuning for help under the hood. Founded in the Netherlands in 1995, ESS produced
a scant 30 supercharger systems for BMWs in its first year.
Before long, however, the company’s products started attracting attention from enthusiasts in the U.K., Germany and even the U.S.,
though ESS didn’t officially import its products here until 2005. Once that process began, the response was so positive that ESS set up
a North American headquarters in Chandler, Arizona in 2008. According to Roman Zepeda, head of marketing for the company’s U.S. division,
ESS currently offers a comprehensive line of supercharger systems and other power-enhancing components for BMWs and other makes.
When the E90/92 M3 was launched in Europe in 2007, ESS developed a forced induction kit to augment the car’s high-revving,
414-hp V8, first with the 575-crankshaft hp VT2-575 and then with the 600-hp VT2-600 kit. While the crew at Arkym could have installed one of these systems,
they went one better and cajoled ESS into delivering a prototype of the even-more-powerful VT2-650,
which wasn’t yet available to the public and was the only one of its kind in North America at the time of our test.
A removable supercharger suits a split personality M3
Like the more conservative systems, the VT2-650 uses a Vortech V3Si centrifugal supercharger, the same unit found on all of the company’s
late-model supercharger systems. Inhalation takes place through a high-flow K&N filter attached to a cast plastic high-temperature
supercharger intake, which delivers air to ESS’ cast aluminum intake manifold with integrated velocity stacks;
on the Arkym M3, this part is wrapped in carbon fiber weave for an improved appearance.
Since it’s a complete kit, the VT2-650 also includes high-temperature hoses and custom-milled CNC brackets that allow the supercharger to
be installed and removed without permanent modifications. A high-capacity liquid intercooler ensures adequate cooling while a compact Vortech
Maxflow Racing blow-off valve relieves excess pressure. Eight higher-capacity Bosch fuel injectors fulfill the need for additional fuel according to ESS’
recalibrated software settings, which also remove BMW’s 155-mph top-speed governor. The kit also includes a 100,000-mile drive belt with
additional OEM rollers and a sturdier crankshaft pulley designed to work specifically with the VT2-650, plus an ESS oil breather assembly.
Spent gases exit through the aforementioned iPE Innotech Valvetronic F1 switchable exhaust. Constructed of stainless steel,
the system allows one of three settings—On, Off or Auto—to be selected by remote control from the car’s interior.
In the On setting, valves close off two of the four pipes, resulting in a quieter exhaust note suitable for normal driving. In Auto, the exhaust is controlled
by the engine’s throttle position sensor—if the driver opens the throttle fully, the valves in the exhaust automatically open and the sound of the exhaust
goes from muffled street car to full-bore race car. In the Off setting, the exhaust valves open up completely and stay open,
making the Arkym M3 sound like a race car from idle to redline.
(Note: This exhaust system is for “off-road use” only—i.e. for track use only—in part because it lacks catalytic convertors. Though we tested it on the street, we do not endorse the use of “off-road only”
parts on BMWs being driven on the street, especially when they remove the catalytic converters that help ensure clean air for everyone.)
When ESS dyno-tested the finished car, the VT-650 exceeded all expectations, producing 604 horsepower at the wheels. Take into account a 15%
driveline loss and crank horsepower is close to 700—a big increase over the stock engine’s 417-hp EU/404-hp U.S. output.
As effective as it is, the supercharger itself is scarcely audible, leaving little to give the game away so long as the driver goes easy on the throttle
while leaving the exhaust in the Off position and the “M” button unpressed. Switch the exhaust valves to Off and press that little “M” button on the dash,
however, and the equation is altered drastically, resulting in the most intense modified M3 I’ve ever experienced.
A demented level of acceleration
Put simply, this BMW delivers a demented level of acceleration. As I pull onto one of the bridges that arc into and out of downtown Los Angeles,
a full dose of throttle has the M3 lunging down the road, pinning me back in the seat. Pulling DCT’s left paddle for a lightning-fast upshift allows
the acceleration to continue unabated as the tires squirm for traction and the rear of the car wiggles in protest—or is that joy? Even though the Toyo tires
and KW Clubsport coilovers deliver sky-high grip, it’s still possible to detach the tires from terra firma with an aggressive dose of throttle.
As engine speeds approach redline, the quick-revving S65 V8 engine uncorks an incredibly hard-edged and raspy howl. It’s as loud as an ALMS racer,
the sound echoing off nearby buildings as if they were the concrete barriers at the Long Beach GP.
Honestly, the combination of relentless, internal organ-rearranging acceleration and staccato engine note is so intense that words can hardly describe it.
Somewhat ironically, this M3 remains an easy car to drive at any speed thanks to its confidence-inspiring handling and quick steering response.
That said, this is definitely one of those road tests that really should have taken place on a race track. There’s no way to explore this car’s
true capabilities on a public road, especially one crowded with errant drivers in minivans and local police with prying eyes and blank ticket books.
As inadequate as it is, our spell behind the wheel offered sufficient proof that ESS delivers on its promise of huge power with no loss of driveability.
It’s a good match for Arkym’s modifications to the body and chassis, ensuring that this M3 goes as fast as it looks without sacrificing
the essential balance that makes these cars so fun to drive in the first place.
#datbimmerdoe #thatbimmertho
FOLLOW @datbimmerdoe on INSTAGRAM
Last edited by datbimmerdoe; 01-11-2012 at 05:13 AM.. Reason: add article + more pixxx
      04-25-2011, 11:48 PM   #2
TK-421
Registered Sex Offender
Drives: E46 M3 | 1JZ S13
WOW
      04-26-2011, 12:02 AM   #3
Crazy Bimmer
The Jesal
Crazy Bimmer's Avatar
Drives: E90 M3
2009 BMW M3  [0.00]
Love that front bumper.
2009 E90 M3 - SOLD
      04-26-2011, 12:02 AM   #4
saeedg48
Drives: Porsche 991.1 GT3
more pictures of that sparkling graphite m3 please.
the orange one looks great too but i've got a sg m3 that's why i ask
2015 Porsche 991.1 GT3
2015 F80 M3 -- Individual; Space Grey
      04-26-2011, 12:02 AM   #5
808E90
808E90
808E90's Avatar
Drives: E90 ///M
Nice ... Darren's E90 335 is sick too!!!
LTMW FTL . Karbonwerks LCI Trunk . Vorsteiner Poly Front Lip . NA Motorsports LUX H8 . RECARO Pole Position Seats . BMW Performance Pedals . BMW Performance Performance Grills . BMW Painted Fender Grills . BBS 19x9.5 19x11 LMs . Michelin PS2 265/295 . H&R Sport Springs . Wheel Mate 45/55MM Stud Kit . BBS Red Lug Nuts . ESS VT1 Supercharger . Akrapovic GT4 Exhaust
      04-26-2011, 12:04 AM   #6
KRUZNM3
193
Drives: F80 M3
thats a sick m3!!
      04-26-2011, 12:08 AM   #7
991brothers
991brothers's Avatar
Drives: GT3 RS
I just noticed that the gray m3 is a 335i. Gosh it looks soooo nice!
Currently: 2019 991.2 GT3 RS Lizard - 2016 991.1 GT3 RS Lava - 2019 991.2 GTS
SOLD:
2022 BMW M5 Competition - 2016 GT3 RS UltraViolet -2018 GT3 Chalk - 2016 GT3 Lava - 2015 GT3 Guards Red - 2018 Audi RS7 - 2016 F80 M3 - 2015 GT3 Black - 2015 GT3 Carrara White - 2016 991.1 GTS - 2012 997.2 GTS Cabriolet - 2011 E92 M3 - 2006 E46 M3
      04-26-2011, 12:09 AM   #8
Stormtroooper
The General
Stormtroooper's Avatar
34
Drives: 2018 M3CS
2011.5 M3  [10.00]
Really like that front bumper. I'm on the fence about the wheels tho.
E92 M3
2011.5 AW / DCT / ZCV / ZP2 / Heated Seats (SOLD)
2018 M3CS
      04-26-2011, 12:14 AM   #9
biglare
Bulldog
biglare's Avatar
Drives: BMW & Porsche
Fire Orange is SICK!
Saw it driving back from MFest on Saturday and looks great rolling at speed on the highway!
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS
      04-26-2011, 12:26 AM   #10
xquisit
xquisit's Avatar
112
Drives: 328i / R32 / 1.8T
I dig that orange color so much, and that front bumper is starting to grow on me!
I've never seen those wheels in that size (only seen them in 18"), and they look good with the orange BBK.
IMHO, the car would look dope with some gloss black side mirror covers + tinted m3 side-marker
[N51]BMW Perf. Grilles - Debadge - AA exhaust - OEM M Sport front bumper {Euro Style: Reflectors shaved off} - Medium tint - Custom Headlights - BBS LM Reps 19x8 ET32 19x10 ET30 [LCI]
      04-26-2011, 12:58 AM   #11
ooowowizstev
Drives: '08 E92 M3
2008 BMW E92 M3  [10.00]
Love it.
'08 E92 ///M3 - AW/BLK/CF, M-DCT, 19's
H&R, Vorsteiner, Eisenmann, BMC, BBS More to come...
      04-26-2011, 01:48 AM   #12
M3_WC
Drives: M3
Someone give this car a proper photo shoot, NOW!
      04-26-2011, 01:53 AM   #13
xchosun1x
Track Duty
xchosun1x's Avatar
Drives: Track build 08 E92 M3 DCT
honestly everything about the car is really nice. the pictures don't do justice to the car.
everything from the body mods, paint, wheels and brakes were immaculate and well put together.
      04-26-2011, 01:59 AM   #14
saeedg48
Originally Posted by the infamous... View Post
e90 335i's color is porsche gt3 rs grey: http://www.e90post.com/forums/showthread.php?t=500419
      04-26-2011, 02:11 AM   #15
xquisit
xquisit's Avatar
112
^ That Porsche grey is nutty! He made a great choice.
      04-26-2011, 02:17 AM   #16
dlouie87
dlouie87's Avatar
31
Drives: 2007 AW 335i e90
sicck!
      04-26-2011, 02:32 AM   #17
Maseroche
Maseroche's Avatar
Bahrain
55
Drives: '12 BMW M3
2012 BMW M3  [0.00]
Love how that Grey looks!
Khalid
'12 BMW E92 M3
'03 BMW E46 M3
'14 Mercedes-Benz S400
'18 Alfa Romeo Giulia Quadrifoglio
      04-26-2011, 04:40 AM   #18
Jameson@Alpine
Jameson@Alpine's Avatar
98
Drives: BMW
not too many cars made me say "wow!" till I saw this one. I really loved everything about it. Car looks awesome. that orange is sweet overall!
      04-26-2011, 05:24 AM   #19
JSCO
JSCO's Avatar
Drives: AMG GT
Glad you posted this....I thought Mfest 5 was this past weekend...why hasn't anyone posted pics?
      04-26-2011, 05:42 AM   #20
xquisit
xquisit's Avatar
112
This!
      04-26-2011, 05:44 AM   #21
NYCMCBM3
NYCMCBM3's Avatar
167
Drives: 2012 MCB E92 M3
both cars look sick!
2012 MCB///M3
      04-26-2011, 09:15 AM   #22
GOLFFRR
GOLFFRR's Avatar
10823
Drives: GOLFFRR cart
yea saw that thing at mfest it was sick, def on the bright side but still liked it
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
arkym, arkym e92 m3, arkym m3, brembo, e92, ess supercharger, fire orange, hre p43s
m3post
