BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Retrofit rear footwell lights?
GetBMWParts
      12-25-2023, 08:24 PM   #1
ThatLennyBoi
ThatLennyBoi's Avatar
Drives: Bmw f30
Hey everyone, has anyone actually tried to add footwell lighting for the rear like you see in the G20? I got light package and suddenly wondering, what if i just add rear footwell lights too... I thought it would be pretty cool for the F30 to also have the ambient lighting, i never seen anyone do it and don't want to buy those silly rgb strips. The thing is i haven't been able to put my head under the seat to see if there is some kind of mounting point which i doubt. If nobody has tried this, well then i'm stepping forward to say i'm going to this and perhaps make a guide how i will do it, i assume i just make wiring acording to the diagram, then use a Y cable to avoid cutting cables or taking pins out so it basically plugs in cleanly, this is probably the same method i'm going to go for the pillar ambient lights and other lights in the future. Here is an example of what i'm going to try:
      12-26-2023, 03:15 AM   #2
mrpingu
Norway
191
Drives: 2018 F48 X1 xDrive 18D
Not so long ago i took a picture of my f48 sport Seat from the underside. Hope it helps 😊
Retrofits done: 2TB, 235, 313, 430, 459, 508, 5DP 322
mig283040.50
      12-26-2023, 04:46 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
It would be easy to get power from the wires going to the console outlet, running them to LED lamps installed under the seats.
      12-26-2023, 05:32 PM   #4
ThatLennyBoi
Drives: Bmw f30
Thank you so much!
      12-29-2023, 10:26 PM   #5
eff32fl
eff32fl's Avatar
1076
Drives: 2019 440i M Sport THP MPPSK
You would need 2 of these they're the footwell ambient lighting modules.
https://www.realoem.com/bmw/enUS/par...&q=63319242161
You would have to find a 5V power source nearby and either make or buy a Y cable for each side.
      01-04-2024, 02:44 PM   #6
Badurson
Drives: BMW E60
I have actually done it some time ago. They are working separately from front and they include orange/white ambient. I will take some pictures tomorrow and share them
ambient, diy, f30, lights, retrofit
