BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
Mporium BMW
      11-07-2020, 12:14 PM   #1
GrauM3
Drives: BMW M3
Starter or ground strap?
im having a very specific problem with my e92 M3.
The car starts perfectly fine on mornings where the temperature is above 45°F, after sitting all night. On cold mornings is where i seem to have the issues.
The car does not even attempt to start if it is too cold in the morning. But once it starts it has no problem starting for the rest of the day no matter how cold it is. Im leaning towards the solenoid in the starter going bad but someone had suggested the ground strap as a potential culprit as the metal can expand and contract in different temperatures, possibly moving the connection. I just had the strap mentioned to me and have not had a chance to look at the condition of the strap just yet.
Just trying to see if anyone else has had a similar problems and could offer any solutions.
Thanks!
      11-07-2020, 05:19 PM   #2
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
One is really easy to test.
      11-08-2020, 10:33 PM   #3
TX
Drives: 2009 ///M3 E92 APW 6MT
Since you mentioned temperature, I would check the battery. If it's a cold morning and your battery is on the edge it might throw in the towel.
      11-09-2020, 12:18 AM   #4
DanMpower
DanMpower's Avatar
Drives: BMW M3s and a Red VW
Thanks!
Put a trickle charger on the battery on those cold days, go out and try to start it in the cold morning. If it fires up perfectly, it's your battery.
tsk941525.00
      11-09-2020, 05:49 AM   #5
pbonsalb
Use a jumper cable only as a 2nd ground and see if that helps the cold start.
      01-28-2022, 03:01 PM   #6
Idfkman
Idfkman's Avatar
473
Drives: F80 M3
Thanks!
Ever find a solution to this? Having a similar issue.
Here’s an example:
https://share.icloud.com/photos/07ac0ndVDOFNLgevicnt1z7wA#Laurel
      01-28-2022, 04:08 PM   #7
Scrippy
Lord Scrip
Scrippy's Avatar
Drives: 2011 M3 Coupe
  [0.00]
2007 BMW 335i  [0.00]
Which one is that? Weird that you say that and offer him zero insight.
      01-28-2022, 04:42 PM   #8
JPSurratt2005
93
Drives: 2009 E92 M3 DCT
I've replaced my ground strap and still had the cold weather issue, and a few warm days as well.
      01-28-2022, 06:59 PM   #9
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
Can anyone tell me the length of the ground strap, connector to connector?
      01-28-2022, 07:38 PM   #10
Idfkman
Idfkman's Avatar
473
Drives: F80 M3
Here are the part numbers for the ground cables
At starter - 12427840580
At exhaust - 12427840591
Full kit - 12427840580KT
10 E90 M3 /// Dinan Intake, X Pipe, Exhaust, Underdrive, 3.62 Diff, Coilovers, Alpine e85 Tune - sold
16 F80 M3 /// MaxPSI 4 Pin, DP, CP, SL Mid-Pipe, TMIC, KW HAS, EU5's, AB Performance Flex Tuned
Bubbles2753.00
      01-28-2022, 11:38 PM   #11
Redd
Yeah no one keeps stock of these here. So I was looking for generic, that's why need the length.
Idfkman473.00
      02-03-2022, 10:53 AM   #12
pjk380
pjk380's Avatar
88
Drives: 2010 E92 M3
I picked up the ground strap, the one at the exhaust and have not installed it just yet. It measures 11 5/8" from center of the bolt hole to bolt hole.
Idfkman473.00
      02-03-2022, 06:03 PM   #13
Redd
Thanks!
      02-05-2022, 07:54 AM   #14
pbonsalb
But I have offered the insight (see post #5). Test the engine ground. All you need is a set of jumper cables. Use one or both sides as ground cables. Block to chassis. Then try starting.
Easy to rule the ground in or out. Then move to battery/alternator since they are next easiest to test. Then to starter.
You can just make a replacement ground if you have the supplies. If not, measure and find an off the shelf part with the correct bolt hole size or terminals with enough meat to drill out larger. Or buy BMW's perfect fit ground.
There are also grounds at the tail pipes that are often rotten out that are probably there for a reason on these cars. There may be grounds at the hood hinges -- I cannot recall since I moved on to another car last year and am in the process of forgetting E90M3 tech and learning another car tech. I am just a DIYer and am best at remembering the cars I have.
Idfkman473.00
Scrippy1821.50
      04-23-2024, 11:55 AM   #15
AirborneFF
AirborneFF's Avatar
14
Drives: 2011 M3 Competition
I was having the same symptoms. Long crank, battery was reading 12.7 v. The battery and alternator are both less than 3 years old. I had a track day recently where my TCS was very intrusive. When I got back to the paddock the yellow brake light, brake symbol and exclamation point were all on. I got under the car to take a look at the ground strap under the engine. It was completely green. It was NOT degrading in any way with slight twisting and inspection. It was very loose. I tightened it up with a 13mm wrench. The long crank was gone!. TCS acted normal. No more issues.
Fix: Try the extra ground test. If it starts fine or better check the ground strap.
      04-23-2024, 03:31 PM   #16
Honda
Honda's Avatar
289
Drives: BMW
What is the extra ground test?
m3post
