12-01-2015, 04:17 PM | #67 | |
European Editor
10596
Rep 22,992
Dackel
08-15-2016, 09:27 AM | #68 |
24
Rep 187
So I just installed the Whitline sub-frame bushings. I have to say, getting the rear bolts back in was WAY harder than I remember when taking them out.
I even pulled them back out several times to make sure I wasn't stripping something. But they looked fine. I lined them up and then went in about 10 turns freely by hand but once they get about half way in I really encountered some serious resistance. I pulled them back out and greased the threads and even so I had to use a piece of my jack handle for the last inch. They are all tight now. Anyone else have this issue? I know 100% the bushings and sub-frame are lined up right. The front mounts bolts went in easy and I tightened them down to about the last 1/2 in before I put the rears in.
12 CR 135i - BMS Intake
08-15-2016, 12:17 PM | #69 | |
European Editor
10596
Rep 22,992
I looked on RealOEM.com and the bolts don't seem to be of a one time use type. Maybe try using a magnet to see if those bolts are of a alloy/stretch type. ?
08-15-2016, 01:31 PM | #70 | |
24
Rep 187
Edit: according to realOEM, they are both #7. Part number: 33306793892 Torx screw with collar M12X110-10.9 http://www.realoem.com/bmw/enUS/show...07#33306793892
Dackelone10595.50 |
12-14-2016, 10:40 PM | #72 |
Rep 4
new to the 1er, and totally love this car. 2011 128i, M-Sport, 6MT, SULEV N51.
My ride also has Koni FSD shocks and struts, plus Eibach lowering springs and ZHP 18" wheels. It seems firmly planted to the road, taking foothill curves and wiggles in the pavement without a hint of wander. I read this entire thread and did not see a mention--M-sports have some kind of M-type suspension components. But RealOEM does not list the M bushings numbers as factory in my car. I take it that means there is no hope that they are indeed already in place? Thanks Dack for the good info and advice. I have spent many hours just reading on the forum and have gleaned a lot from you and many others. John |
12-15-2016, 08:29 AM | #73 | |
Rep 1,233
More than likely they are stock....so upgrade! |
Dackelone10595.50 |
12-15-2016, 10:38 AM | #74 | |
European Editor
10596
Rep 22,992
JWedd
IF you do go with the M3/1M rear subframe bushings... I would also replace all six brake hoses with DOT approved stainless steel brake lines - bc you have to drop the rear axle to install the M3 bushings. . Also for anyone with a e8x/e9x car... read this article in Bimmer Magazine... The Ultimate Handling Machine TC Kline’s suspension tuning transforms the entry-level 128i Coupe into a car that can rival the 1 Series M Coupe for pure driving fun. http://www.bimmer-mag.com/issues/101...e#.WFLGFvkrLIU
12-15-2016, 12:59 PM | #75 |
Rep 4
thanks gents...I'll have a bunch of time under the car in a few weeks with various fluid changes, brakes, water pump etc, so I'll do a close inspection of the bushings. It's possible they have the inserts also. With 60k miles, some bushing wear is to be expected.
John |
Dackelone10595.50 |
12-31-2016, 10:44 PM | #76 |
19
Rep 179
Any idea the hardness of the M3 bushes?
Strongflex has them in PU now, was wondering if they would be a better option. http://www.strongflexuk.co.uk/bmw/1-series/e81-e82-e87-e88-04-11/rear-subframe-rear-bush.html#.WGiImsvmjqA |
01-05-2017, 08:19 AM | #77 | |
Rep 1,233
So if you're concerned about that, the poly bushings I don't think will add any significant harshness, at least not when we're talking about subframe bushings. Other bushings (like the diff bushing etc) I can't comment on, as I've heard they can add harshness that is felt inside the car. |
01-22-2017, 12:02 AM | #78 | |
19
Rep 179
Considering the OE bushings are so soft with physical gaps inbetween, instead of getting them pressed out with gadgets and tools, won't it be easier to just cut them out?
04-19-2017, 03:20 AM | #80 | |
European Editor
10596
Rep 22,992
Dack
Tricki215.00 Luftmeister33.00 |
04-19-2017, 01:51 PM | #81 |
Rep 119
Which Rear subframe bushings should I get? My head is spinning.
-M3 -Whiteline -Powerflex, -Agk I plan on renting the bushing removal tool and the car will just be doing spirited driving. I dont mind NVH increases. Please help me decide |
04-19-2017, 07:13 PM | #82 |
European Editor
10596
Rep 22,992
I would get the M3/1M bushings. Very little increase in NVH but very much improved control under performance type driving. One of the best mods I've done to my 135i.
05-08-2017, 09:27 PM | #84 |
17
Rep 45
I'm also keen on the forum's consensus regarding torque values.
Does anyone have a recomendation for the ideal IDs for pipe for a DIY tool? I'm guessing something just above 75mm and 80mm. |
05-09-2017, 05:24 AM | #85 |
European Editor
10596
Rep 22,992
dojk
BoLLo_ The bolts that secure the rear subframe to the chassis are a one time use(stretch bolts). So when you order new bolts at a BMW dealer, have them look up the torque values. Any dealer should be able to tell you the torque value.
BoLLo_16.50 |
05-11-2017, 02:51 AM | #87 | |
17
Rep 45
My local dealer doesn't have any in stock. I doubt they replace them if they don't have any in stock but that is beside the point. I see in the Bentley manual the tightening torque is 100NM (73.7 ft.lb) dojk I don't have time to read the whole thread now but I seem to remember some clue regarding the correct orrientation in this thread: http://www.1addicts.com/forums/showt...frame+bush+diy |
Dackelone10595.50 |
05-11-2017, 01:07 PM | #88 | |
European Editor
10596
Rep 22,992
My dealer had to break open the rear brake lines and lower the axle onto a cart positioned under the car to work on those two rear subframe bushings. Them they had enough room to use that on the car press tool. Then they bled the ABS block and brakes with the BMW ISTA tool. Looking back, I think I should have also replaced my brake lines at that time. Ohh well. Hind sight is 20/20. Dackel
