04-18-2020, 06:10 PM | #1 |
Rep 517
I just changed out my gaskets of my OFHG cause it broke my belt in under a year from a leak that I thought was minor. So here's some tips feel free to add:
- change your OFHG seals as soon a you develop a leak - if you go longer change your belt - when you change you belt clean the teeth of each pulley - degrease both pulley's with teeth and pulley's without or the belt will break again or worse - the lower T10 bolt on the OFHG is hard to get so I removed the connecting radiator hose. Check that it's not internally cracked as you don't want contamination. If you have a lot miles might be a good maintenance item since you're in there. See my images below. A comparable OE hose are like 18 bucks on FCP. https://www.fcpeuro.com/products/bmw...in-11537580969 (I think mine cracked because oil was seeping into that hose from the outside.you can see the oil on the connection lip in the image.) Pushing 20 psi I'm sure speeds these problems up.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
04-18-2020, 06:53 PM | #2 |
Rep 1,442
Drives: 2011 535i 6MT
Nice, I just did mine... my advice: don't accidentally start your car when the oil filter cap is off, it will make a mess - I wish I had it on video, it looked like old faithful, except black.
Did you pull your intake mani and all that fun stuff too? |
04-18-2020, 09:14 PM | #3 |
Rep 14,521
Yup! Had Burrninja do mine just recently about a month ago. Oil leaked onto my belt and splattered over everything. Had to clean everything up. We also went ahead and replaced the belt as well as the oil cooler gasket
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
Bmwdoubles_194.00 BurrNinja430.50 |
04-18-2020, 10:30 PM | #4 | |
Rep 517
I took off my CP and took off all the bolts off my manifold and pulled it up, almost out.
04-18-2020, 10:35 PM | #5 |
Rep 517
I also changed the valvetronic cap due to oil leaking out of it. For 6 bucks it's a no brainer and super easy to switch out.
https://www.fcpeuro.com/products/bmw...ng-11377502022 At the end of you install purge the air from coolant system. - fill reservoir to max line. I used distilled water. - turn car on , not running - turn heat to full on both sides - hold gas pedal to the floor and listen for water pump after about 10 seconds - let run for 10-12 minuets
04-19-2020, 12:12 AM | #6 |
Rep 915
Drives: 2017 540i Bluestone Metallic
Easy diy, saves TONS! Good write up. I did the same method.
Instgram @burninja
04-19-2020, 01:54 AM | #8 |
1303
Rep 2,591
Something I've always wondered... what exactly does a OFHG leak look like? How obvious is it? I'm honestly not sure if mine is leaking or not, but at only 45k miles I don't think it should be leaking just yet
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
04-19-2020, 06:36 AM | #10 |
Rep 1,873
I've been preparing to do this job later this spring. I have to say that I am uncomfortable with all of the risk of oil starvation and how to resolve it. Good coolant connection tips - thanks. I'm pretty sure somewhere I saw an aluminum replacement for that coolant hose part available.
There's folks who say it only applies to those with the oil/air cooler in the fender (requires the high speed synchronization option) because a bubble is formed. If you don't have that option, there's no concern. No hard evidence I've found (yet) There are those who say you just need to refill the oil through the housing. Everyone says that priming is a "good idea" but there's 3-4 different ways to prime, ISTA doesn't have a procedure that uses the computers to help, and for each process you can find someone out there who says it isn't the right way because <something>. In particular that <something> refers to the DME reducing the volume on the oil pump, which is why idling isn't good enough to resolve whatever the issue is. Some tips say that the first thing you should do is get out and GET ON IT, so the DME requests high oil flow. I have to say that goes against every instinct when just having completed a "major" repair to two key fluid systems on the engine. I'm more of an idle-and-check-for-leaks-and-noises kind of guy. More say "don't worry so much", yet that accounts of perfect OFHG jobs resulting in spun rod bearings continues to climb. I watched an N54 decarbonizing video where the guy used a little jumper wire on the starter (which is right there when you have the IM off). I wonder if that would be a good way to prime with no spark or fuel injection. |
04-19-2020, 10:19 AM | #11 |
Rep 716
This is the process I found a while back that I saved when I do the job...
"After replacing the engine or making engine repairs that require the replacement or removal of the engine bearings, VANOS gears, camshafts, bed plate resealing, engine oil pump, engine oil filter housing, cylinder head, engine oil cooler or anything that interrupts the engine oil supply circuit of the engine requires a short oil pump and oil supply circuit priming procedure." This procedure is used when the high pressure fuel system pressure is not depleted after minor engine repairs and the fuel injection system needs to be disabled by removing the fuel injector electrical connectors. 1- If the engine has been drained prior to the repair remove the engine oil drain plug again to remove any residual oil that may have settled in the engine oil pan during the repair if the engine oil pan was not removed entirely. 2- Reinstall and torque the engine oil drain plug (with a new seal ring) per the applicable repair instruction. 3- Remove the oil filter housing cover and verify the oil filter is present. Reinstall the oil filter housing cover and torque it to the proper specification noted in the applicable repair instruction. 4- Fill the engine with the proper type and amount of engine oil, as specified in the applicable repair instruction. 5- Connect a battery charger to the vehicle. 6- Remove all fuel injector electrical connectors to disable fuel injection. 7- Crank the engine for 10 seconds. 8- After 10 seconds have elapsed, stop the starter, and allow the starter to cool for 20 seconds. 9- Repeat steps 7 and 8 two additional times. 10- Reinstall the fuel injector electrical connectors, reassemble the vehicle and verify proper engine operation. 11- After the engine has reached operating temperature, check the engine oil electronically or with the dipstick, and top up the engine oil as needed. |
F10N557.00 |
04-19-2020, 12:42 PM | #12 | |
Rep 517
I don't think there's an official ISTA process because oil starvation wasn't supposed to happen. Nothing about it in newstif.info either: https://www.newtis.info/tisv2/a/en/f...n20/1VnYMIDuML The guys at BMP said, "if you replace the oil during an OFHG repair, I pour 1qt through the OFHG and the rest normal". Not saying it's not possible as BMW does recommend purging the air out of cooling system before starting the car right after the repair. Maybe that's where the problem really lies, is with air in the cooling system that shares the same OFHG? If high oil request is what primes the oil cooler than an idea would be to reverse the oil cooler valve so it's alway circulating. I reverse mine for summer and track days. Takes longer to warm up but on track days, driving really hard not a tick over 240 degrees. Spirited driving with that mod is 220 on average.
ey2001310.00 |
04-19-2020, 12:53 PM | #13 |
Rep 716
Same here I have not heard of anyone that I know but when I do it i am going to do it just incase... on my e60 I changed it out 3 times myself while I owned it and never primed the oil and I was ok until someone clipped me from the side and totaled it... my e60 was like the link you posted in the first picture but my f10 looks like the second pic.. don't know if there is any difference.
Bmwdoubles_194.00 F10N557.00 |
04-19-2020, 02:14 PM | #14 | |
Rep 5,367
04-19-2020, 03:30 PM | #15 | |||||||
Rep 1,873
The same place I saw mention of the oil pump volume being minimized during normal cranking indicated that you need to crank the engine when the DME is NOT expecting to start (e.g. jumper the starter to run without the ignition Quote:
I should look through ISTA to see if it's somewhere else... Quote:
This is a photo of the OFH on an F10 with option S840A "high speed synchronization". These hoses go to the outboard oil/air heat exchanger. Some accounts say that this model is the only one to have an oil starvation risk but I'm not so sure. I think this variant is a minority of F10 N55s. This might be a photo from someone here, it's been circulated all over: Even though my general N55 reference guide says that any option S823A "hot climate version" cars have an oil/air heat exchanger, I think that information doesn't apply to the F10 and instead we get an oil/coolant heat exchanger. This is my OFHG and I have S823A: |
04-19-2020, 04:23 PM | #16 |
Rep 915
Before I did my ofhg I let my car drain oil as i worked on it. By time I was done there was no lick of oil coming out. Poured some down filter housing, then filled engine to spec minus the half quart used in housing. Have been on roughly 5k miles and no issues.
Instgram @burninja
Bmwdoubles_194.00 |
04-19-2020, 07:09 PM | #17 |
Rep 14,521
That's what we did
BurrNinja430.50 |
04-19-2020, 07:28 PM | #18 | ||
Rep 915
Instgram @burninja
04-19-2020, 08:20 PM | #19 | |
Rep 1,873
04-19-2020, 11:20 PM | #20 | ||
Rep 517
Going to see if these dimensions match. It says not for our platform but BMW carry over parts.
04-19-2020, 11:35 PM | #21 |
Rep 517
Looks like FCP sells that with a better OE like clamp!
https://www.fcpeuro.com/products/bmw...e-rein-chc0609
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg Last edited by Bmwdoubles_; 04-21-2020 at 01:34 AM.. |
04-29-2020, 10:55 PM | #22 | |
98
Rep 204
