BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > MHD "take a look at my log" thread
      06-25-2016, 02:52 AM   #89
nismo
Drives: 335 e90 2008
Originally Posted by hellokitty View Post
I'd run the usual test for boost leak. You should be hitting target boost but you are not. What mods do you have? Miles?
I'm FBO with only stock DVs, on 93 octane. 30000 miles. Wedge custom tuned.
      06-25-2016, 06:28 AM   #90
stanlalee
Drives: 07' E92 335i manual
Originally Posted by Msport335 View Post
track night....here are a couple logs on my e60 wedge tune.
was hoping for better times but couldn't hook up.... logs are from 12.2 and 12.3 runs both at 120mph
http://datazap.me/u/msport335/mhd-e6...og=0&data=3-22
now definitely in the market to run meth but don't know the first thing about it as far as what i need since i run MHD flash only.
also will be picking up a set of 275/40/17 drag radials .... which are best between the 555r or nt05r?
You don't need anything except a meth kit with boost referencing (turns on when boost reaches X value. Some are 2 stage or progressive as boost increases).
      06-25-2016, 07:53 AM   #91
Nonecure
Nonecure's Avatar
Drives: 2013 M3
Your log looks good to me. I'm impressed you can run E60 without TBI or PI for added fueling. Your hpfp will not let you produce any more power than what you are making now. 120 is a good trap speed and shows the power you are making. Your times will drop once you get a good hookup.
      06-25-2016, 02:18 PM   #92
EscapeYourMind
Drives: 08 BMW 135i
Could someone confirm what I am seeing here:
http://datazap.me/u/escapeyourmind/n...12-13-14-24-27
Looks like boost leak (maybe turbos going bad?), and lots of corrections (not sure why). Could probably use new spark plugs. No codes or anything, and fueling seems ok to me.
I'm FBO running on 93 octane. ~92k miles.
      06-25-2016, 02:25 PM   #93
Msport335
Msport335's Avatar
97
Drives: 2009 335i m-sport e90
will meth allow me to make more power on the stock turbos? can i simply get a bms kit and call it a day ....will that work with mhd flash only?
E90 LCI M-sport/ 6AT/ LSD/ FBO+
      06-25-2016, 03:52 PM   #94
Nonecure
Nonecure's Avatar
Drives: 2013 M3
Sorry, I can't really answer that since I have not run with Meth. I seriously doubt you going to get any noticeable gain on stock turbos with Meth versus running your E60 tune from Wedge.
      06-25-2016, 06:25 PM   #95
Shrike360
Drives: 2009 E92 M3, 2011 Porsche CTT
Replaced the fuel sensor and took a couple logs. Seems to be good, just some timing corrections. Any thoughts here?
http://datazap.me/u/shrike360/run-2-...og=0&data=4-23
      06-25-2016, 06:34 PM   #96
Sgop335
Sgop335's Avatar
Drives: 07 335i e92, 08 535i
Theres something up w these maps, saw in some others. Timing plummets to negative on full load and comes up some...yikes
335i e92 TPC 19Ts
      06-25-2016, 09:45 PM   #97
Shrike360
MHD stage 1+ v6.1. Probably the same tune as others with that timing drop.
This is the log I took a few months back. Same tune, broken lpfp sensor though: http://datazap.me/u/shrike360/stage-...0&data=4-23-27
      06-25-2016, 11:25 PM   #98
hellokitty
hellokitty's Avatar
Drives: '17 M3 ZCP DCT
Looks good but do you have a FMIC?
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
      06-25-2016, 11:33 PM   #99
hellokitty
hellokitty's Avatar
Could be your DVs. Look into Turbosmart or Forge upgraded DVs.
      06-25-2016, 11:44 PM   #100
Shrike360
OEM. Pretty obvious with the 45 degree dT.
Was planning on going FBO next month, but may have to replace a diff, which hampers those plans.
      06-25-2016, 11:45 PM   #101
hellokitty
hellokitty's Avatar
Time for a LSD??
      06-26-2016, 12:16 AM   #102
Shrike360
Time for a LSD??
Maybe. Supposedly it makes the xi throttle steerable.
      06-27-2016, 07:34 PM   #103
Rob335i
Drives: 06 335i
http://www.datazap.me/u/rob335i/log-...a=4-26&mark=89
can someone take a look please cheers
      06-27-2016, 09:37 PM   #104
flyinb501
Drives: 2009 E90 335i
Hey Guys, I've been running V5 stage 2+ 91 octane for a while now, and it has been great. I decided to try the 93 octane map, and now seeing quite a bit of timing correction. Will someone please take a look and tell me if these values are safe, or should I go back to the 91 octane tune? Also, can you tell if your clutch is slipping from a log? It seemed in 3rd of 4th gear I could barely notice some slipping...
http://www.datazap.me/u/flyinb501/lo...a=8-9-10-12-21
      06-28-2016, 01:40 AM   #105
hughrd1_e90
32
Drives: A Bimmer
Hey guys how's my log looking? I'm running 93 octane with 3 gallons of e85. http://www.datazap.me/u/ricky85/log-...og=0&data=4-24
      07-01-2016, 04:21 AM   #106
MyNameIsNotSure
52
Drives: 2018 M3 ZCP
Logs
I'm on a stock 2009 MT 335i with the stage 1 91oct tune (version 6.1). So I've been getting some intermittent misfires, specifically they only happen in 6th gear going up a steep hill under WOT around 85-90 mph. Tried a lot of things and took the car to a couple of different shops and still can't figure out what's wrong!
Replaced coils, plugs and rear oxygen sensor but the misfire is still there intermittently. Annoyingly when I went to log tonight, it didn't misfire a single time, maybe it was because of the low night time temps (60F in Cali). Thought I'd post the logs anyway, maybe you guys will notice something. I'm new to logging so I did a few, just in case:
3rd gear pulls (on flat ground):
Run 1
Run 2
Run 3
Here is a sixth gear pull going up a steep hill, where I tried to recreate the misfire:
Sixth gear pull
      07-01-2016, 04:32 AM   #107
hellokitty
hellokitty's Avatar
Run 1
Run 2
Run 3
Sixth gear pull
How many miles since a walnut blast?
      07-01-2016, 11:28 AM   #108
MyNameIsNotSure
52
Drives: 2018 M3 ZCP
It's at 95k right now, walnut blast done at around 75k.
      07-01-2016, 11:31 AM   #109
hellokitty
hellokitty's Avatar
Are you misfiring on the same cyl consistently? Logs appear to be within reason (but I didn't do a deep dive). I just reviewed it high-level.
Common causes you've already addressed such as coils and plugs. Your AFR appears to be in check so that rules out injectors and o2 sensors.
The only thing I can really think of is poor octane. California 91 is pretty junk (I'd know, I lived there before they stationed me abroad.)
Perhaps you can try adding 2-3 gallons of E85 and see if it happens again...
      07-01-2016, 11:51 AM   #110
MyNameIsNotSure
52
Drives: 2018 M3 ZCP
It hasn't thrown a code in a while so idk which cylinder it is. But when it used to throw them it was either cyl 5 or 6. Another thing is that I intermittently get an SES (at random times not near misfires) with code 2C31 (Lambda probe front catalyst, adjustment control) and for whatever reason my catalyst, evap system, and oxygen sensor monitors always seem to be "incomplete", caused me to fail smog. Could any of this be related? I only use 91 from chevron/76.
