      07-06-2019, 03:56 PM   #23
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
Arrow Alps...
bbnks2
Yeineken
fast1eddy
ShocknAwe
Originally Posted by Traf View Post
The wobble feeling
No, it is not from the tires. I think this is just how the 1er coupes drive at high speeds. I have Michelin PS4 tires in 225/255 sizes. I have gone thru four or so sets or tires... it's just how the 1er handles at high speeds. Two years ago I had an alignment done at a BMW dealer for the first time. THAT really help with some of the rear end "wandering" but the front toe changes at high speed was still there.
I still think the harder bushing material on the M3 control arms and thrust rods might help eliminate that wobble or toe change at high speeds. Well see.
Originally Posted by MightyMouseTech View Post
So, knowing Dack, this car is done and back on the road.
How did the alignment go?
How do you like the feel?
To busy carving up the mountain passes?
MightyMouseTech it's funny you say this... because I have been out, driving the Alps with some friends.
Just today the TRW tie rods came in the mail. I still need a boot crimping tool to arrive as well as a 38mm open wrench. I might just use a BIG crescent wrench for the inner tie rods. I also had to order a tie rod puller since one is rusted in place(I think). I also have some new BMW hardware coming in soon. IF all goes well... I should have the front suspension done in two weeks or so.
Last month I installed the rear (upper)M3 tension rods, four Bilstein shocks and Eibach springs and Dinan camber plates. The car really handles well and understeer is gone. The bump steer from the rear suspension is also gone. I think that was those old links in the rear - changing the toe when hitting a bump.
Two weeks ago I drove the Alps with some Euro 1Addicts friends. It's our yearly ritual. Driving thru Austria, Slovenia, Italy and Switzerland. It was awesome.
I drove about 2,300 kms, so the suspension has settled some. Once I install the tie rods in a few weeks... I will have a proper alignment done. I will keep you guys a breasted.
Here are a few pics...
My haus in Bayern... car freshly lowered. I think now its even slightly lower!
at Alpina in Buchloe... test driving the new B5.
Near Mariastein, Austria...
Passo Sella...
Sella Pass in the Dolomite(Italy)...
San Bernardino Pass, Switzerland...
Some friends...
7188 Tujetsch, Switzerland...
Bye, bye, Swiss Alps...
Appreciate 4
      07-06-2019, 04:23 PM   #24
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
I almost forgot... here are some fotos of the TRW tie rods. I only took pics of one of them.
I am a bit curious WHY they supplied two different types of nuts for the outter tie rods. I am pretty sure my car has the regular nut not the one with a floating or rotating collar. ANy advice MightyMouseTech ???
Rotating collar nut on the left. Normal flange nut on the right.
tie rods are stamped R & L... right and left, sides of the car.
Meyle steering rack bellow(s) kit...
#17 & #18 are the rear suspension parts I replaced with these ///M bits.
Name:  8 Guide Rods 1.jpg
Name:  10 Guide Rods 2.jpg
1and11864.00
      07-06-2019, 04:31 PM   #25
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
Btw... I would LOVE to replace the rear toe arms with ///M ones... but as we know the M ones are too short. I was thinking maybe I could fine another M car that uses a longer link that would fit on a 135i... but so far I have had no luck.
My first thought was to look on an M2 or M3(F80) but they have a totally different rear suspension. Any ideas guys?
Name:  11 Toe Arms.jpg
#14 is the rear tow arm I would like to replace.
Name:  135i rear suspension diag_433u.jpg
Originally Posted by fast1eddy View Post
The M3 thrust rods will take care of the elastic feel in the front end . Helps tame the rear too and makes the whole car for predictable and solid. They also introduce a fair amount of NVH. I ended up switching back to stock mostly because of our crappy roads and a nagging wife. if you have good roads where you live , you'll love them .
Thanks.
Germany is known for good, smooth well maintained roads.
Dack
Appreciate 3
1and11864.00
      07-07-2019, 12:41 AM   #26
fast1eddy
fast1eddy's Avatar
270
Drives: 2008 135i Lemans Blue
2008 135i  [0.00]
  [0.00]
I'm totally jealous. That trip looked amazing with some incredible roads. I've got a well sorted great handling car with no good roads to enjoy it on
Dackelone10623.50
      07-07-2019, 03:52 AM   #27
Traf
Traf's Avatar
France
95
Drives: E82 135i
Maybe adjustable toe arms with dual ball joint ? You can find them cheap enough.
Dackelone10623.50
      07-07-2019, 08:16 PM   #28
Eddie135
N55 Commando
Eddie135's Avatar
Australia
55
Drives: 135i - DCT - N55
Exactly. You did put a gasket between the Dinan plate and body correct?
Sorry guys, does this gasket comes with the camber plates or do I need to order it separately?
Thanks.
      07-07-2019, 08:49 PM   #29
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Thanks.
Separately, from the dealer.
Dackelone10623.50
      07-08-2019, 01:29 PM   #30
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
Thanks.
I ordered mine from a BMW dealer. You need two of #5...
BMW p/n 31306772226 4,80 € each
https://www.realoem.com/bmw/enUS/sho...diagId=31_0695
Also make sure you have a new nut, #3 in the above illustration. Most new shock kits come with one. My Bilstein's came with new ones.
Dackel
lab_rat394.50
      07-08-2019, 05:22 PM   #31
Eddie135
N55 Commando
Eddie135's Avatar
Australia
55
Thanks mate, legend!
Dackelone10623.50
      08-01-2019, 02:27 PM   #32
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Drives: E82 Mutt, M57 Truck
Hey Dack. What do you think of your new steering links
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      08-01-2019, 03:43 PM   #33
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
They look good in the box!
I still have not installed them yet! First, I ordered an air compressor and air hammer. The air hammer took almost a month to come from Amazon(China). I needed an air hammer and tie rod/ball joint press bc one of the tie rods is frozen(rusted) in place. The air hammer arrived last week, but then my daily, my e39 540i 6sp, died on me last week. Fuel pump quit on a HOT 104'F day here in Germany. Not fun. My e39 is back up and running... so I should be able to tackle the HD tie rods and M3 front end bits soon. Maybe next week!
Dackel
Thanks to ADAC for my taxi ride home last week!!
      08-01-2019, 04:46 PM   #34
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Oh man. Sweet 5er. Sorry to hear about the fuel pump. Down here in the southeast I sympathize with you on hot weather auto trouble.
Wondering if I should have my shop do my tie rods while my 1er is in for remediation.
Dackelone10623.50
      08-02-2019, 04:16 PM   #35
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
Yeah, I would say replace them. I removed one of the tie rods at the hub... while there was no play the ball joint moved quite easily. Its time. Get the HD tie rods IF you can.
When installing my suspension I also replaced the sway bar end links and some of the control arms like the rear toe arm links(out of stamped steel)... all that stuff was worn at 100K miles. Not loose... but worn. So you know the saying... "while I am in there..." I replaced all that stuff. It truly is a rabbit hole.
I will post an update in this thread when I install my front M3 control arm bits & tie rods.
Dackel
      08-03-2019, 09:10 AM   #36
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Guess I'm ordering some HD tie rods. Thanks Dack.
Dackelone10623.50
      08-03-2019, 02:58 PM   #37
tetsuo111
Save the Manuals!
tetsuo111's Avatar
Drives: E91 RWD 6MT, X3, Ducati S4R
Helpful reporting and beautiful pictures - thank you for sharing!
Originally Posted by Dackelone View Post
bbnks2
Yeineken
fast1eddy
ShocknAwe
2011 6MT RWD ClubSport Wagon | 3,185lbs | 1 of 149 ZSPs delivered in North America
Outside: BMW M-Aero, Euro region lighting, Seibon | Inside: M3 cockpit, Recaro SPG, Prototipo, AutoSolutions SSK, UCP | Stop: M3 ST-40R, PFC | Grip: Solid-mounted subframes, rear coilover conversion, M3 Nitron R3, Hyperco, SPL, AKG, ARC8 | Go: StageFP, CF snorkel, 3IM, MILVs, SuperSprint headers, Dundon Motorsports Inconel exhaust, VoltPhreaks | Cool: CSF | PCA #2018100384 | BMW CCA #505794
Dackelone10623.50
      08-23-2020, 09:32 AM   #38
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
The tie rods ever get installed?
