BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Joying 10.25" Android Head Unit Install - Non Idrive - Digital Audio Out & Carplay
      12-15-2021, 09:08 PM   #45
ctuna
Drives: 325xi 06 wagon MT
Yes the BMW head unit is the server for the Most Bus which can
have a number of modules besides the SOS function . All those
modules will cease to function when replaced by and aftermarket
head unit . There are some harnesses that bypass this stuff like
certain connects 2. From the old days the first thing you did when
removing and replacing the OEM with aftermarkete was code out
the SOS module from the Instrument Panel and remove the TCU
and or Mulf .
      12-15-2021, 09:57 PM   #46
Eturnulrs704
40
Drives: 08 E92 335i 03 E39 540i
I went the 10.25 route. And honestly I love it. Just because it doesn't fit. That seems to be the theme these days in cars coming from the factory. Screams that look out of place but are stock options. I do also have a 3d printer and think I will get to work on it.
      12-15-2021, 10:21 PM   #47
Eturnulrs704
40
Size:  146.0 KBSo I tried the tunes, but my stereo is shot because of a damaged fiber optic most cable. Any one know which cable I need to replace the most cable that's broken. It's part of this group in the trunk, the shock/coilovers damaged it and the speaker wiring.. also can I replace it with the aftermarket orang one shown, or do I need the one with multiple heads.
      12-25-2021, 01:33 PM   #48
Mrquik310
Drives: BMW 328i
Originally Posted by busta604 View Post
I went with the 8.8". Just used the cage supplied with head unit and bent the tabs to hold it at desired depth. Full view of HVAC. Custom spacers weren't necessary, but still might later to center and move up a few mm.
this looks dope!!
      01-22-2022, 12:18 PM   #49
Eturnulrs704
40
and or Mulf .
The resident guru. I've searched quite a bit and haven't found what I'm looking for. Maybe you can point me in the right direction. My optic cable has a tear in it. Near the rear strut/coilovers. Is there a tutorial on how to open the bus connection to replace that one damaged wire. There is also an spare not connected. I want to either use that to keep the green theme or use parts of the aftermarket orange wire I bought. So is there a way to just unpin those fiber optic cables and replace the damaged one without cutting or completely removing the entire harness?. Thx
      01-22-2022, 05:17 PM   #50
ctuna
If the one for the compact disk player is undamaged and you don't have
a compact disk player you can just move it over . It should go to the
Most Hub which is under the rear seat Bolster on the Driver side in
Us Cars that aren't convertibles. (REAR SEAT Bolster behind driver side see links)
https://www.e90post.com/forums/showthread.php?t=163253
https://www.google.com/search?q=BMW+...VCkMqy2aCK09M:
The connectors that have two lines going in are all modular and can be reconfigured with the end connectors.
Also you can use a flashlight to shine in one end of the fibers to see if it
transmits to the other end of any individual cable.
      01-22-2022, 11:43 PM   #51
J0K3R5
J0K3R5's Avatar
Vatican City State
406
Drives: BMW
https://www.joyingauto.eu/blog/post/...-bmw-e90-2010/
Help yourself Software part II, read post 1 : https://www.e90post.com/forums/showt...7#post27890067
      01-27-2022, 04:51 PM   #52
Eturnulrs704
40
Thx bro. Can always count on you. I've had the seat bolster out for almost 3 weeks just contemplating on how to open up that bus and pull out the cable. You rock.
      01-27-2022, 05:42 PM   #53
ctuna
Looks pretty straight foward if you read the threads.
      02-11-2022, 07:19 AM   #54
KalevE
Estonia
Drives: BMW E92 325i RWD
Originally Posted by J0K3R5 View Post
I wonder where the new radio is installed since the original is still there
BTW what parking cameras are you using with those Joying units? And does anyone use ADAS capable DVR with it?
I have thought about getting either the 10.25 or 8.8" single din unit, but their universal camera ain't the prettiest thing and I would prefer the one that replaces trunk handle.
      02-17-2022, 05:22 PM   #55
Eturnulrs704
40
I bought one from Amazon that replaced the truck latch. It was 59.00. HD 1080p. Gotta make sure it's the one with the big lens sensor. The version with the smaller lens has poor picture quality.
https://www.amazon.com/Reversing-Cam...NsaWNrPXRydWU=
      11-22-2022, 06:21 PM   #56
The Nightman
Cometh
The Nightman's Avatar
1090
Drives: Boy's Soul
Sorry to bump an old thread, but could anyone comment on what it is like to have this headunit on at night? Does the screen automatically dim enough to prevent glare?
Not a fan of screens in the cabin (hard to avoid nowadays) but would love to have Android Auto.
Eturnulrs704
busta604
PORTMOODY
      12-10-2022, 10:31 AM   #57
busta604
38
Drives: 2009 BMW 328i Touring xDrive
Joying has dash cam and parking cam accessories. I didn't bother with either. Wiring seems like too much work. I prefer the safe, old fashioned way of turning my head and looking when backing up in such a small car. the factory parking sensors are sufficient and pop up a display on the head unit by canbus. There's also a setting to turn the volume down when in reverse.
      12-10-2022, 10:34 AM   #58
busta604
38
Eturnulrs704
busta604
PORTMOODY
You can set the brightness/dimness for both day and night mode. Night mode can be set by time or by auto headlights (canbus).
I've had absolutely no issues at night
      10-12-2023, 05:21 PM   #59
Ca86108
31
Drives: 135i
Hello,
Does anyone know what options I have if I have the Harmon Kardon sound system? Are there any options for me like this?
      03-02-2024, 09:53 AM   #60
aznbo187
Drives: E46 M3, 128, E91 328, E70 X5d
That’s pretty clean! I wonder if they will start selling it. I’d like to avoid cutting the dash…but maybe that’s really the best option. Poor single hump..
