Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Need help finding my perfect CarPlay unit- money no object.
      10-07-2023, 07:29 PM   #1
bootleg330
Drives: '13 E92 "330i" xDelete M-Sport
Hello all, I have a Logic 7 equipped car with CIC. I would like to add CarPlay but I have a bunch of criteria that make me feel like I'll have to retrofit NBT. Essentially, I want a unit that uses the OEM mic and also does not connect through the AUX. Now while the 12Volt unit does this, there is one thing I hate about it: the home button to get back to iDrive saying "Mr12Volt" instead of "BMW" as on the OEM systems or even on the Bimmertech one. if anyone can direct me to a unit that has what I outlined it will be much appreciated.
      10-08-2023, 03:02 AM   #2
ctuna
Drives: 325xi 06 wagon MT
Mr 12 volt is the only one that doesn't use the Aux as far as I know.
If you can update the BMW head unit far enough I believe it supports
carplay and android.
there are many video's on ytube the above one tells the difference between
going cheap and not so cheap.
https://en.wikipedia.org/wiki/BMW_iDrive
http://www.bimmerretrofit.com/store/
      10-09-2023, 02:38 PM   #3
Hauteknits
Drives: 335i E93 N55 6MT
This sparked my interests for car play again. Stumbled upon this video https://www.youtube.com/shorts/LgxaOGzJK7Y. Maybe you can change it to the BMW logo?
      10-09-2023, 11:21 PM   #4
ctuna
So did you change it? and to what?
Seems like a common android function .
But maybe not Carplay.
      10-10-2023, 02:12 PM   #5
lnxguy
Drives: 2009 335D
The perfect carplay unit doesn't exist unless it's an OEM integration. That being said Mr12Volt is probably the best of the bunch.
'09 335D
      10-10-2023, 10:42 PM   #6
bogdanc4
bogdanc4's Avatar
9
Drives: 2011 335d
I dont know how i stumbled upon this post, maybe because usually i go on the classifieds one only but i’m glad i found it as i’ve never heard of mr12volts carplah solution and it’s exactly what i’m looking for. Something without loosing audio quality and this seems to even make it better. Just ordered one 🙏🏼
Ali-E90378.50
      10-16-2023, 03:01 AM   #7
avivienni
ASH
avivienni's Avatar
Drives: BMW 335i E93 2009
2009 335i  [10.00]
You can actually change the bootloader logo that pops up when you hit the home button on your iDrive for Mr12Volt
Go to Settings -> System -> Factory Mode -> Advanced Setting -> In the password prompt type "688612" -> Boot Logo -> Pick the BMW emblem
      10-19-2023, 01:11 PM   #8
KClemente
KClemente's Avatar
Drives: E90 335i
For anyone that has a Mr12volt, how's the boot time and connection time?
Cars give me headaches.
      10-22-2023, 04:27 PM   #9
bootleg330
well that just completely changed my opinion on the 12volt and rendered this thread useless... here's to hoping it'll work with logic 7
      10-22-2023, 04:28 PM   #10
bootleg330
apparently it is possible. will probably pull the trigger but the logic 7 also scares me
      10-22-2023, 05:11 PM   #11
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2659
Drives: 11' 335is DCT
I use the RoadTop one on ebay. Uses OEM mic. Originally it connects via AUX only but I messaged the seller and they gave me an update that works with using the stock BT audio.
No big issues with it yet. I would say sometime BT connection is just slow at first or I have to re-pair but eh it's not a big deal.
But if money is no obejct I would assume the BimmerTech one is your best option?
      10-22-2023, 05:20 PM   #12
bootleg330
the bimmertech unfortunately goes thru the aux port, unless there's a new version. roadmap one sounds interesting will check it out
      10-22-2023, 05:25 PM   #13
bootleg330
I have logic 7 which adds even more complication too
      10-22-2023, 05:31 PM   #14
TheMidnightNarwhal
2659
Not sure what changes with logic 7. I have Individual audio on mine which is higher no issues.
      10-24-2023, 06:29 PM   #15
BoostMW
Drives: 335i
Completed my mr12volt install last weekend, everything working well and audio seems to be great. I’ve been using aux so long that I feel the audio is better than before. Only thing I can’t do is change the logos on this new box but not a big deal
      03-18-2024, 12:32 AM   #16
avivienni
ASH
avivienni's Avatar
2009 335i  [10.00]
Boot time is very quick, you only see the logo you picked for about 5 seconds before you’re on the interface. My favorite part is that it runs in the background for a few minutes after you turn off your car. So if you were to turn off the car, fill up gas, and get back in, the CarPlay screen will pop up as soon as your finger hits the push to start, connected to your phone and everything already. On my IPhone 13 it used to connect almost instantly like 3 seconds but after getting the 15 Pro it’s more like 10. Not sure if it’s the phone or the unit but just throwing that out there.
