      01-29-2024, 07:01 PM   #1
g20beam
g20beam's Avatar
476
Drives: G20 330i M Sport
2019 BMW  [0.00]
US HIDs to ROA HIDs Conversion Help
I’m currently trying to convert my headlights (US/NA spec HIDs) to the Euro/ROA HID headlights.
After plugging them in, only the low beams/high beams and turn signals work, angel eyes and DRL does not. I looked at the socket and moved around one wire and the DRLs are now functional.
My problem now is the angel eyes, in the Euro/ROA spec lights they are a separate plugged H10 bulb, which does not exist on the US/NA spec.
My question is, how do I wire the H10 bulb to the main headlight wiring harness so that it functions? I know that one wire must go to the DRL light, does the brown go to the ground wire? If so, does anyone know which socket is for ground?
Sorry I am no electrician so any help would be appreciated. Thanks.
      01-31-2024, 03:08 PM   #2
danix
14
Drives: e39,e46
Brown is usually ground but not always. You can check with a continuity tester from the brown to a bare metal ground (but make sure it's not hot first by checking for voltage).
This link may help with diagrams, haven't tried it myself: https://www.bimmerfest.com/threads/a...-2023.1436615/
      01-31-2024, 04:26 PM   #3
g20beam
g20beam's Avatar
476
2019 BMW  [0.00]
Hey thanks for your response but I’ve figured it out! The wiring works perfectly and there’s no codes even without coding. Did a whole LED conversion for all bulbs too.
      02-01-2024, 10:04 AM   #4
danix
14
Drives: e39,e46
Awesome. Do post before/after pics of the beam coverage, may help someone.
g20beam476.00
darkrom188.00
