Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Low pressure sensor and crankshaft code... Just replace sensors?
      06-22-2013, 08:12 AM   #1
djpeetur
djpeetur's Avatar
Drives: F80
Any ideas, n54 w/ 90k miles
      06-22-2013, 08:19 AM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
i guess you are tuned considering the 2D18 code? you need to add ALL INFO about the car. not only codes. Also try to search them here , you will find tons of threads with troubleshooting help.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      06-22-2013, 08:48 AM   #3
djpeetur
djpeetur's Avatar
Drives: F80
Stock 135i 90k
      06-22-2013, 01:27 PM   #4
BMWM.D.
Stupid Idiot
BMWM.D.'s Avatar
134
Drives: E90 335i & 6th Gen ZL1
Yes, you need to replace the low-pressure sensor. The 2A99 is not being caused by the crank sensor. Probably related to the vanos on the exhaust cam. Possibly a vanos solenoid issue.
      06-22-2013, 03:53 PM   #5
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
Yep. Vanos solenoid to start, might as well do both along with the low pressure sensor. Then if the vanos solenoid doesn't fix it, you probably have a worn exhaust cam bearing ledge. You'll have to pull the valve cover and front cam bearing cap to check for wear if that's the case.
      06-22-2013, 07:15 PM   #6
djpeetur
djpeetur's Avatar
Drives: F80
ok thanks guys. will replace all 3 since its in same area. yea my car is stock. just rode like a dick for an hour. guess cause it has 90k
