BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > PE Exhaust - N55 same as N54? Might have made stupid mistake.
      06-23-2013, 04:13 PM   #1
stashtrey
Drives: 08 E90 335xi TiAg
Trying to figure out if the Performance Exhaust is interchangeable or the same between N55 and N54.
I just bought what I thought was the correct BMW PE on eBay (new/power seller, 100% feefback etc). I then realized the part# is for 2010+ E90/335's.
From the research I've done so far it looks like the N55 PE doesn't come with the new x pipe/resonator delete. Just the mufflers and clamps.
I'm not worried about cancelling the order. I don't think that will be a problem.
I'm wondering if there is any difference with the actual mufflers. They look identical from what I can tell.
If I can't get a refund and get stuck with this setup will I be able to make it work? I'm thinking the mufflers are likely the same and I'd just have to have a shop delete the resonator. That's the only difference I can see.
Any feedback would be appreciated as I have that sick feeling and obviously am pissed off I wasn't more careful.
The eBay description didn't mention model year and I failed to scrub the part #.
E90 2008 335xi - TiAg - AMS FMIC - BMW PE - BMS OCC - ER CP - KW V3 - Vorshlag Camber Plates - AG M359 18" PSS - Alpina Flash - RB PCV Valvle - AFE Intake - Walbro LPFP
      06-23-2013, 05:47 PM   #2
rismo
Drives: BMW E92 335
The N55 has a single DP... not sure how the N55 exhaust is exactly routed.
http://www.bmw.com/com/en/owners/acc...catalogue.html
You can use that to see how the parts look like...
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3
      06-23-2013, 05:55 PM   #3
stashtrey
Yeah... aware of the single DP. The N55 exhaust piping from the resonator back go from two to a single up to the DP.
The exhaust I bought is only axle back so I'm assuming the mufflers are likely identical.
I can use what I bought and just have the shop delete the resonator. PE exhaust doesn't go all the way up to the DP's. It starts beyond the secondary cats.
I'm thinking this will work for me. I'm currently straight-pip/muffler delete. These mufflers should be the same size and the rest is just removing the resonator.
      06-23-2013, 08:12 PM   #4
richpike
Drives: MDX, LR4
The 2010 was still the N54. Are you sure the part number said 2010+? Maybe it is the correct setup already.
Good luck.
Rich
      06-23-2013, 08:30 PM   #5
stashtrey
the part # said 3/2010 and up.
I'm not worried. It should be fine. I'll have the shop remove the resonator and slap the mufflers on. Job done. Can't wait!
