03-31-2015, 06:34 AM | #265 |
58
Rep 150
Ok well I tried this one and I still got the same results. However now when I try to use my existing maps, I get a prompt to enter a code there too. I double checked and the maps that my car has are still the same maps.
I also checked the folder name as you suggested to compare to the NAVD_... number and it does match what was in the XML I posted. What else could be wrong? :-\ Any help would be greatly appreciated as my maps are currently broken . Maybe the DE file that I generated? I didnt' have any problems when generating it following the directions with e-sys and then converting it to base 64. It loads without issue into the fsc code generator so all of that seems just fine... I have NBT maps, and the interface looks like one of the pictures that call it NBT so I'm assuming I have NBT. Is there a different way to generate the DE file vs 1B file (NBT vs CIC) ? If anyone has a setup able to generate FSC codes, maybe you could help me test by generating one with the file that I generated and we can compare to what I was able to generate? |
FlorinQCK-2.50 |
03-31-2015, 08:25 AM | #267 | |
58
Rep 150
I'm sending you the FSC file contents and the code i generated via PM. Thanks a ton for your help... |
FlorinQCK-2.50 |
04-01-2015, 06:35 PM | #271 |
58
Rep 150
Hey kitster, your PM box is full it looks like. I'm still unable to get the right first portion of the code for some reason... I was able to generate the same fsc file that you returned tho.
04-07-2015, 06:33 AM | #277 |
58
Rep 150
As I did get it to work, I'd be glad to help out any others that are still struggling.
Zungu and V12 (they PM'd for help), if you want to post your troubles here I can try to help so that others can benefit from our answers... |
FlorinQCK-2.50 |
04-07-2015, 08:48 AM | #279 |
General
10513
Rep 41,033
Because no one else has FSC Service v2.5.
FlorinQCK-2.50 |
04-09-2015, 09:25 AM | #281 |
Rep 2
have big problem
Hi guys,
i have a big problem. First the steps i did before the problem: - open e-sys and tried to load FSC it; it says all the time "select file to open" - so i wondered because i have no file to open. I tried many times and at the end i took the FSC from the pages of this thread with the VIN KS91992 - i pushed false button , i dont push the save , i pushed "run" so i think the FSC from VIN KS91992 is in my car. Can it be? - now my installed map Europe Next 2014-1 is locked and would like a code After this steps i recognize that it was false so i download the FSC in car like the manual in this thread but i got all the time with the VIN KS91992. Thats the reason why i think i saved false FSC in my car. With this FSC i tried to create codes. But no one worked. So i opened the FSC into the editor in e-sys and change the VIN to mine and saved again to car. After this i tried to create new codes ... no one workes. I have Europe NEXT 2014-1 installed in the car and NEXT 2015-2 on stick. I created codes for 0xA9 0x05 till 0x09. Someone who can help me ? Im down after 7 hours of tests... thx a lot. excause me for my english - im german Add: Attached the actual files from car. one direct saved file .. another after base64. Last edited by Psychotica; 04-09-2015 at 09:52 AM.. |
FlorinQCK-2.50 |
04-09-2015, 11:32 AM | #282 | |
General
10513
Rep 41,033
PM sent.
FlorinQCK-2.50 |
04-09-2015, 12:08 PM | #284 |
General
10513
Rep 41,033
No. F144965_00DE0001.fsc is corrupt. Open file in E-Sys FSC-Editor, and you will see it fail. You can make code from it, but it will not be correct.
FlorinQCK-2.50 |
