N55 Vacuum leak
03-03-2024, 08:08 PM | #1 |
Rep 3
N55 Vacuum leak
I’ve got a 2011 e92 335i purchased last Monday. The car came with a catless downpipe and and upgraded charge pipe. Flashed to stage 1 through mhd the other day. After flashing went for a drive when I got back home I noticed a whistling noise from under the hood and found the leak fairly quick. I taped it up as a very temporary fix. Was wondering if anybody can tell me where I can find and buy a replacement for the hose. And if it would cause my afrs to be all over the place. Car now feels pretty sluggish and will occasionally die when sitting at stop sign. Could that hose be causing all these issues? Not driving it unless I absolutely have to car threw a code for being too lean and also a 2775 code right after stalling out. Pretty new to the whole tuning and modifying scene and I wouldn’t even know where to start to look for it. Thanks ahead of time.
03-03-2024, 09:16 PM | #3 |
Rep 904
Don’t know the exact part number, but that’s a hose going from the vacuum reservoir in the valve cover to the exhaust flap. Problem is, that vacuum reservoir is also used to control the wastegate, that’s why the car is sluggish. I’d just disconnect this exhaust flap hose at the valve cover, cap the nipple and be done with it. That’s what I did anyway when I discovered that my exhaust flap doesn’t hold vacuum.
03-04-2024, 12:42 PM | #4 |
Rep 717
Fastboatster is right about that vacuum line, you'll feel sluggish due to wastegate not closing right due to lost vacuum, and get that wistling sound you heard.
But that won't cause your AFR's to go lean, or cause stalling at a stop (the vacuum in that line comes from a vac pump, not the intake manifold). So in addition to the loose vacuum line you've found, you also have a seperate issue(s) going on that's causing your lean codes and stalling. I'd start by looking for leaks in your intake and charge piping (leaks after the MAF sensor will suck un-meterered air into the engine, causing you to go lean). |
wrevilo47.50 |
03-04-2024, 09:13 PM | #5 | |
Rep 3
04-15-2024, 09:03 AM | #6 |
Rep 3
Further Troubleshooting of the vacuum system
I just posted this in another thread. (not specifically related but it may help the community with further issues)
http://f10.5post.com/forums/showpost.php?p=31074058&postcount=7 Here is the hose I just used to replace that same exact vacuum line, it's more than you need but you can use it to replace all lines to VC and boost solenoid and the wastegate if yours is pneumatic (should be) BMW Blue Silicone Vacuum Hose (5 Meters) - CRP 11731259996 -ordered from FCP Euro (Lifetime warranty on almost all parts) As for the oil on the plugs, I highly recommend replacing all plugs with NGK one step colder and all coils (or just the submerged ones, at least) since the car is tuned. The oil is most probably the VCG and will cause coils to wear prematurely. That's why I recommend replacing them. To eliminate the chance of cracks within the VC and giving you issues. I'd say do both since you have to pull it for the gasket either way, and if there is uncertainty about when the VC was last replaced. (they are plastic) I am currently chasing an issue where my vacuum lines are filled with oil, and I hope the vacuum pump is not the culprit. Hope this helps. |
04-15-2024, 12:23 PM | #7 | |
Rep 717
04-15-2024, 12:25 PM | #8 | |
Rep 717
04-16-2024, 08:15 AM | #9 |
Rep 3
I’ve been looking really hard and have only found one forum with a dead end; month long tags with the dealer and finally resulting in pump replacement. It just doesn’t make sense to me that it would be leaking oil from an area where it’s sucking in air. I really hope a new valve cover fixes the issue. Otherwise I’ll be ordering the pump and special tools.
