The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Tuning E92 335xi (Higher Mileage) Looking for Feedback!
      05-09-2024, 01:42 PM   #1
ChicagoE92
ChicagoE92's Avatar
Drives: E92 335xi
Hello all!
I would love some feedback regarding tuning a higher mileage N55.
I have owned the car for around 2 years and daily drive it.
Is there anything else I should do for the sake of longevity for the engine/surrounding components?
Is it smarter to get it tuned in a shop rather than by flashing?
Last major failure point I have not addressed is the HPFP but plan to over the summer.
Miles as of current day: 102,144
Current Parts List:
  • MHD Super Liscense
  • ARM Motorsports Downpipe
  • HPS Cold Air Intake
  • ARM 7” FMIC (maybe)
Will be changing spark plugs/coils prior to tuning.
Below is the maintenance history:
Spark Plugs/Coils: Will be installing the OE kit from FCP Euro prior to flashing.
Transmission Service (ZF6AT): Has never been done.
Alternator: Replaced within the last 1k miles.
Water Pump/TStat: Replaced within the last 1k miles.
Drive Accessory Belt/Pulleys/Idler Pulley: Replaced within the last 2k miles.
VCG: Replaced at 81k miles.
Radiator: Replaced at 81k miles.
Coolant Resovior: Replaced at 81k miles.
HPFP: Original has not been replaced.
Oil Changes: Every 5k miles with 5w40 from Liqui Moly.
      05-10-2024, 03:36 AM   #2
wrevilo
48
Drives: 2010 E92 335i N55 6MT
Sounds like you are on top of everything really. I'd expect any issues to be exposed through the mapping. For example, only after I had flashed MHD did I start getting codes regarding the HPFP in my car.
The OTS maps via MHD are cheap and easy as a starting point.
Appreciate 3
      05-10-2024, 10:33 AM   #3
minulache
19
Drives: BMW 4 F36 & E92 N55 LCI
Same as wrevilo said.
Spark plugs and ignition coils and you are good to go to Stage 2+
Maybe a good idea to change also the fluid in the front/rear differentials and transfer case along with the transmission service.
