BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Aftermarket Valve Covers?
      02-11-2024, 04:01 PM   #1
friedeggnchips
Drives: E90 325i LCI
Hi guys,
Recently made a post about fixing the injectors on my '10 325i N53. Car is running nicely but whilst there I noticed a crack in the side of the plastic valve cover right next to the oil filler cap.
A couple weeks ago before doing the injectors, the cabin started smelling like burnt oil and after shutting off the car I noticed a faint white smoke coming from the top of the bonnet. Turns out that this is a very common issue for the valve cover to crack, and the valve cover gaskets are also very common to go.
Now my problem is that the Valve cover from BMW is around £450. This doesn't seem too expensive but I've already spent a lot fixing the injectors. I'm looking at buying an aftermarket valve cover that's slightly cheaper and buying the gasket from BMW separately. Has anyone had any experience with aftermarket valve covers? This seems to be the correct part number: 11127548196.
Here are some example parts:
Ridex:
https://www.autodoc.co.uk/ridex/17160078
Febi Bilstein:
https://www.ymfcarparts.co.uk/febi-b...-cover-176165/
Apex Autoparts:
https://www.apexautoparts.co.uk/prod...rol-engine-bmw
      02-12-2024, 11:20 AM   #2
Phil325i
Phil325i's Avatar
616
Drives: E92 325i MSport Coupe
When I replaced mine I went OEM because that's all my indy would fit (to preserve BMW 2-year parts warranty). I think Febi are OE suppliers, so I guess you'd be OK with them...
      02-18-2024, 06:44 PM   #3
friedeggnchips
Yeah I may buy Febi. It's an important part so I don't want to buy some cheap chinese one but I've already spent £800 getting injector issues diagnosed and sorted (DIY'd the replacement injectors). I'm also going to need a new NOX sensor at some point. I can't justify spending almost £2,000 on a car that's 14 years old lol.
