View Poll Results: I own a...
2008 model and the waterpump failed. 176 14.05%
2008 model and the waterpump is ok. 194 15.48%
2009 model and the waterpump failed. 65 5.19%
2009 model and the waterpump is ok. 195 15.56%
2010 model and the waterpump failed. 18 1.44%
2010 model and the waterpump is ok. 87 6.94%
2011 model and the waterpump failed. 73 5.83%
2011 model and the waterpump is ok. 172 13.73%
2012 model and the waterpump failed. 52 4.15%
2012 model and the waterpump is ok. 103 8.22%
2013 model and the waterpump failed. 23 1.84%
2013 model and the waterpump is ok. 95 7.58%
Voters: 1253. You may not vote on this poll
      02-03-2022, 11:39 AM   #617
G3min1
Curious Gooner
Drives: 2010 BMW 135i M-Sport
2010 BMW 135i  [0.00]
2010 135i - 70500 Miles - N54 - Code:2E82 Electrical Cooling Pump:Switch Off
Indy Shoop replaced waterpump and thermostant for $900
      02-04-2022, 06:13 AM   #618
Gray_Panther
Gray_Panther's Avatar
1555
Drives: 128i
73k miles on my '12 still running fine. Let's see what this summer brings.
2012 BMW 128i 6MT Deep Sea Blue Metallic
      02-19-2022, 02:07 PM   #619
parameter416
384
Drives: 2012 128i M-Sport Coupe 6MT
I had the water pump & thermostat replaced this week (128i, 143,000km/89,000 mi). No sign of it failing. So now I'll never know if it would've lasted another 5k or another 50,000k.
      08-21-2023, 10:19 PM   #620
gtarwiz
Drives: 1989 325iS 2010 128i MTech
148,xxx miles and it was the thermostat that failed. Happened around the beginning of the year. 2010 128i
      08-23-2023, 02:42 PM   #621
jdt10768
jdt10768's Avatar
332
Drives: 2013 128i MSport 6MT
2013 128i msport 6mt, ~70k miles, no failure yet. Now I've jinxed myself . . .
      08-23-2023, 03:17 PM   #622
Maurtis
Drives: 2008 BMW 135i Convertible
2008 135i convertible auto, 63k miles, water pump failed last week. Shop is replacing the water pump, thermostat, coolant hose, coolant, and hood struts (unrelated but they fail on hot days) for $1,245.
      08-23-2023, 06:21 PM   #623
Almuliman
Drives: 2013 LMB 6MT 128i
2013, 08/13 production, 84K miles, hasn't failed yet, N51
      08-23-2023, 06:46 PM   #624
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
Yeah, I need to change my vote. 2011 135i is -1 on the no issue and +1 on the failure. replaced it a while back but forgot about this poll.
      08-24-2023, 07:05 AM   #625
JustAnotherSportsCar
JustAnotherSportsCar's Avatar
80
Drives: 2008 BMW 135i E88
2008 135i 6MT E88 with 97,000 miles. Previous owner replaced the water pump but not the thermostat. Thermostat was throwing a code when I bought the car in August 2021. I have since replaced the pump and thermostat while I had everything ripped apart for the turbo replacement job. I bought the least expensive genuine BMW parts I could find with the latest part numbers. Hoping to get another 75,000-100,000 miles before it needs any major work again.
      08-24-2023, 08:05 AM   #626
BikeNHV
131
Drives: 128i, F-350, Cooper SE
2009 128i w/ 144k mi. Still original.
I do a decent amount of preventative maintenance (occasional coolant drain/fill, but never a true "flush"), and have replaced some other cooling system parts.
09 128i 6MT Base N51|147k
BMWP and M parts mashup, plus some E36 wheels.
97 F-350 460ci Big Block 5MT 4x4
23 Battery-powered MINI
      08-24-2023, 08:20 AM   #627
jdt10768
jdt10768's Avatar
332
Sounds like our cars are just about the same Born On Date, what's your VIN?
Mine was built on 8/15/2013, w VIN ...VF46821
I think Aug 2013 was the last month of production
      08-24-2023, 02:51 PM   #628
Almuliman
VF46817 – you're 4 cars and 5 days newer: 2013-08-10 production date.
      08-24-2023, 03:33 PM   #629
jdt10768
jdt10768's Avatar
332
That's crazy - I wonder who has the last one built?
This car has particular chrono significance to me since it was built on our youngest son's birthday. Maybe he will inherit it, if he can learn to run a shop vac and orbital buffer . . .
      08-29-2023, 02:17 AM   #630
lvfb
35
Drives: BMW 128i cabrio
my water pump on my 2009 128i vertte e88 went out at approx 116k miles
mother fucker of a job to change out. take out the radiator fan so you have extra space!
      08-29-2023, 07:28 AM   #631
tracer bullet
Hmm, I didn't even think of that when I did mine. It ended up coming out 6 months or a year later to do the belt and tensioner pulley up front. If one does take the fan out they may as well do both jobs at the same time (belt/pulley and water pump).
      08-29-2023, 12:00 PM   #632
lvfb
35
yea that is what i did was replace the belt as well. so far havnt had any issues.. at least with that part of the car
