07-24-2014, 09:48 AM | #6953 | |
Rep 1,232
07-24-2014, 10:19 AM | #6954 | |
Rep 7
Then in the HU_NBT ECU change Acoustical_Lock_Confirm to Aktiv. Then tick the flag in the iDrive settings under "Doors". |
07-24-2014, 10:28 AM | #6955 | ||
General
10445
Rep 40,765
FZD => Akkustische Quittierung Entschaerfen = Acoustic acknowledgment when Disarming. FZD => Akkustische Quittierung Schaerfen = Acoustic acknowledgment when Arming regardless of the door status. FZD => Akkustische Quittierung Schaerfen mit Klappenbeachtung = Acoustic acknowledgment of Arming depends on the door status And these for Alarm Arming/Disarming Visual options: FZD => Optische Quittierung Entschaerfen = Visual Acknowledgment when Disarming. FZD => Optische Quittierung Schaerfen = Visual Acknowledgment when Arming regardless of the door status. FZD => Optische Quittierung Schaerfen mit Klappenbetrachtung = Visual Acknowledgment when Arming depends on the door status.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 07-25-2014 at 12:27 PM.. |
07-24-2014, 10:32 AM | #6956 | |
Rep 449
'17 F80 (RET)
'14 F22 M235i (RET) '11 E90 335i (RET) '07 E92 335i (RET) '89 E30 M3 (RET) |
07-24-2014, 10:37 AM | #6957 | |
Rep 7
The graphic shows up on the instrument cluster but there is no marker/slider to tell you what the temp is - frustrating. |
07-24-2014, 10:38 AM | #6958 | |
Rep 7
07-24-2014, 10:58 AM | #6959 |
Rep 449
Thanks for the info, hopefully I have that setting on my F22 since I have no temp gauge at all!
'17 F80 (RET)
07-24-2014, 11:25 AM | #6960 |
Rep 7
07-24-2014, 11:38 AM | #6961 |
Rep 449
'17 F80 (RET)
07-24-2014, 12:56 PM | #6962 |
Rep 1
Newbie....Just got my cable and have read through the initial quickstart guide. It's a few years old, is it still accurate or is there an updated version of the guide? Could someone send me the files/download link to get started?
07-24-2014, 12:58 PM | #6963 |
General
10445
Rep 40,765
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 07-24-2014 at 03:17 PM.. |
07-24-2014, 04:52 PM | #6964 |
Rep 3
Thanks so much for all the info!
Is there a token for the most recent ESYS that users are sharing, or do I have to go ahead and purchase one? Anyone willing to split? |
07-24-2014, 06:07 PM | #6965 |
General
10445
Rep 40,765
Token solution is cheap, and you are driving a brand new $40k plus 2014 BMW. I think you can afford to support one of the two developers, who happen to be fellow Bimmerpost users.
07-25-2014, 11:54 AM | #6966 | |
Rep 16
if you have an idea... thanks |
07-25-2014, 11:55 AM | #6967 |
General
10445
Rep 40,765
Maybe ENET Cable is crap.
07-25-2014, 12:16 PM | #6968 |
Rep 16
It's from CODECARD... and it's new!
Just to confirm, i need just Esys without Psdzdata to find identification of my I-step? thanks Last edited by pitbub; 07-25-2014 at 12:31 PM.. |
07-25-2014, 12:31 PM | #6969 |
General
10445
Rep 40,765
Yes, that is all you need to check I-Step.
Connection to car, should not be a problem so long as: 1) The Target Connection Window should not be blank (It should show multiple target connections for different chassis') 2) ENET Cable must be good 3) Car must have proper voltage (start engine). 4) Laptop must not have Firewall or any Antivirus software running. 5) PC Lan Adapter should get a fallback IP address of 169.254.xxx.xxx (Make sure it is using DHCP and does not have a Static IP address assigned to it) If the above are true, and you have tried multiple PC's, then you must examine Cable, and if it is good, then something is not right with Car Gateway Module.
07-25-2014, 12:46 PM | #6970 | |
Rep 16
sorry but i'm novice... 1) target connection in Esys ? (for choose my serie? it's blank for me) or in Windows? 2) indeed at the end 3) that, it's ok and easy 4) i'll check another time but normaly it's fine 5) |
07-25-2014, 12:56 PM | #6971 |
General
10445
Rep 40,765
So, you are saying that when you hit the E-Sys Connect button, you do not see Chassis Target Selections like this?
07-25-2014, 01:05 PM | #6972 | |
Rep 16
07-25-2014, 01:17 PM | #6973 |
General
10445
Rep 40,765
So, you have not properly installed your PSdZData to the E-Sys Data folder, or you have not set E-Sys Options properly to point to PSdZData location.
07-25-2014, 01:23 PM | #6974 | |
Rep 16
OK for resume, I copy my PSdZData in the good path, I connect my Esys and i read my I-step... |
